GolfVenture Posted August 20, 2014 Posted August 20, 2014 This Blue Tooth came off my helmet in an accident. I striped and cleaned the surface on both the Blue Tooth and the new Helmet. Put on what I thought was a strong double sided tape. But over a couple of months the tape gave up. The Blue Tooth is behind the brown double sided tape that I pealed off. Any good suggestion?
Freebird Posted August 20, 2014 Posted August 20, 2014 What kind of tape did you use? The 3M tape with the red backing is good. Available at most Automotive parts stores. Clean both surfaces with alcohol before putting it on.
Venturous Randy Posted August 20, 2014 Posted August 20, 2014 I went to an auto paint supply store and bought some trim/badge insulation tape. It seems to be very strong and weather and heat proof. RandyA
Wade 2000 Posted August 20, 2014 Posted August 20, 2014 What kind of tape did you use? The 3M tape with the red backing is good. Available at most Automotive parts stores. Clean both surfaces with alcohol before putting it on. I'll put a second to this as I have mounted many things with this tape and never had anything lose grip
Caveman Posted August 20, 2014 Posted August 20, 2014 Just another possibilty...velcro. I have used the 3m automotive trim tape and it will hold it also. Velcro..easy to remove and replace if needed.
GolfVenture Posted August 20, 2014 Author Posted August 20, 2014 Velcro or 3M. I'll experment. Thank You everyone.
Marcarl Posted August 20, 2014 Posted August 20, 2014 I use the 3m stuff mostly,, put some stuff on the Venture 10 years ago and it's still there as it was then. It's a little thick so if I need something thinner I use UGlu. It thin, absolutely miserable to work with, super sticky, and you need a world of patience, but it works! http://www.13deals.com/images/products/uglu_offer_01.jpg
Barrycuda Posted August 20, 2014 Posted August 20, 2014 What kind of tape did you use? The 3M tape with the red backing is good. Available at most Automotive parts stores. Clean both surfaces with alcohol before putting it on. Don is correct, this stuff is pretty good....
Tensilon Posted August 20, 2014 Posted August 20, 2014 Ditto on the 3M automotive grade double-sided trim adhesive tape;)
tz89 Posted August 21, 2014 Posted August 21, 2014 It's called 3M molding tape. It's seriously sticky!
