Kregerdoodle Posted January 18, 2008 Share #1 Posted January 18, 2008 Do I need to remove the tank to change out the plugs, I have 9k on the bike and not sure if they have ever been changed or not. Also what should they be gaped at?? Thanks Link to comment Share on other sites More sharing options...
BOO Posted January 18, 2008 Share #2 Posted January 18, 2008 I don't recall the gap, you will have to look in the manual. Some change the plugs without taking the tank off but it's not a big deal to remove the tank and it sure makes things easier. Good Luck, Jerry Link to comment Share on other sites More sharing options...
Squeeze Posted January 18, 2008 Share #3 Posted January 18, 2008 Gap should be 0.035 Inches Link to comment Share on other sites More sharing options...
Eck Posted January 18, 2008 Share #4 Posted January 18, 2008 I thought you have to remove the gas tank so you can get to the two top bolts on the dog bones (top engine mounts).. Link to comment Share on other sites More sharing options...
yamahamer Posted January 18, 2008 Share #5 Posted January 18, 2008 I thought you have to remove the gas tank so you can get to the two top bolts on the dog bones (top engine mounts).. IF THERE IS A WAY AROUND IT I'D LOVE TO KNOW:confused24: Link to comment Share on other sites More sharing options...
Squidley Posted January 18, 2008 Share #6 Posted January 18, 2008 I thought you have to remove the gas tank so you can get to the two top bolts on the dog bones (top engine mounts).. We have a winner!!! You can't take out the front plugs without the Tank off and the dogbones removed. I'll rewrite that....I dont know any other way to get the plugs out besides the previous statement Link to comment Share on other sites More sharing options...
BigD Posted January 18, 2008 Share #7 Posted January 18, 2008 At what mileage should the plugs be changed? Link to comment Share on other sites More sharing options...
Squidley Posted January 18, 2008 Share #8 Posted January 18, 2008 At what mileage should the plugs be changed? All depends D I like to change them out every year, that is more than the mfgr says which I think is about 30K. I like to have the assurace of the bike performing at it's best and the price of a set of plugs and an hour's time is negligeable in my book Link to comment Share on other sites More sharing options...
bill04 Posted January 18, 2008 Share #9 Posted January 18, 2008 Try this ,,, I use a piece of flat bar , 1x 1/4 in about 10 in long , i remove the 2 bolts that hold the tank in the front and loosen the bolt under the seat ,then i remove the tank plastic cover and pry it upwards so to put that piece of flat bar under the tank and leaning on top of the ignition switch ,it gives you enough lift to remove the two dog bones and not having to remove the tank especially when it's full . Work's fine for me . Link to comment Share on other sites More sharing options...
SamB Posted January 18, 2008 Share #10 Posted January 18, 2008 I just changed my Iriduim plugs out at 14K .Just because.. They had alot of life left in them. Link to comment Share on other sites More sharing options...
karbar99 Posted January 18, 2008 Share #11 Posted January 18, 2008 My book states changing at 16k. I went to the IRIDIUM plus as well. Plug #DPR8EIX-9, no gapping. Link to comment Share on other sites More sharing options...
Kregerdoodle Posted January 18, 2008 Author Share #12 Posted January 18, 2008 My book states changing at 16k. I went to the IRIDIUM plus as well. Plug #DPR8EIX-9, no gapping. Are these available at any auto parts store ??? Say NAPA ??? Link to comment Share on other sites More sharing options...
Mike G in SC Posted January 19, 2008 Share #13 Posted January 19, 2008 I changed my plugs a couple of weeks ago. First time on this bike (2006 RSTD). Have done it a few times on my previous Roadstar. The Roadstar is easier/quicker (and needed it more often). I did go to the Iridium Plugs (Carquest for about $8 each). Gap 32-35. I did have to remove the tank and seat. I ended up having to use the tool kit plug wrench because my plug socket would not get deep enough to turn the plug. I did remove the front engine mounts (one at a time for good luck). Use a can of compressed air to blow out any grit or pebbles before you pull the old plug. Two problems I had: A) the chrome (plastic) piece around the gas cap has 4 bolts. The nuts can free spin in their rubber grommets. One was a real fight. B) I was so proud when I looked in my bolt bucket and saw no spare parts left over,,,, until I looked where the tank had sat and saw this big rubber thing (looked like a starwars mock up). What the hell is that??? It was a "rubber baby buggy bumper" thing that keeps the tank from rattling. It stuck to the tank when I pulled it, fell off, and I didn't see it when I picked up the tank to put it back on. So,,, I had to take it all apart again. So, I kind of did this twice! By the way, my old plugs looked fine, 23K. I haven't noticed any gain by going to the Iridium plugs. SO, being a RSTD, it still runs great!!!! Mike G in SC Link to comment Share on other sites More sharing options...
Sleeperhawk Posted January 19, 2008 Share #14 Posted January 19, 2008 Are these available at any auto parts store ??? Say NAPA ??? I buy the normal plugs at Autozone all the time, but dont know about the Iridiums Link to comment Share on other sites More sharing options...
karbar99 Posted January 19, 2008 Share #15 Posted January 19, 2008 Purchased mine at Oreilly's Parts Store @$6.95 a plug. Oreilly's NGK IRIDIUM IX DPR8EIX-9 stock# is 2202. Any parts store that has NGK plugs should be able to help you. DO NOT gap these plugs, they're already pregapped. Link to comment Share on other sites More sharing options...
James Ardrey Posted January 19, 2008 Share #16 Posted January 19, 2008 Try this ,,, I use a piece of flat bar , 1x 1/4 in about 10 in long , i remove the 2 bolts that hold the tank in the front and loosen the bolt under the seat ,then i remove the tank plastic cover and pry it upwards so to put that piece of flat bar under the tank and leaning on top of the ignition switch ,it gives you enough lift to remove the two dog bones and not having to remove the tank especially when it's full . Work's fine for me .I do it in a similar fashion. Besides the weight of the gas I have led lights under the tank and I haven't put a quick release plug on them yet so I would have to take them loose from the tank. Link to comment Share on other sites More sharing options...
Squidley Posted January 19, 2008 Share #17 Posted January 19, 2008 Are these available at any auto parts store ??? Say NAPA ??? Some may argue with me here, but thats fine. I have used the Iridium plugs before and they didn't make a darn bit of difference in my bike. To me it's just a waste of money. I run nothing but the stock NGK's in the bike now and save $28 in the process...Just a few cents worth Link to comment Share on other sites More sharing options...
