bikerjohn Posted February 23, 2012 Posted February 23, 2012 (edited) I am going to go look at a pop up tomorrow? It is a 1968 Apache Falcon? it is 7'5'" in lengh 5'2"in width and 47"hieght Carries 400 max cargo I could not find the wieght of the trailer. My question is is this a good deal ad how much should I pay for it? How well would it tow behind my 06 Venture? Just found the wieght is 600 lbs? is this too heavy? The guy is asking $1500. Looking at the internet I found a old broucher that stats it was 645 plus frieght in '68. Any advice or help would be great John Edited February 23, 2012 by bikerjohn
bongobobny Posted February 23, 2012 Posted February 23, 2012 Will it pull it? Probably. Is the price good? Maybe, seeing as nowdays prices would be around $6000 give or take. I would take a closer look at what is out in the market as far as weight and compare efficiency. Was this trailer designed to be pulled by a motorcycle or a car? What did the present owner use to pull it?
TheKid Posted February 23, 2012 Posted February 23, 2012 I just did some research and looked it up. It is a very old FULL size pop-up camper designed to be pulled with a car. I personally would not pull that with a motorcycle but then I have seen some big pop-ups pulled by trikes. If I were you I would try to find a used pop-up that is designed to be pulled by a motorcyle. (Time Out trailers, Aspen Trailers made by Trailmaster, Bunkhouse, Roll-a-home, Lesur Lite, LivinLite quick silver 5.0, Kwik Kamp, etc) You can find good deals online you just might have to drive a distance or find someone in the area to check it out before you make the trip. Good Luck on your camper searching and purchasing.
Stache Posted February 23, 2012 Posted February 23, 2012 Carries 400 max cargo Just found the wieght is 600 lbs? is this too heavy? 600# empty + 400# cargo? Yes you could probably tow it, at least somewhere fairly level, but I suspect you'll have a bit$h of a time trying to get it to stop. Too heavy for me to consider it.
ragtop69gs Posted February 23, 2012 Posted February 23, 2012 Size and weight would be a big red flag for me. As already said, stopping that trailer would be a challenge.
Squidley Posted February 25, 2012 Posted February 25, 2012 John, If you haven't bought that trailer....dont, WAY too heavy empty, remember the RSV weighs in at 900+ lbs, and another 600lb trailer, this one isn't made for the bikes
warriorhoneybee Posted February 25, 2012 Posted February 25, 2012 thought i saw something yesterday about help with a trailer. well at least you are being told the same thing as yesterday, WAY TO HEAVY!!! good luck on a lighter one.
Marcarl Posted February 25, 2012 Posted February 25, 2012 Way to heavy to be comfortable, and safe. Also with the age, if you do look at something that old, be sure to check the frame underneath for rust, could be almost completely gone.
Scooter Bob Posted February 25, 2012 Posted February 25, 2012 I'm with the others here, way too heavy to start with. If you want a classic pop up, search for the Apache Chief. There were a couple for sale around here last spring for about a grand. They weigh about 275 empty.
