Guest msegelle Posted January 6, 2011 #1 Posted January 6, 2011 Question what is the best way to get a key made for a Venture if you don't have anything other than a key and the bikes V.I.N.? Dealer or locksmith? Thanks for the input.............. Mark
MiCarl Posted January 6, 2011 #2 Posted January 6, 2011 Probably a locksmith. If the key you have has the key code stamped on it then it's possible to order a key cut to that code.
Dave77459 Posted January 6, 2011 #3 Posted January 6, 2011 Here's a thread that could be helpful. I understand that if you don't have the keycode, you can find it on saddlebags or ignition switch stems. Or something. Dave
Snaggletooth Posted January 6, 2011 #4 Posted January 6, 2011 If it's a factory key it may still have the code numbers stamped into it. Any locksmith can code that and make a new key exacty like a new one. We have a locksmith here on the site that does a lot of keys for us by code. Maybe someone has his info. Most hardware stores carry blanks that work for our bikes to if the key is usable. I don't think the VIN# will play much of a role on this one. I know even within a give make and year there can be several different blanks used. Guys, don't some models have the key code on the ignition switch itself? Me. I avoid stealership whenever possible. I like my money in my pocket. When I bought my bike the PO gave me a handful of keys. They all worked in something but not in everything. One key was a factory key with the code number on it. It was so badly worn it would barely work at all. I found a locksmith online and sent him a the code number, a copy of my drivers license and a registration and he made me two new key and I made copies of those at the hardware store. Now every key works in everything. Good luck.
Flyinfool Posted January 6, 2011 #5 Posted January 6, 2011 I had my spares made at the local Ace Hardware. They stock the blanks.
RandyR Posted January 6, 2011 #6 Posted January 6, 2011 Dave77459 said: Here's a thread that could be helpful. I understand that if you don't have the keycode, you can find it on saddlebags or ignition switch stems. Or something. Dave I'd like to know where exactly, because I looked and couldn't find the key code that way.
Condor Posted January 6, 2011 #7 Posted January 6, 2011 RandyR said: I'd like to know where exactly, because I looked and couldn't find the key code that way. If I remember correctly the 1stGen's have the code on the back of the ignition, not sure about the 2ndGen. If you have the key, take it to a locksmith and have another cut. You might also check with your local Y dealer to see if they have any blanks...
Bubber Posted January 6, 2011 #8 Posted January 6, 2011 I looked for my self and you will find a number on the underside of the the rotating key hole cover on your gas cap. you will need a mirror to read it.:yikes: I never really checked it against my key but I was told that that is the key code.:moon: Take the key to any locksmith and for 5-5 dollar he will make you a key..... get a couple. Good luck Bubber
Guest msegelle Posted January 8, 2011 #9 Posted January 8, 2011 Thanks everyone for your help........ Mark:thumbsup2:
Rick Butler Posted January 9, 2011 #10 Posted January 9, 2011 Save yourself any grief, Take the bike and the key to a reputable locksmith and let them make one. And if it's a locksmith shop, they will have a blank. And then check it while you are there so if there is a problem, they can fix it. Hope this helps, Rick
RandyR Posted January 9, 2011 #11 Posted January 9, 2011 Yes there is a code under the key cover on the gas cap. It is NOT the key code for either my RSV or my RSTD.
