raceman62race Posted December 15, 2008 #1 Posted December 15, 2008 Just wondering if anyone has a 1st generation charging stator that is burned up that I might be able to talk you out of? I have some ideas that I want to experiment with and I need an old burned up/damaged stator
Dano Posted December 16, 2008 #2 Posted December 16, 2008 I believe I still have one on the shelf. PM your addy and I'll send it to you. Dan
Squidley Posted December 16, 2008 #3 Posted December 16, 2008 danob11 said: I believe I still have one on the shelf. PM your addy and I'll send it to you. Dan G2 Dano, he's got an '08 Might want to see if Ruffy down in Florida still has the one he replaced from his. HalRSV99 also replaced one and he's in Ontario Canada.
Dano Posted December 16, 2008 #4 Posted December 16, 2008 raceman62race said: Just wondering if anyone has a 1st generation charging stator that is burned up that I might be able to talk you out of? squidley said: G2 Dano, he's got an '08 Gee Squid, I thought you actually wore the glasses to see and understand words!!!!! I made SURE I read it twice to get it right!
Squidley Posted December 16, 2008 #5 Posted December 16, 2008 danob11 said: Gee Squid, I thought you actually wore the glasses to see and understand words!!!!! I made SURE I read it twice to get it right! Oh well...it happens He must be trying to help you 1st genners out with them antiques
barend Posted December 16, 2008 #6 Posted December 16, 2008 Actually might be, we were talking about boosting output at the NE Ga. M&E. Now what ideas john has I have no idea!
raceman62race Posted December 17, 2008 Author #7 Posted December 17, 2008 I'm going to try to hand wind a stator for more output. Use to work in a electric motor shop winding electric motors. Going to give it a try but not making any promises.
BOO Posted December 18, 2008 #8 Posted December 18, 2008 I think I might have one also. Would have to look around at the shop a little bit but I did replace one a few years back and I don't remember throwing it away. Good luck wit the rewind, Jerry
scotty Posted December 18, 2008 #9 Posted December 18, 2008 I have one on the floor of the garage. New one just showed up today. You are welcome to it. Scotty
Dano Posted December 18, 2008 #10 Posted December 18, 2008 It's on it's way tomorrow. Dan If you need a test subject, just send it back when you're done!!
Squeeze Posted December 18, 2008 #11 Posted December 18, 2008 danob11 said: It's on it's way tomorrow. Dan If you need a test subject, just send it back when you're done!! Was that an Application as a Crash Test Dummy ?? :rotf: Not that i doubt raceman's Abilities, but as skinny as you are, i'd give that a second Thought !!
Dano Posted December 18, 2008 #12 Posted December 18, 2008 Naw, skinny enuff that I just pass through most solids........ Thinking of adding some warm gear, knowing my stator isn't up to snuff to handle the load. I have my driving lights on all the time when I'm riding, notice a HUGE drain while I'm stopped. Could be that cheap Interstate gell battery I bought instead of the Odyssey. I'm starting to think it won't hold a load without the stator charging full, even tho its 22 amp/hour.
raceman62race Posted December 21, 2008 Author #13 Posted December 21, 2008 I'll let yall know how I come out after I am finished and test one or two.....If I can't beef it up for more output, maybe I can rewind them stock for less than a new one costs....We'll see!! Danob11...thanks for sending me one!!
Dragonslayer Posted December 23, 2008 #14 Posted December 23, 2008 raceman62race said: Just wondering if anyone has a 1st generation charging stator that is burned up that I might be able to talk you out of? I have some ideas that I want to experiment with and I need an old burned up/damaged statorI got one I just changed out a couple of months ago.
raceman62race Posted December 23, 2008 Author #15 Posted December 23, 2008 Just got one from danob11. At first glance, it looks like I will be able to rewind it stock no problem. I'll let you know if I can beef up the windings so it won't burn up as easy.
1BigDog Posted December 23, 2008 #16 Posted December 23, 2008 The higher output stators from Buckeye all need to be hard wired into place. From what I understand the higher output fries the plastic connector under the bike. I'd venture (pun intended) to say that any stator wired for more output needs to be hard wired in.
