This stream auto-updates
  1. Today
  2. The parts are available from Yamaha still. Here is a link to a site I use all the time to purchase my Yamaha parts. https://www.partshark.com/oemparts/a/yam/50042b41f8700209bc78980a/carburetor The parts you are looking for are listed as item numbers 37-40, but I think that item 37 includes the other 3 but I am not sure.. If you dont order from this site least you will have the Yamaha part numbers to order from someplace else. I have not tried to replace these parts yet so I can not tell you how difficult it is but check out the tech pages and search for carburetor rebuild and you should find some other information there. Good luck Rick F.
  3. The clear yellow oil is the new Yamalube shock oil. The black stuff is what drained out of the shock. Well over 125ml. The engine hadn't been running for a couple of days before I saw the oil on the shop floor.
  4. Yesterday
  5. Ok now where did that plastic cup of clean oil come from? Is that your new shock oil that you put into the shock, or is that the mystery oil that came from somewhere else on your bike? If that isn't new shock oil, then the first thing I would suspect is crankcase oil blowing out breather tubes that come out down near where the lower shock mount is. But I'm at a loss as to what caused it to leak out if you didn't run the engine when you washed the bike. But also, your profile says this is a 2010 RSV trike. Never seen one up close. Does the trike setup have any additional oil reservoirs down under? Happy belated birthday by the way!
  6. WELLLLLLL..... It was NOT the shock. The shock was had plenty of oil in it and was not leaking. However, since I had it off, I changed the O ring and oil. I was putting it back on, got all 3 bolts in and could not find the lock nut for the 3rd bolt. 🤔 So, I didn't get it finished today. I'll get a new nut tonight and finish it the first thing in the morning. The other side of the equation is the problem. Where did you clear yellow oil come from that was under my bike after we washed it. I didn't start it to move it out to be washed or when I moved it back in the shop. Here are some pics of the oil and the frame I built to fix it. To say the oil was dirty is an understatement. Now I will keep an eye out for oil leaks.
  7. 1987 Venture Royalle 13 DT. I have had issues with my carbs overflowing. I have taken them off to clean them. One of the carbs has a sticking float valve. The seat that the valve sits in has burrs inside that won't allow the valve to move smoothly. I have tried a few things to shave the inside without luck. I don't know how it got that way. It had been working before I took it apart. It is difficult to get anything straight down in there. I have a rebuild kit that has a replacement valve and seat. If I can't smooth it out how hard would it be to replace it? Are the correct caps available? How hard is it to dislodge the valve seat. Thanks!
  8. Good morning to all riders out there. We've had 11 straight days with no rain and we can need some rain in our area. The good news...rain may be coming this afternoon and tonight for a change. Everybody have a great day.
  9. Last week
  10. @bpate4homeUp to this day, I am very appreciative of the weather app that we have today on our cellphone. No more guess work on weather and doppler radar is our best companion on every ride. Always ride safe.
  11. I forgot to wear mine when riding yesterday. Would have been interesting. Got in 100 mi but dodging some rain drops.
  12. Could the rear brake pads have grease on them?
  13. Share some pics when you can! Here's mine just now - dry 950 miles later. And if yours was low on shock fluid and was pogo sticking, you will be amazed at how much better the ride is when you get it fixed.
  14. I got the shock off this afternoon. It took about 20 minutes to get it set in the vise and start draining it. I made the bracket to press it up to change the O ring but stopped for dinner. It looks like it will be an easy fix, but I didn't get the fork oil today so it will be Tuesday before I can reinstall it.
  15. Brakes are not linked on Royal Star Ventures. May be a collapsed line somewhere. Start at the outlet of the master cylinder break that connection and press on the pedal, if fluid freely flows, reconnect and work your way down the line until you find a point where the flow is diminished, if you get to the bleeder valve on the caliper and do not find an issue, maybe the calipers are stuck or dirty to the point they will not move freely.
  16. Hmmm.. I do know from experience that when replacing, or in your case rebuilding a master cylinder it can be a pain to get the juice to flow at first. With the master full and the brake line disconnected at the master, what happens when you pump the brake handle? I don't think the front / rear brakes are linked on the second gen...not sure though. If they were I'd wonder about the proportioning valve. Someone should chime in and confirm or deny that they're linked. It doesn't seem that it should be this difficult, but I've had similar situations. (Don't make sense) I feel your pain, but I think if you stick with it you'll find the answer. It sounds like (so far) you've been checking all the boxes.
  17. I hooked my vacuum to the bleeder and took line loose at master cylinder, and it pulled a vacuum on my finger. It is open. I took MC off and went back in to make sure seals were correct, had a friend look also, they were correct. We fill the MC with fluid the best we could and filled the reservoir down to MC the best we could and connected lines. Still can not get a pedal. Tried reverse fill with a large tube like a syringe all while working the brake pedal. Tried reverse fill again. Still cannot get a pedal. I have now tied the brake pedal all the way down and will leave overnight. (old trick). I also beat and vibrated the brake lines from MC back to caliber especially where the line has high spots. If This does not help, I plan to take it to someone that is supposed to know. Has anybody else had this problem bleeding the venture?????
  18. So....I wonder if you were to remove the hose from the master cylinder and immerse it in a container of brake fluid and try the vacuum bleeder at the wheel cylinder....would it draw through the hose? If not, then that would seem to indicate an issue within the brake tubing between the master / slave cylinder.
  19. Hope they get some more done before we go there is nothing past the bridge
  20. Earlier
  21. OK, I rebuilt the master cylinder and reinstalled. Can not get to pump back up. I tried to use a vacuum bleeder and got some fluid to go down some in the reservoir, but can not get any more to go down, all while holding vacuum on the bleeder. Tried pumping the pedal slowly with vacuum, still not fluid going down. I tried a 1 man bleeder that I just purchased and can not get fluid at bleeder valve at rear brake. I'm at my wits end. Any advice and help will be appreciated. . Tomorrow I will try reverse bleeding by using a big syringe that I bought a Orileys. Hope thar helps. Thank you in advance
  22. I go to Batteries+ Bulbs. I have a 5yr AGM I'm my 07 RSTD. If it fails all I have to do is take it back and get a new one. They go by your phone number to find your receipt.
  23. Likewise on this end...planning to do some moderate riding around and take advantage of the nice weather all weekend long and up until Labor day. I wear a fitness band on my wrist all day and it keeps track of my activities including steps, workout activities and one of them is heart rate. I find it comforting to know that my heart rate drops all the way down to 50, when I ride and simply enjoy the wind. With that said, relax and enjoy the ride.
  24. Rode to the office today. Been able to get in more and more. Wife is still a little scared of me riding after the stroke but just taking it easy and not pressing it. With the Monday holiday hoping the weather holds out and I can get in a couple hundred miles.
  25. Good morning to the Venturerider community. Another great weather in store for us here in SE Pa. Enjoy the rides and ride safe.
  26. If my health hasn't degraded I'll try to get my 82 yr old butt on the bike and ride there too.
  27. The MC is very simple. Nothing to rebuilding it. I disassembled mine but the seals looked fine so I didn't use my new kit. The RSV is notorious for having a too powerful rear brake so something is definitely wrong with yours. I would bleed it more and if that didn't fix it I might put new seals in the MC. Is the caliper working smoothly and releasing quickly like it should? You might need to rebuild the caliper.
  1. Load more activity
