This stream auto-updates
  1. Yesterday
  2. Good morning to all. Yesterday, I was able to complete my planned project on the RSV. Installed another Denali Sound Bomb horn on the RSV this time. It didn't take long for me to decide where to install the horn so I got to work right away. Just applied blue loctites on all bolts and made sure that I used nylon lock nuts to the horn mounts. It turned out great IMO and very satisfied. Today, we are having some very fine mist and cloudy. I guess thanks to Hurricane Erin that is just offshore off the east coast. On a day that I really want to go out may turn out to be a day of indoor activities and more computer and ham radio. The agenda is to hit the gym and do a little bit of riding, but that will have to wait for another day. Attached are some pics and a very short video for attention. IMG_1283.MP4
  3. Last week
  4. I have 135000 on my rsv and last been about 70000 since I changed. Bike still runs good, what is best plug and what best gap.
  5. I get from 33 to 52 mpg. According to how hard I ride.
  6. Good morning to all! Pretty cloudy here in SE Pa. I guess due to that offshore east coast weather disturbance. Spotty showers but will not account for anything. Spent a few hours wiring the Denali SoundBomb horn on the RSV and will finalize the install early this afternoon. Tested the horn last night and it works! Have to stop by the local Home Depot to get a longer 5/16 bolt to properly secure the horn mount. Blue Loctite only. Hope you guys have a great day and ride safe. God Bless to all.
  7. It has been a long time since I had my Venture, so I have forgotten a lot about it, but if the Venture has any rubber lines in the rear brake system, it may be that those sections have weakened over time and stretch or expand when pressure is applied. If there are rubber sections, maybe it is time to replace them, preferably with braided steel covering. Just a thought. This would not necessarily have anything to do with air bubbles, but could affect the ability to lock up the rear wheel and slide it, which the Venture should do very easily, as the rear brakes are known to do that even of good dry pavement.
  8. Don't know if it applies the same in this situation, but I know a collapsed brake line can cause some problems. When you bleed at the caliper, does it seem to have good pressure?
  9. Woody
    Vogel 2025
    Joe and Bobbi made it home
  10. Yes, open and close like always when doing a car. I did not know if there was a problem with an air bubble like I had on my gold wing clutch. It seems like it should be easy, but my brake got worse every time I changed my rear tire.
  11. I know...Dumb question, but I gotta ask.... When bleeding by pumping the pedal, are you tightening down the bleeder screw before releasing the pedal? If bleeding with a vac pumper, are you tightening down the bleeder screw before removing? I'm just wondering if you're letting air back in after bleeding....
  12. Lisa and I got home around 730 last night. Thanks to y'all for another great get together. It was wonderful to see so many of my Venturerider friends again. Already looking forward to the next one. Will post a pic or two when I get a minute.
  13. I put a Bluetooth receiver in the bike. Just stream any playlist I want off the phone. Way easier for me.
  14. RDawson
    Vogel 2025
    Just walked in the door. Stopped to eat with the youngest in Huntsville.
  15. Just walked in the door. We detoured through Huntsville to visit the rocket scientist.
  16. Patricia and I had to come home Saturday morning and didn't get to go see the crew before we left. It was a wonderful trip and I was thankful to get to meet some fine people. I pray everyone makes it home safely. Steve.
  17. Woody
    Vogel 2025
    I heard Skid, Mike & Shirley, made it home safely. yawl let us know when you make it home, you know family worries.
  18. Woody
    Vogel 2025
    We are glad to see everyone and we had a good time and some nice rides
  19. It is possible that you need to rebuild the master cylinder. It's not a difficult or expensive job, but sometimes necessary.
  20. OK. I drained and ran new DOT synthetic fluid today. Still can not get full pedal. Rode the bike and it will not slide tire on dirt road. Looks like there is still air coming out while using the vacuum pump. Why is that? Is there a trick to bleeding to get air out. As I said every time I change a tire off, my brake pedal got softer. I have fluid coming using my vacuum bleeder, but it still looks like air bubbles coming into line from the bleeder valve. I took bleeder valve out and put thread tape on, replaced and still looks that way. I have never done brakes other than pump and bleed on cars. Is there sometime I am over looking or a trick to bleed. I read somewhere about someone using what they called reverse bleeding, where you force fluid back into the reservoir thur the bleeder valve. I'm at my wits end. Any suggestions will be appreciated. If you know of anyone on here that could help. Thank you in advance.
  21. 2nd gen are not linked. Make sure you have fluid. I change the brake fluid in all my bikes every two years regardless of miles ridden
  22. Ride it to get it warmed up, leave it running and get a propane torch that has propane in it. Open the torch valve but do not light it. No go around the intake with the propane torch and see if there is any change in the engine. If not, an intake leak can be ruled out, if there is a change then you have a leak and needs to be addressed.
  23. Can't remember if the 2nd gen has linked brakes, so the front left with the rear. If they do you can find lots of air in the line going through the triple tree. There will be a bleeder screw there.
  24. Blue sky, thank you for your post. I'm having same problem. 2002 RSV 135k miles. Every time I change a rear tire, my brakes got worse. Now will not slide tire on dirt. I just used my vacuum pump to change all fluid and still looks like bubbles coming into the clear line. I have run about 4 or 5 oz thur it. Any other advice. I have never rebuilt a master cylinder. Thank you.
  25. I, he did not in this case. Just the rubber diaphragm and slipped down.
  26. Did he rebuild it??? Did it correct the problem??? thank you
  27. The brakes on the RSV are not linked. Take a look at this thread.
  1. Load more activity
