- Today
Brakes are not linked on Royal Star Ventures. May be a collapsed line somewhere. Start at the outlet of the master cylinder break that connection and press on the pedal, if fluid freely flows, reconnect and work your way down the line until you find a point where the flow is diminished, if you get to the bleeder valve on the caliper and do not find an issue, maybe the calipers are stuck or dirty to the point they will not move freely.
- Yesterday
Hmmm.. I do know from experience that when replacing, or in your case rebuilding a master cylinder it can be a pain to get the juice to flow at first. With the master full and the brake line disconnected at the master, what happens when you pump the brake handle? I don't think the front / rear brakes are linked on the second gen...not sure though. If they were I'd wonder about the proportioning valve. Someone should chime in and confirm or deny that they're linked. It doesn't seem that it should be this difficult, but I've had similar situations. (Don't make sense) I feel your pain, but I think if you stick with it you'll find the answer. It sounds like (so far) you've been checking all the boxes.
I hooked my vacuum to the bleeder and took line loose at master cylinder, and it pulled a vacuum on my finger. It is open. I took MC off and went back in to make sure seals were correct, had a friend look also, they were correct. We fill the MC with fluid the best we could and filled the reservoir down to MC the best we could and connected lines. Still can not get a pedal. Tried reverse fill with a large tube like a syringe all while working the brake pedal. Tried reverse fill again. Still cannot get a pedal. I have now tied the brake pedal all the way down and will leave overnight. (old trick). I also beat and vibrated the brake lines from MC back to caliber especially where the line has high spots. If This does not help, I plan to take it to someone that is supposed to know. Has anybody else had this problem bleeding the venture?????
So....I wonder if you were to remove the hose from the master cylinder and immerse it in a container of brake fluid and try the vacuum bleeder at the wheel cylinder....would it draw through the hose? If not, then that would seem to indicate an issue within the brake tubing between the master / slave cylinder.
OK, I rebuilt the master cylinder and reinstalled. Can not get to pump back up. I tried to use a vacuum bleeder and got some fluid to go down some in the reservoir, but can not get any more to go down, all while holding vacuum on the bleeder. Tried pumping the pedal slowly with vacuum, still not fluid going down. I tried a 1 man bleeder that I just purchased and can not get fluid at bleeder valve at rear brake. I'm at my wits end. Any advice and help will be appreciated. . Tomorrow I will try reverse bleeding by using a big syringe that I bought a Orileys. Hope thar helps. Thank you in advance
I go to Batteries+ Bulbs. I have a 5yr AGM I'm my 07 RSTD. If it fails all I have to do is take it back and get a new one. They go by your phone number to find your receipt.
- Last week
Likewise on this end...planning to do some moderate riding around and take advantage of the nice weather all weekend long and up until Labor day. I wear a fitness band on my wrist all day and it keeps track of my activities including steps, workout activities and one of them is heart rate. I find it comforting to know that my heart rate drops all the way down to 50, when I ride and simply enjoy the wind. With that said, relax and enjoy the ride.
I use dot 4
Rode to the office today. Been able to get in more and more. Wife is still a little scared of me riding after the stroke but just taking it easy and not pressing it. With the Monday holiday hoping the weather holds out and I can get in a couple hundred miles.
Good morning to the Venturerider community. Another great weather in store for us here in SE Pa. Enjoy the rides and ride safe.
BlueSky started following HELP,,,,,,,,Soft rear brakes on 2002 RSV and Asheville 2026
If my health hasn't degraded I'll try to get my 82 yr old butt on the bike and ride there too.
The MC is very simple. Nothing to rebuilding it. I disassembled mine but the seals looked fine so I didn't use my new kit. The RSV is notorious for having a too powerful rear brake so something is definitely wrong with yours. I would bleed it more and if that didn't fix it I might put new seals in the MC. Is the caliper working smoothly and releasing quickly like it should? You might need to rebuild the caliper.
You said you used synthetic fluid. What DOT number is it? DOT 5 is not compatible with our brakes. DOT 3, 4, and 5.1 are compatible.
Thanks guys. There sure are a lot of brands. the real problem is finding out who makes them. I decided to go with Walmart. If I have a problem win the road a Walmart is just around the corner Thanks again, labile
Good morning to all! Beautiful weather in our area and I hope you also have good weather. Running errands today and my transportation of choice is the Yamaha. Ride Safe.
Thank you Paul. That looks very doable for me.
Steve, if you're mechanically inclined and wanted to try and tackle it yourself, see this writeup:
If he’s traveling it may take some time to hear back from him.
Thank you, Ronnie. I have sent him a text and am waiting to hear back from him.
carb intake size
M61A1MECH replied to Precious's topic in Royal Star and Royal Star Tour Deluxe Tech Talk
The original Royal Stars(1996 to 2001) hade 28 mm carbs. Venture style Royal Stars including the Venture (1999 to 2013) and the Tour DeLuxe (2005 to 2010) had 32 mm carbs. From AI Key Dates for Yamaha Royal Star: 1996: The initial Yamaha Royal Star model was introduced. 1996–2001: This period included the initial Royal Star cruiser and the Royal Star Tour Classic, a version of the Venture with some features removed. 1999: Yamaha launched a new full-dress touring version called the Royal Star Venture. 2005: The Royal Star Tour Deluxe was introduced, which was a standard Royal Star Venture model with no touring features like a fairing, radio, and trunk. -
I texted @dfitzbiz contact info to you. He’ll rebuild it.
Does anyone know the size of the carb air intake on a 98 RSTD? I'm getting two different results when I search. 28 MM and 32 MM. I have had enough with the big ugly air box on this scoot! I'm changing to pods.
It is more or less ok to ride but you’ll get a pogo effect. If it’s just leaking oil, you can repair it.
I washed the Venture today and after backing it back in the shop to put it back together, I noticed some oil dripping underneath the center of the bike. Looked it over and it looks like the shock is leaking. A couple of questions here. Will it hurt to continue to ride the bike with a bad shock? And second, who can I get to rebuild this shock? Thanks for any help.
