This stream auto-updates
  1. Today
  2. Have fun on your test ride. The Voltage at 13.7V is what you want. Healthy voltage! I think your riding season has just started and thousands of miles ahead...
  3. no need to leave the forum
  4. I bought some Prestone antifreeze that said was compatible with Aluminum and Cast Iron but didn't get any positive response about using it so bought from dealer who got this at a good price and I paid $13can for it! Bought 3! Checked all fluids and topped them up,started bike and meter showed 13.7v at idle and increased with throttle so hopefully take for test run tomorrow and my charging problems are solved!
  5. Happy Trails
  6. What @N3FOL said! You can still keep intuch with everyone here even if you don't ride anymore!
  7. Yesterday
  8. Take care @uechi kid, but we will still be here talking about bikes and everything else. Hope to hear from you time to time in this forum. Enjoy your summer!
  9. The time has come for me to say goodbye. I haven’t ridden much in the past 5 years so I sold my Venture. I need to make sure I thank everyone here for being such a great community. You’ve made being a diy guy so much easier. The expertise here has saved me time, money and a lot of aggravation. It’s been great. Ride safe. Rich Flay
  10. Last week
  11. How much for just the saddlebags?
  12. Good morning to all! Glad I was able to cut the grass yesterday. Off to church then washing the truck later this afternoon. Enjoy your day.
  13. I had one hydro lock but fortunately the piston with fuel must have been at TDC so no clunk and no damage, Took the plugs out and it sprayed fuel all over when it turned it over,
  14. I think it depends if another cylinder fired with that one going up on compression stroke, that’s the big clunk. They’ll sometimes run for a little while until the bent rod lets go, often opening an inspection hole in the block.
  15. Hydrolock was the first thing that came to my mind. Doesn't that usually bend a rod instantly?
  16. Sorry to hear about your brother, my condolences. I will be here when you want to talk about lighting.
  17. I have used your harnesses before; they are awesome! Was struggling with what I thought was a harness problem recently; turned out to be the stator, but your relays and harnesses are installed on this trike. Considering talking to you about more lights; will start a new thread about it. My brother died an hour ago; I'm a bit preoccupied right now.
  18. If you’re anywhere near west Ky I’m trying to clear all of this out of my shop. $400 for it all. Chrome forks, both fenders, saddlebags, trunk, fairing.
  19. I build light bars for Ventures, you could attach one to the cargo tray if you wanted to, it will give you tail lights, brake lights and turn signals. In this photo it is mounted under my trunk. Completely plug and play.
  20. Hey Everyone! I have been in and out of this forum for a long time. I have had a 09 Venture that I bought from my Dad when he had a mini stroke and couldn’t balance the bike anymore but i was working on his bike long before it was mine. I had dropped the bike a few times when I first got it and damaged the left saddlebag. I had originally fixed it with some hot staples and that worked well enough to keep stuff inside of the saddlebag. I dropped it again about a year after that and that same spot broke again. I wasn’t able to fix it because I was missing pieces of plastic. I had a lot of stuff going on for a while so I put off buying a new one. I am looking at the saddlebags out there for the bike and they are more expensive than they were when I first looked at them a few years ago. Is there any good places to buy cheaper saddlebags and plastics for the bike. I was also thinking about 3D printing my own if I can find someone with a printer that would print one if I supplied the materials. Thank you to all of you who have posted in the tech forums for your help over the years. I have been able to fix a lot of problems by referring to your conversations and insight!
  21. @sleepy2 My thoughts and prayers to you and your nephew's family and close friends. My your nephew rest in peace. Not surprised about the price of anti-freeze from a moto dealer. The next time I do my anti-freeze, I am simply sticking with Prestone which I seem to have no problems with. Take your time and enjoy the install. The fruits of your labor will show in no time. Got called in to work once again, but at least I was able to ride and take advantage of the nice weather we are having.
  22. Haven't had much time this past week as Nephew passed away from liver and pancreas problems he had been battling for a few years, he did pass peacefully though! Was able to pick up some Antefreeze the other day(boy has it gone up)from dealer! One had it at $20 per liter and other was $13 per liter (Ipone) Have all cooling drains tightened up and am ready to fill with Antifreeze but will triple check everything first. Also ready to install new Voltage Regulator, oil filter then fill with oil.
  23. Pull the plugs and see if it’ll turn. Check the oil to see if it’s full of gas to Rule out a hydrolock situation.
  24. I ordered an Air Filter for my SVTC, but I got the wrong air filter. This is what they sent me (see pic) and it will have to go back as a return. The one I got is way too big. Would anyone know the exact part number of the air filter for the 2018 SVTC?
  25. Looking for set up for little cargo attachment for tow ball. With cargo it blocks rear lights and tag
  26. Good morning to all! TGIF. Weather is great here in SE Pa. Have been riding for the last 2 days after all the rain last weekend. Cutting the grass today and I just might have enough daylight to wash the truck. Enjoy your Friday.
  27. I own a 2009 Royal Star Tour Deluxe S. It is a weekend rider for short trip and only has 7500 miles on it. It has been meticulously maintained and I've never had an ounce of trouble with it. I recently experienced a starting issue where I heard a loud "clunk" like metal hitting metal when attempting to start and then the motor would not turn. The solenoid would click, but the engine did not turn. I thought my battery had lost charge, so I put it on the charger overnight. The next day, she started fine. After a handful of rides, the issue repeated itself. Again, thinking my battery was low, I put it on the charger and it started fine the next time. Unfortunately, it happened a third time and the solenoid clicks, but the motor will not turn even after a battery charge. I had the battery load tested and it passed with no issues. I replaced the solenoid, but that did not help. After reading through a few posts, I am thinking it might be my starter clutch. Perhaps something has broken internally and not allowing the motor to turn? I would like some advice on how I could diagnose the root cause to ensure I am fixing the right problem. If it is the starter clutch, is it a repair that I can do myself and are there any available instructions? Thanks in advance for your help!
  28. Earlier
  29. I was in the Army from 67 to 70 when we had a half million GIs in Viet Nam. Fortunately for me, I was sent to S. Korea. But, a friend died over there, my first cousin was shot in the abdomen but survived and another friend came home with a creased helmet that was shot off his head. Almost everybody my age, 82, knows someone who died over there. I am a student of history and the heroes who sacrificed themselves in WWI and WW2, the Korean war and all the others are owed a tremendous debt. If anyone would like to know more about the war in the Pacific during WWII, watch Battle 360 on youtube. It's a series of programs mostly following the Aircraft carrier Enterprise, the only carrier we had that survived the entire war. It's an amazing story.
  1. Load more activity
