cmiles3 Posted July 30, 2007 Share #1 Posted July 30, 2007 Have 2, a custom and a Markland. Both came with '88 parts bikes I sold, but neither was installed. I can fit them, but I'd like to see how other first gen trailer hitches are installed. Looks like there are several options for the front connection, some move more than others. Looks like the connections under the saddlebags might require a longer bolt, or some spacers. Shoulda gone to Ft. Collins and got my own photos. Link to comment Share on other sites More sharing options...
Squidley Posted July 30, 2007 Share #2 Posted July 30, 2007 Chuck, Hopefully these will help you out a bit. Link to comment Share on other sites More sharing options...
Leadwolf56 Posted July 31, 2007 Share #3 Posted July 31, 2007 I mounted my markland hitch after looking at Squidley's pictures. You'll need either longer bolts through the saddlebags or as I did I used a smaller shoulder bolt that just slid through the bolt hole. It's not real difficult to mount but I had to lose my rear mudflap. It works very well, I now have about 2800 miles pulling my Bushtec trailer with no problems at all. Link to comment Share on other sites More sharing options...
cmiles3 Posted July 31, 2007 Author Share #4 Posted July 31, 2007 Thanks. Just what I needed. Chuck, Hopefully these will help you out a bit. Link to comment Share on other sites More sharing options...
GigaWhiskey Posted July 31, 2007 Share #5 Posted July 31, 2007 I shore would like to have a hitch on mine. If for just looks or a place to put the Knob Creek after buying it from the Liquor Store. Oh yea, and to trip out the crotch rockets at work. Link to comment Share on other sites More sharing options...
jdross440 Posted December 1, 2012 Share #6 Posted December 1, 2012 Does anyone have a photo the forward attachments looking down or forward to show exactly where it fits? I have the picture attached looking in but nothing showing how it fits on the bolt. Link to comment Share on other sites More sharing options...
KIC Posted December 3, 2012 Share #7 Posted December 3, 2012 Here are the pictures of my 89. I took this Markland off of my 87. I was able to keep my mudflap by drilling a few holes and mounting under the hitch. Link to comment Share on other sites More sharing options...
Pegasus1300 Posted December 4, 2012 Share #8 Posted December 4, 2012 Is this the stock mud flap you are having trouble with?I have mounted 2 Marklands one on an 83 and one on an 86 and they all cleared the flap just fine.The front mounts to the muffler mounts.There should be no movement when all mounted up.Use a longer screw/bolt that will go thru the nut on the bag mount the use another nut/washer to tighten it up to the bottom of the bag mount.There is also a u clamp that goes on at the tabs back by the ball plate.BTW this description only applies to the 86-93 series. Link to comment Share on other sites More sharing options...
Flyinfool Posted December 4, 2012 Share #9 Posted December 4, 2012 (edited) Does anyone have a photo the forward attachments looking down or forward to show exactly where it fits? I have the picture attached looking in but nothing showing how it fits on the bolt. It is really hard to try to get a pic of this area, it's tight and only accessible from below. With mine I had to get longer blots for the muffler mount. Watch your bolt length, to long can hit the rear suspension, to short and the nut will fall off. The stack up is, with the muffler mounted as normal the bolt goes thru a nut that is welded to the frame, so you put the front of the Markland bracket on the end of the muffler bolt that is sticking out of the weld nut, and then put a lock nut on to hold the bracket. For the middle mount that goes up under the saddle bags, I drilled out the 6mm weld nut that is on the crash bar to 1/4 inch. I then made up a spacer out of a piece of galvanized pipe that had an ID to just fit over the drilled out nut. the length of the spacer should be just long enough to fill the space between the plate on the hitch and the plate on the crash bar. I then used a 1/4-20 grade 8 bolt that went from inside of the bag thru the drilled nut, thru the spacer, thru the plate of the hitch thru a grade 8 flat washer and finally a grade 8 lock nut. For the rear mount there are 2 tabs on the chrome part of the hitch. There should be a short flat strap with a hole in each end that goes from this tab to a bracket that attaches to a piece of frame that holds the bumper on. Most people do not remove this bracket when taking the hitch off of another bike. So it is often missing. This is how I modified my Markland hitch http://www.venturerider.org/forum/showthread.php?t=52757 Edited December 6, 2012 by Flyinfool Link to comment Share on other sites More sharing options...
jdross440 Posted December 6, 2012 Share #10 Posted December 6, 2012 Thanks. This will help a bunch. Link to comment Share on other sites More sharing options...
Krazykarl Posted April 28, 2013 Share #11 Posted April 28, 2013 So glad this post is still around!!!! Link to comment Share on other sites More sharing options...
Pasta Burner Posted March 20, 2022 Share #12 Posted March 20, 2022 @Squidley@Freebird any chance of restoring these pics? Sorry for all the requests. I took my markland off when I first got the bike and am trying to put it back on. I think I understand from the words but just want to be sure. Link to comment Share on other sites More sharing options...
Freebird Posted March 25, 2022 Share #13 Posted March 25, 2022 On 3/20/2022 at 4:59 PM, Pasta Burner said: @Squidley@Freebird any chance of restoring these pics? Sorry for all the requests. I took my markland off when I first got the bike and am trying to put it back on. I think I understand from the words but just want to be sure. I restored what I could find. FlyinFools pictures must have been kinked or something because I don't find them. 1 Link to comment Share on other sites More sharing options...
