User Tag List
Thanks Thanks:  0
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Brake lights on Star venture
  1. #1
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Brake lights on Star venture
    Does anyone know does bike have to be moving for brake lights to work sitting idling and not driving brake lights will not come on signals work and 4 ways work. Any ideas or is it bad to the shop
  2. #2
    Join Date
    Aug 2006
    Reading
    PA
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Brake lights on Star venture
    On all the bikes I have owned, the brake lites work when the bike is sitting still and the brakes are applied. Thats how they inspect them here in Pa. Should lite when front or rear brakes are applied. Mite want to check the fuses.
    Craig
  3. #3
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cecdoo View Post
    Craig
    Back to dealer tommrow was going to go for my first ride but no brake lights no ride
  4. #4
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ZOEYDOG View Post
    Got it fixed was just the brake light switch needed adjustment they must not have caught it at the factory or dealer. Now tommorrow first ride on the Venture.
  5. Likes cecdoo liked this post
  6. #5
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    15 Post(s)
    Tagged
    0 Thread(s)
    Glad you figured it out. Most brake light switches are mechanically activated. Some the pedal engages the switch and some have a linkage that pulls the switch to on. I have seen a couple on cars that were in line and pressure activated. Another reason you need to be a little mechanically inclined to ride. No guaranty the mechanic doing the work was 100% although thats what we are paying for.
    2013 Black Victory XCT
    Trailers are for when your bike is broke, aint they?
  7. #6
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by djh3 View Post
    It has a pull switch was pondering what it could be then thought of the switch surprised it was never pickup on was glad I had my wife check the back I am always checking lights and oil and tire pressure before riding.
  8. #7
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Iím working on a different issue. I noticed that the rear bag lights only function as turn signal. Iím looking into a proper modification that will also allow them to function as brake lights for better visibility.
  9. #8
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Brake lights on Star venture / Backup camera
    I also noticed that the infotainment system actually has tie ins for a BACKUP camera installation. Was on the phone with Yamaha Customer Service & ordered a manual for the bike so I can get the proper tie ins to make that happen. Found an excellent mini camera that mounts on license plate frame and is very unobtrusive & stealthy.
    Will let you know how it goes!
  10. Likes lugthar liked this post
  11. #9
    Join Date
    Apr 2013
    Colfax
    WI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How fast do those things go in reverse?
    Dennis
  12. Likes ChiefGunner liked this post
  13. #10
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Karaboo View Post
    Very funny Karaboo! Itís to be able to easily see how your rig is towing without turning around. Side views only give you a partial. Also, sheís a BIG girl and backing her ina tight spot can be tense. Itís hard to see her butt and a camera, especially with IR for night takes all the worry out of it with a clear view.
  14. #11
    Join Date
    Apr 2018
    Vine Grove
    KY
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ChiefGunner View Post
    I would be careful with the towing. Saw some other posts around with folks looking for hitches and stuff. Digging through the manual, it specifically states that this bike is not engineered for towing anything, and is probably not encouraged, especially warranty wise. Just putting that out there....
  15. #12
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    201 Post(s)
    Tagged
    0 Thread(s)
    I think that nearly every bike out there has similar things in the manual. A lot of us still do it though. I guess there are some instances where it could affect your warranty but they have to PROVE that towing caused the issue. I guess I'm a bit stubborn, on any vehicle I own, I use it the way that I want to and need to. If I ever have a problem, I'll fight the battle.
  16. #13
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    So just wondering how you made out with this idea? One problem you may run into is what I ran into when I first started building light bars for the2nd Gen Ventures. I used the same 4 LEDs on either side of the center LED as brake and turn signals, problem was if you held the brake lever back or used the foot pedal the brake the lights stayed on constant, the brake did not allow the LEDs to go out when the turn signal cycled. I tried to compensate for that by adding some dropping resistors in the brake circuit just before the LED light bar, that way you still got the brake signal to the light bar but at slightly less than full brightness, when the brakes and turns were both applied the affected 4 LEDs would cycle from full bright (turn signal power on) to reduced brightness (brake power applied) so there was still a turn indication working.
    Steve K
    Edgewater , FL
    And the LORD said "Thou shalt have dominion over all of the animals, Except of course the cat."
    DR. Goldwing; has the antidote for the blues
  17. #14
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by johnnyroid View Post
    Every single bike manufacturer makes the same statement. It’s a liability thing, but Wings, HD, Stars, Shadows, Ventures, Valkyrie’s etc... have been towing for a few decades.
    i don’t recommend it for a novice rider, but most people riding a bike big enough to tow aren’t usually novice riders either.
  18. #15
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by M61A1MECH View Post
    I like doing my research so I don’t have to “re-invent” the wheel. This is the best item I’ve found to do what we want with the rear lighting. I like the fact too that it has a number of selectable patterns you can choose from to even further personalize it.
    https://www.jpcycles.com/product/632...conversion-kit
Similar Threads
  1. Replies: 8
    Last Post: 06-13-2016, 10:29 PM
  2. 2008 Royal Star Venture - Head Lights
    By Kozubek in forum General Tech Talk
    Last Post: 02-25-2016, 06:32 AM
  3. Hyder brake lights turn off driving lights ???
    By cb1313 in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 06-18-2009, 09:25 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
