Jus Monkeyin Around Posted August 11, 2008 #1 Posted August 11, 2008 (edited) Just bought an 86 Royale was told carbs were rebuilt ha took them off they were not so I took them apart and cleaned them put it all back with no extra parts I get it to idle at 1000 rpms but im getting popping and back fireing please help. Edited August 11, 2008 by DavePankow48089
Fvogt Posted August 11, 2008 #2 Posted August 11, 2008 This could be raw gas getting into the exhaust system or a lean condition caused by: carbs not seated correctly, vacuum leak of some sort. Fred
GigaWhiskey Posted August 11, 2008 #3 Posted August 11, 2008 Do the diaphragms have pinholes in them? Did you tighten all four screws for each diaphram? Miss one, you might just get that backfire.
Jus Monkeyin Around Posted August 11, 2008 Author #4 Posted August 11, 2008 Thank you did not see any pinholes just checked to see if seated correctly seems to be ok now maybe it was just still some gunk in fuel line ran 1/2 tank now seems to be better still running rich thou. now my suspension computer reads E4 and it is not working anyone know what that code is?? Dave
Condor Posted August 11, 2008 #5 Posted August 11, 2008 DavePankow48089 said: now my suspension computer reads E4 and it is not working anyone know what that code is?? Dave It's saying solder me...solder me.....
Jus Monkeyin Around Posted August 12, 2008 Author #7 Posted August 12, 2008 reads E4 and is not working HHHHEEEEEELLLPPPPPP please Dave
Rocket Posted August 12, 2008 #8 Posted August 12, 2008 DavePankow48089 said: reads E4 and is not working HHHHEEEEEELLLPPPPPP please Dave http://www.venturerider.org/forum/showthread.php?t=493
Jus Monkeyin Around Posted August 12, 2008 Author #9 Posted August 12, 2008 Thank you for the link found all 9 pins cracked resoldered put back together still reads e4 now im stumped any thoughts???????????
GigaWhiskey Posted August 12, 2008 #10 Posted August 12, 2008 (edited) I have seen lonestarmedic fix an E4 on TexasYamahaMamas bike. Wonder if he has some advice. Edited August 12, 2008 by GigaWhiskey
Dano Posted August 12, 2008 #11 Posted August 12, 2008 Do you have the airbox and filter installed? These bikes do not like to have unrestricted air.
sarges46 Posted August 12, 2008 #12 Posted August 12, 2008 DavePankow48089 said: Thank you for the link found all 9 pins cracked resoldered put back together still reads e4 now im stumped any thoughts??????????? Redo them...this time do all the pins in the thing...both boards. I had to on mine...second time I didnt even bother looking for bad ones...I just did em all. Worked great.
Squidley Posted August 12, 2008 #14 Posted August 12, 2008 Dave, Where abouts in Warren are you? I work in Pontiac and live in Marine City. If you like I could stop over and give you a hand.
6m459 Posted August 14, 2008 #15 Posted August 14, 2008 I have always found that backfiring on my Venture was cured when any leaks in her exhaust system were fixed. How is your exhaust sytstem ? Hope this is of some help / interest. Brian H. Uxbridge Ont
Captain Murph Posted August 14, 2008 #16 Posted August 14, 2008 sarges46 said: Redo them...this time do all the pins in the thing...both boards. I had to on mine...second time I didnt even bother looking for bad ones...I just did em all. Worked great. YES! I find that half of the CLASS controllers are fixed by doing only the connector pins. Most of the others that still don't work will if you carefully redo every single pin on that board. It is not that hard, but please make sure you aren't doing it with a soldering gun but a lower wattage (40-75W) pencil iron. Some of the other other components on the board might get damaged if you get things too hot. Good luck. While it is no guarantee, I will repeat again that these CLASS BOARD problems seem to be caused by component connnections not component failures.
Jus Monkeyin Around Posted August 14, 2008 Author #17 Posted August 14, 2008 Correct my iron is 25 watt worked out beautifully Thank You I love it when a plan comes together!!!!!!!!!
