VegasVic Posted July 31, 2008 Share #1 Posted July 31, 2008 Love this site and this is my first post. I just bought a 2001 RSV, and there was no tool kit which came with it. I tried my digital air pressure guage to check, but it wouldn't even go on the valve stem. My air hose inflater/deflater went on, but showed 0psi. I'm not sure it opened the Schrader valve. Any thoughts? Link to comment Share on other sites More sharing options...
cmiles3 Posted July 31, 2008 Share #2 Posted July 31, 2008 On my 1st Gen, it's always been difficult to check pressure in the front forks. I use a regular dial pressure gage and it works, but I lose pressure every time I check it. So it's a real balancing act to measure, add air, measure again until I'm satisfied. Today I bought a suspension pump at a bicycle shop. It is a low volume pump, with a dial pressure gage and a screw on inflating valve. Works well, and doesn't lose a lot of air when you disconnect. Mine was $35. You can find them on the internet. Link to comment Share on other sites More sharing options...
kbran Posted July 31, 2008 Share #3 Posted July 31, 2008 Look at the suspension air fork balance kit on this page http://www.denniskirk.com/jsp/search/search.jsp?store=Main&searchString=PROGRESSIVE&sort=priceasc Then look for the progressive suspension air pump on this page http://www.denniskirk.com/jsp/search/search.jsp?currentOffset=0&previousPageOffset=0&nextPageOffset=20&np=&searchString=PROGRESSIVE&store=Main&sort=priceasc&np=0&page=&limit=20&next.x=13&next.y=10. It will allow you to put air in small icrements with zero loss when removed. You can add olnly 7lbs. to the front forks, up to 50 on the rear. The air suspension comes with zero from the factory, you have to adjust for you ride. The balance kit makes it easy to get the same amount of air in both front forks. Link to comment Share on other sites More sharing options...
V7Goose Posted July 31, 2008 Share #4 Posted July 31, 2008 Because the front forks have such low volume and pressure for air, you absolutely must have a gauge with a zero loss chuck to even check them (such as the Progressive shock pump with gauge). Realistically, there is no way to properly set the pressure with a separate pump and gauge - you need a combined unit. Do NOT try to add air with any compressor! It is also absolutely critical to be CERTAIN that both forks are EXACTLY equal in pressure. Even a minor difference will affect the handling - not dangerous, but it is certainly noticeable that it just doesn't feel as confident. If in doubt, the best option is to just run with no air. This is the default factory setting and is absolutely fine for must riders and conditions. And in any conditions, it will be way better than having the pressure different in each fork. Last comment - a balance kit certainly seems to be a good idea. But there have been about equal reports here from people who had real problems getting one fitted correctly and those that said they work great with no problems at all. Just FYI. I'd suggest you do a search for old posts before you decide what to do. Goose Link to comment Share on other sites More sharing options...
EFudd Posted August 1, 2008 Share #5 Posted August 1, 2008 Have an air tank (about 5 gal. without compressor) that I used to fill at the local gas station, then recently bought a compressor. I fill the tank to 6psi from the compressor then fill the front forks with it. High volume ratio so as long as the chuck on/chuck off is quick the front forks are equal and at the pressure I want. Link to comment Share on other sites More sharing options...
Pappa Bear Posted August 1, 2008 Share #6 Posted August 1, 2008 Adding air?, Isn't that what the class system does? Link to comment Share on other sites More sharing options...
bobcat Posted August 2, 2008 Share #7 Posted August 2, 2008 On my 1st Gen, it's always been difficult to check pressure in the front forks. I use a regular dial pressure gage and it works, but I lose pressure every time I check it. So it's a real balancing act to measure, add air, measure again until I'm satisfied. Today I bought a suspension pump at a bicycle shop. It is a low volume pump, with a dial pressure gage and a screw on inflating valve. Works well, and doesn't lose a lot of air when you disconnect. Mine was $35. You can find them on the internet. Doesn't your class system work? Link to comment Share on other sites More sharing options...
Bummer Posted August 2, 2008 Share #8 Posted August 2, 2008 Not since all the wires rattled loose. Ok, that was the '85 and I fixed it by just resoldering all the connections, but time does take its toll. Link to comment Share on other sites More sharing options...
waterbug Posted August 2, 2008 Share #9 Posted August 2, 2008 What is preasure is everyone running in there shocks? I was told by the sales guy at the dealer I shouldnt have to worry about adding any unless I haul a load and maybe put some in the rear. Mine is still what ever it was when I bought it and I am not sure if I should add any or not??? Link to comment Share on other sites More sharing options...
Maritimer Posted August 2, 2008 Share #10 Posted August 2, 2008 Anyone have tried the balance kit on a RSV with front end lowered? The air valve is just a fraction of an inch from the handle bars. And if that won't work, would the pump described above by kbran work on lowered front end? Thanks Link to comment Share on other sites More sharing options...
PaleRider Posted August 2, 2008 Share #11 Posted August 2, 2008 Go down to the nearest HD dealer, buy the (Touring Accessory) Suspension Air Pump (54630-03A) for $44. Best price, best deal. It won't let the air leak out. For most applications, 4lbs (first mark) in front shocks and 25lbs in rear shock. DO NOTE go over 7lbs in front shock, unless you want a large bill. http://www.harley-davidson.com/gma/gma_product.jsp?PRODUCT%3C%3Eprd_id=845524442292571&FOLDER%3C%3Efolder_id=2534374309149264&ASSORTMENT%3C%3East_id=2534374309149264&bmUID=1217685128893&bmLocale=en_US Link to comment Share on other sites More sharing options...
Bummer Posted August 2, 2008 Share #12 Posted August 2, 2008 What is preasure is everyone running in there shocks? I was told by the sales guy at the dealer I shouldnt have to worry about adding any unless I haul a load and maybe put some in the rear. Mine is still what ever it was when I bought it and I am not sure if I should add any or not???Hi! I like to add up the total load I'm going to be running with the lop off the right number. eg 200 lbs, 20 psig in rear shock. 400 lbs, 40 psig in rear shock. I put 6 in the front and just leave it there. Keeps it from bottoming on hard braking. Where in Indy. If we're ever in the same place at the same time I can show you the pumps I have for the suspension. Link to comment Share on other sites More sharing options...
Pudycat03 Posted February 3, 2009 Share #13 Posted February 3, 2009 I did not get an owner's manual yet (one on the way), where is the air valve for the rear suspension located? Link to comment Share on other sites More sharing options...
KeithR Posted February 3, 2009 Share #14 Posted February 3, 2009 You can download the owners manual at this link...unless you want a paper copy. keith http://www.venturerider.org/forum/showthread.php?t=1828 Link to comment Share on other sites More sharing options...
V7Goose Posted February 4, 2009 Share #15 Posted February 4, 2009 All Royal Star owners manuals from 2000 - 2009 are available for free review and download on their web site. Although the bike has not changed, the manual has changed several times. Goose Link to comment Share on other sites More sharing options...
