RDawson Posted July 8, 2025 Posted July 8, 2025 Not starting the darkside argument but I just learned Virginia has outlawed car tires on motorcycles.
RDawson Posted July 8, 2025 Author Posted July 8, 2025 7 minutes ago, ragtop69gs said: How will this law effect out of state riders? I don’t know, I didn’t read the whole law. What I saw is that they have annual inspections and it’s an automatic failure to have a car tire. My wife asked me the same question and my only answer is that we’ll find out if they stop me. 1
RDawson Posted July 8, 2025 Author Posted July 8, 2025 1 hour ago, Woody said: say it isn't so, I have two car tires on mine. 😊 Overachiever
bpate4home Posted July 8, 2025 Posted July 8, 2025 11 hours ago, RDawson said: Not starting the darkside argument but I just learned Virginia has outlawed car tires on motorcycles. Not what I found online: Here is the full online item for inspection: Item 6 seems to be the key item. 19VAC30-70-400. Motorcycle tires, wheels, rims. Inspect for and reject if: 1. Any tire has a cut or puncture, not to include a plug or patch that may be used as a manner of repair, or is worn so that the fabric is visible. NOTE: Plugs/patches shall be in the tread area only. Plugs/patches are not permitted in the side wall of the tire. 2. Any tire has knots or bulges in any side wall or if there is evidence of a broken belt under the tread or of the tread separating from the fabric. 3. Any bolts, nuts, lugs or spokes are bent, loose or missing. Rims or wheels are bent, cracked or damaged so as to affect the safe operation of the motorcycle. 4. Wheel bearings are excessively worn or out of adjustment. 5. Any motorcycle is equipped with a tire that has a tread depth measuring less than 2/32 of an inch when measured in accordance with the instructions set forth in subdivisions 6, 7, and 8 of 19VAC30-70-130. 6. Any tire is marked specifically for use other than on the highway such as "For Farm Use Only," "For Off-Highway Use Only," "For Mobile Home Use Only," or "For Trailer Use Only." 7. Any motorcycle tire has been recut or regrooved. 8. Directional tires or wheels designed and manufactured to go in a certain direction or rotation are not installed in the proper direction of rotation.
RDawson Posted July 8, 2025 Author Posted July 8, 2025 (edited) 37 minutes ago, bpate4home said: Not what I found online: Here is the full online item for inspection: Item 6 seems to be the key item. 19VAC30-70-400. Motorcycle tires, wheels, rims. Inspect for and reject if: 1. Any tire has a cut or puncture, not to include a plug or patch that may be used as a manner of repair, or is worn so that the fabric is visible. NOTE: Plugs/patches shall be in the tread area only. Plugs/patches are not permitted in the side wall of the tire. 2. Any tire has knots or bulges in any side wall or if there is evidence of a broken belt under the tread or of the tread separating from the fabric. 3. Any bolts, nuts, lugs or spokes are bent, loose or missing. Rims or wheels are bent, cracked or damaged so as to affect the safe operation of the motorcycle. 4. Wheel bearings are excessively worn or out of adjustment. 5. Any motorcycle is equipped with a tire that has a tread depth measuring less than 2/32 of an inch when measured in accordance with the instructions set forth in subdivisions 6, 7, and 8 of 19VAC30-70-130. 6. Any tire is marked specifically for use other than on the highway such as "For Farm Use Only," "For Off-Highway Use Only," "For Mobile Home Use Only," or "For Trailer Use Only." 7. Any motorcycle tire has been recut or regrooved. 8. Directional tires or wheels designed and manufactured to go in a certain direction or rotation are not installed in the proper direction of rotation. I I couldn’t link it but here’s a screenshot of what I’m seeing in multiple places. Unless it’s another false news scam, lots of those going around. Edited July 8, 2025 by RDawson
BratmanXj Posted July 8, 2025 Posted July 8, 2025 2 hours ago, bpate4home said: Not what I found online: Here is the full online item for inspection: Item 6 seems to be the key item. 19VAC30-70-400. Motorcycle tires, wheels, rims. Inspect for and reject if: 1. Any tire has a cut or puncture, not to include a plug or patch that may be used as a manner of repair, or is worn so that the fabric is visible. NOTE: Plugs/patches shall be in the tread area only. Plugs/patches are not permitted in the side wall of the tire. 2. Any tire has knots or bulges in any side wall or if there is evidence of a broken belt under the tread or of the tread separating from the fabric. 3. Any bolts, nuts, lugs or spokes are bent, loose or missing. Rims or wheels are bent, cracked or damaged so as to affect the safe operation of the motorcycle. 4. Wheel bearings are excessively worn or out of adjustment. 5. Any motorcycle is equipped with a tire that has a tread depth measuring less than 2/32 of an inch when measured in accordance with the instructions set forth in subdivisions 6, 7, and 8 of 19VAC30-70-130. 6. Any tire is marked specifically for use other than on the highway such as "For Farm Use Only," "For Off-Highway Use Only," "For Mobile Home Use Only," or "For Trailer Use Only." 7. Any motorcycle tire has been recut or regrooved. 8. Directional tires or wheels designed and manufactured to go in a certain direction or rotation are not installed in the proper direction of rotation. But also #8 for some of us. I have a 18" Stratoliner front where where I was running a rear tire backwards on the front. Some call this "double" darkside if run in conjunction with a rear CT.
