RDawson Posted April 14, 2025 #1 Posted April 14, 2025 Neighbor bought a 2023 Spyder new last year. The dealer has had it more time than he has. It has a bad front end vibration they can’t get out of it (I don’t have much faith in that dealer). Any recommendations here?
N3FOL Posted April 14, 2025 #2 Posted April 14, 2025 They probably should look deeper into the repair history of the vehicle. I am just speculating that it might have been involved in an accident that has never been mentioned. If you don't ask, the dealer will not volunteer any information. If there is no other fix, as far as I am concerned, I would like my money back.
RDawson Posted April 14, 2025 Author #3 Posted April 14, 2025 4 minutes ago, N3FOL said: They probably should look deeper into the repair history of the vehicle. I am just speculating that it might have been involved in an accident that has never been mentioned. If you don't ask, the dealer will not volunteer any information. If there is no other fix, as far as I am concerned, I would like my money back. He bought it new. Problems from day one.
N3FOL Posted April 14, 2025 #4 Posted April 14, 2025 Look into the Lemon Law applicable to motorcycles.
Marcarl Posted April 15, 2025 #6 Posted April 15, 2025 Front wheel alignment. Had that issue when I bought my 2014. Front wheels need to be aligned with the rear wheel, not the body necessarily. It's been about 6 years since I did this and it's not on-line anywhere that I know of. Hopefully I remembered all the steps I took. A little understanding though might be needed. Also, this is not how Canam does their alignment, but they did it 3 times and 3 times they failed. Concrete floor, flat and level. 1) install and set the belt for the rear wheel. 1A) set and fasten the steering gear in perfect center, measure well, set snug. 2) set a target behind the bike about 1' behind the tire to use for marking on, 1x3 works great, pasted to the floor. 3) using a laser mark the rear wheel outsides on the 1x3, not the tire, the wheel. 4) now you can measure to mark the center of the bike on the 1x3. 5) make 2 identical inserts to fit the front wheel hubs so that you can set a laser on them and rotate from floor to rear. Identical, very important!!! I made mine with some brass and a speaker magnet glued to it to hold the laser. 6) shoot the laser to the floor at the tire and make that mark on a piece of masking tape pasted on the floor. 7) roll the bike ahead and measure the distance between the marks, make note. eight) now shoot the laser to the 1x3 from the front wheel and make that mark 9) both marks should be the same distance from the center mark from the back wheel. 10) check to see how the measurements work out compared to the front measurement. 11) you can now adjust the tie rods so that the front tires have a 5 to 10 degree toe-in. As you drive they will automatically toe-out a bit to come straight as they should. 12) a crowfoot wrench is very handy to get at the inside nuts. 1
RDawson Posted April 15, 2025 Author #7 Posted April 15, 2025 Thanks Carl, that’s what I think he’s looking for. The dealer is a mega store and deals with mostly atv’s and utv’s from several brands. I checked them out when I was looking for a utv and wasn’t impressed with their people. I went elsewhere because of that. He’s wishing he did too.
N3FOL Posted April 15, 2025 #8 Posted April 15, 2025 13 hours ago, Marcarl said: Front wheel alignment. Had that issue when I bought my 2014. Front wheels need to be aligned with the rear wheel, not the body necessarily. It's been about 6 years since I did this and it's not on-line anywhere that I know of. Hopefully I remembered all the steps I took. A little understanding though might be needed. Also, this is not how Canam does their alignment, but they did it 3 times and 3 times they failed. Concrete floor, flat and level. 1) install and set the belt for the rear wheel. 1A) set and fasten the steering gear in perfect center, measure well, set snug. 2) set a target behind the bike about 1' behind the tire to use for marking on, 1x3 works great, pasted to the floor. 3) using a laser mark the rear wheel outsides on the 1x3, not the tire, the wheel. 4) now you can measure to mark the center of the bike on the 1x3. 5) make 2 identical inserts to fit the front wheel hubs so that you can set a laser on them and rotate from floor to rear. Identical, very important!!! I made mine with some brass and a speaker magnet glued to it to hold the laser. 6) shoot the laser to the floor at the tire and make that mark on a piece of masking tape pasted on the floor. 7) roll the bike ahead and measure the distance between the marks, make note. eight) now shoot the laser to the 1x3 from the front wheel and make that mark 9) both marks should be the same distance from the center mark from the back wheel. 10) check to see how the measurements work out compared to the front measurement. 11) you can now adjust the tie rods so that the front tires have a 5 to 10 degree toe-in. As you drive they will automatically toe-out a bit to come straight as they should. 12) a crowfoot wrench is very handy to get at the inside nuts. It does looks like a lot of work for a bike that may still be under warranty. I hope the neighbor finds a competent shop that is able to fix his issue.
Marcarl Posted April 15, 2025 #9 Posted April 15, 2025 2 hours ago, N3FOL said: It does looks like a lot of work for a bike that may still be under warranty. I hope the neighbor finds a competent shop that is able to fix his issue. i found that it's not necessarily the shop, it's the procedure followed or maybe how close it's followed. Canam does alignment on front wheels using the body center line. This way the wheels are aligned to each other, the fronts to the rear. Yah, it's a bit of work but then it's rewarding. 1
N3FOL Posted April 16, 2025 #10 Posted April 16, 2025 Speaking of CanAm, I was at Don's Kawasaki yesterday and had my SVTC front tire mounted and balanced. While waiting in their showroom, I got the chance to take a closer look at their new 2025 RedRock model built for street and mainly for offroad use. It is sharp. If only I can find the funds to support my desire, this CanAm is a great addition to the fleet. 1
Riderduke Posted May 29, 2025 #11 Posted May 29, 2025 @RDawson I know I'm late with this answer... Here is an option for an alignment.. I've had it done and I noticed the difference.. http://www.spydercomfort.com/dealers.htm 1
RDawson Posted May 29, 2025 Author #12 Posted May 29, 2025 34 minutes ago, Riderduke said: @RDawson I know I'm late with this answer... Here is an option for an alignment.. I've had it done and I noticed the difference.. http://www.spydercomfort.com/dealers.htm Thanks. I’ll show him this.
uncledj Posted May 30, 2025 #13 Posted May 30, 2025 I was thinking about getting a Spyder but y'all are scarin' me a bit.
bpate4home Posted May 30, 2025 #14 Posted May 30, 2025 1 hour ago, uncledj said: I was thinking about getting a Spyder but y'all are scarin' me a bit. My wife had one for about 3 years and there was nothing wrong with it. Never any issues. she stopped riding out of fear (and weak shoulders). She had a close call on a ride that scared her pretty bad. The spyders do take a lot more shoulder input than a bike or trike. 1 1
N3FOL Posted May 30, 2025 #15 Posted May 30, 2025 I really thought the steering is power assisted, but I may be wrong.
Marcarl Posted May 30, 2025 #16 Posted May 30, 2025 Steering is power assisted but it still takes more input than a Venture, normally wouldn't be an issue but if your arms or shoulders have a weakening effect the difference will be noticed. 1
N3FOL Posted May 30, 2025 #17 Posted May 30, 2025 I've never test ride one, but I think I can see what you mean. Turning can involve a little bit of shoulders and some twisting on the torso perhaps especially on sharp turns.
Marcarl Posted May 31, 2025 #18 Posted May 31, 2025 21 hours ago, N3FOL said: I've never test ride one, but I think I can see what you mean. Turning can involve a little bit of shoulders and some twisting on the torso perhaps especially on sharp turns. I would say that is much over stated but to say if you have compromised shoulder(s) and find it difficult on a 2 wheels then don't go to a Spyder would be more realistic.
Riderduke Posted June 18, 2025 #19 Posted June 18, 2025 (edited) As someone who only has 2 muscles connected in the left shoulder and can't lift / push more then 10-15 lbs with it... The Spyder is the only touring bike, that I've tried, that I could comfortably ride... I tried a tri-glide and the steering was too heavy in slow speed maneuvers.. When I'm having fun in the twisties, I pay for it later with shoulder soreness... But it's doable... The power assist in slow speed maneuvers make it possible that I can one hand the turns.. The soreness comes due to having to hold on when I shift my torso in fast curves... I had to put "short reach" (longer) bars on it in order to be able to hold on to the left grip in a right hand full turn of the wheels. (my left arm reach is almost half the length of what it used to be..) Turning the wheels at a dead stop is problematic as I don't have enough strength to push or pull them with my left shoulder. I have never had a problem with my 21' Spyder F3 in the 4 years, 20,000+ miles I've owned it (knock wood)... Edited June 18, 2025 by Riderduke
bpate4home Posted June 18, 2025 #20 Posted June 18, 2025 1 hour ago, Riderduke said: As someone who only has 2 muscles connected in the left shoulder and can't lift / push more then 10-15 lbs with it... The Spyder is the only touring bike, that I've tried, that I could comfortably ride... I tried a tri-glide and the steering was too heavy in slow speed maneuvers.. When I'm having fun in the twisties, I pay for it later with shoulder soreness... But it's doable... The power assist in slow speed maneuvers make it possible that I can one hand the turns.. The soreness comes due to having to hold on when I shift my torso in fast curves... I had to put "short reach" (longer) bars on it in order to be able to hold on to the left grip in a right hand full turn of the wheels. (my left arm reach is almost half the length of what it used to be..) Turning the wheels at a dead stop is problematic as I don't have enough strength to push or pull them with my left shoulder. I have never had a problem with my 21' Spyder F3 in the 4 years, 20,000+ miles I've owned it (knock wood)... David, Just a thought, I have bad Arthritis in my left shoulder and recently had a stroke where my left arm lost most of its motion. I picked up a therapy shoulder pulley from amazon and it helped immensely for range of motion and shoulder strength. Not sure if you have something like this but using it daily help alleviate the pain and now I'm just short of full motion. Not sure if it would help you but. . . . . Amazon.com: Shoulder Pulley for Physical Therapy, Pulleys for Shoulder Rehab Over Door, Shoulder Pulley Over The Door Physical Therapy, Door Pulleys For Physical Therapy, Arm Pulley, Over The Door Pulleys : Health & Household
Riderduke Posted June 18, 2025 #21 Posted June 18, 2025 2 minutes ago, bpate4home said: David, Just a thought, I have bad Arthritis in my left shoulder and recently had a stroke where my left arm lost most of its motion. I picked up a therapy shoulder pulley from amazon and it helped immensely for range of motion and shoulder strength. Not sure if you have something like this but using it daily help alleviate the pain and now I'm just short of full motion. Not sure if it would help you but. . . . . Amazon.com: Shoulder Pulley for Physical Therapy, Pulleys for Shoulder Rehab Over Door, Shoulder Pulley Over The Door Physical Therapy, Door Pulleys For Physical Therapy, Arm Pulley, Over The Door Pulleys : Health & Household Yeah I have one and use it most evenings to keep my range of motion and limber.... Thanks for your concern
