Yammer Dan Posted February 25, 2007 Share #26 Posted February 25, 2007 Yep if you need to continue practicing we're here to help!!! Link to comment Share on other sites More sharing options...
FROG MAN Posted February 25, 2007 Share #27 Posted February 25, 2007 I need to ignore or delete this thread. I can't afford to let mamamo see that trike.:mo money: Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 25, 2007 Share #28 Posted February 25, 2007 Yep that could just about do it.... Link to comment Share on other sites More sharing options...
DragonRider Posted February 26, 2007 Share #29 Posted February 26, 2007 Fantastic looking trike. How long did it take from start to finish.............Love the color. Congraulations Link to comment Share on other sites More sharing options...
Squidley Posted February 26, 2007 Share #30 Posted February 26, 2007 Jerry, Very Very nice job on it bud I'm sure that will turn many heads as your rolling along. You ARE going to be riding it to Freebirds on Maintenance Day right?! Link to comment Share on other sites More sharing options...
Jerry M Posted February 26, 2007 Author Share #31 Posted February 26, 2007 I am planning on being there,We are going to ride the Natchetz Trace Parkway in May.If everything goes well should be at Don's in June. Link to comment Share on other sites More sharing options...
Jerry M Posted February 26, 2007 Author Share #32 Posted February 26, 2007 Fantastic looking trike. How long did it take from start to finish.............Love the color. Congraulations It is hard to say how long it took,you could build the trike in a week if you had everything you needed.I added a few things to the body I molded the license plate into the trunk lid,Installed Diamond plate to the inside of the trunk,increaced the depth of the trunk by cutting a 22'x8'' hole out and adding a box with lid now I have extra storage.I also molded aluminum to the side of the body where it bolts to the orig.frame to enclose it better.I made the bumper out of a custom truck grill and used what I had left for the luggage rack,worked out great.I also took a rear spoiler from a 87 buick and cut it down mounted it on the rear above the trunk.The color is the oem color for 05 RSTD.I think that is about all I did.Jerry M Link to comment Share on other sites More sharing options...
bikenut Posted February 27, 2007 Share #33 Posted February 27, 2007 Jerry You should be very proud for a great job done. That turned out great. Hope to meet up with you some day on the road. Later Link to comment Share on other sites More sharing options...
Sailor Posted February 27, 2007 Share #34 Posted February 27, 2007 That is one of the nicest trikes I have ever seen. Now all you have to do is drop in that 360 hp hyabusa v8 on kneeslider.com or that W9 engine on hosepowersports.com. 182 cu in 262 lbs 526 hp stock...1005 turbocharged Just kidding.....but that W9 would fit into my merc with lots of room left over. Link to comment Share on other sites More sharing options...
Jerry M Posted February 27, 2007 Author Share #35 Posted February 27, 2007 Sailor; what year merc.do you have?Jerry M Link to comment Share on other sites More sharing options...
Sailor Posted February 28, 2007 Share #36 Posted February 28, 2007 '51 lead sled. chopped, dropped etc full custom chev running gear candy apple red Link to comment Share on other sites More sharing options...
Guest HarveyWhite Posted April 2, 2007 Share #37 Posted April 2, 2007 great job!!! where did you get the kit? my son has a bike like this one and are woundering where you got the kit. Link to comment Share on other sites More sharing options...
Jerry M Posted April 3, 2007 Author Share #38 Posted April 3, 2007 The kit is from Tri-Wing Ind.They are in Canada.The kit I used is the 2nd.gen.it uses the stock swing arm.They are a quality product.the body's are flawless. Link to comment Share on other sites More sharing options...
Guest HarveyWhite Posted April 3, 2007 Share #39 Posted April 3, 2007 Thanks for the reply, ill look it up. Dose this one use the stock rear tire can't tell in the pics. Link to comment Share on other sites More sharing options...
silvercrew Posted April 3, 2007 Share #40 Posted April 3, 2007 You did a awesome job, it looks like it rolled off of the showroom floor. Link to comment Share on other sites More sharing options...
chabicheka Posted April 4, 2007 Share #41 Posted April 4, 2007 great job!!! where did you get the kit? my son has a bike like this one and are woundering where you got the kit. here's their webste http://triwing.com/ Link to comment Share on other sites More sharing options...
Guest Katydid Posted April 5, 2007 Share #42 Posted April 5, 2007 My heart is pounding!!! WOW. How much does it weigh finished? How do you back it up? I am gonna have to have one now that I've seen ures!! Link to comment Share on other sites More sharing options...
Jerry M Posted April 7, 2007 Author Share #43 Posted April 7, 2007 I would say about 1000 pounds,It rolls very easy and I don't have to balance it while trying to back it up.It is about 10 feet long and 56' wide so you need to be aware of the size when in a parking lot or going to the drive through at the bank or getting gas,you could loose a fender. Link to comment Share on other sites More sharing options...
