Freebird, Marcarl and/or to anyone else who can help with this... Couple months ago, before heading out on our emergency call to go see our new grandson,,, I ripped Tweeksis apart to install a new U-Joint.. Not wanting to pay the big $$ to Mom Yam, I ordered off the cross reference found here: https://www.venturerider.org/forum/showthread.php?6238-U-Joint-Cross-Reference
I could not find a supplier of the TRW 20128 (Datsun?) so I went with the Spicer 5-1500x,, that one came in and had no lock ring grooves but had the top clips = my 1st Gens have to use the lower clips = reordered the Moog (Precision) 392. I knew the 392's were greasable thru the caps but figured I would grease it - pull the zerk and plug the hole if I had to.
Found out that the 392's and the 5-1500x (I see Spicer does make the 5-1500 with lower clips,, looks like I just got the top clipped ones by chance) are lower clip groove ground at 1.496 inches of yoke space (see "G1" on spec sheet found here: https://www.northerndrivetrain.com/product/SPI-5-1500X.html ).. 1.496 inch = 38mm and our/my 1st Gen yokes require 40mm clip to clip space.. I ended up shimming out to 40mm with washers on top of the cap journals to make the 392 work (took my calipers down to ACE hardware and purchased 4 - 1mm thick x 10mm in diameter stainless flat washers @10 cents each and used them as shims inside of the caps and on top of the journals).. Thankfully the cap diameters on both the 5-1500's and the 392's do spec exactly the same as the OEM! I have replaced many U-Joints thru the years and the "feel" of the finished product was good after pressing in the caps with the vice and have now got a few miles on Tweeks with this make shift u-joint in place.. The 392 was an 8 dollar part shipped to my door and, being a person who LOVES the challenge of making things work that normally would not work - I would do it all again the same way I did BUT = it might not be a bad idea for the clubs sake to have some form of a disclaimer placed in that tech article so if one of these lop eared varmints gets stranded and needs a quick fix,,, they will know what they are up against..
I know Don,, I am a royal pain in the neck and I hated to post this and cause ya more work but,, you know me :missingtooth:
Not sure how this all fits into the MK2 or the RSV's...... That knowledge will have to come from someone wayyyyyy more smarter than I :mugshot:.. Was just wondering if another update to that cross reference would not be wise?
Puc
Edited by cowpuc
  Marcarl said:
ALl done bro. Just added your paragraph to the original thread.
Thanks Carl,,, a finer lop eared brother of a Canuckian Moderator varmint I have never met!!:big-grin-emoticon:
Looking up 1973 Nissan B110 on Rock Auto (They put all the Datsun years under Nissan) here (screenshot) are all the part numbers of U-joints they carry. Rock Auto does not carry the TRW part number. As a rule if Rock Auto doesn't carry it, its likely not being made by that supplier anymore. TRW may be gone as a brand by now?? not sure. If you hit the info button, more specs available for each part. Link: https://www.rockauto.com/en/catalog/nissan,1973,b110,1.2l+l4,1428,drivetrain,universal+joint,2392
Edit: Apparently did not like me copy and pasting the screenshot into the body of the thread, looked ok in preview though.......Screenshot_2018-10-06 1973 NISSAN B110 1 2L L4 Universal Joint RockAuto.jpg
In my line of work we deal a lot with a variety of PTO shafts and makeshift drive lines often fabricating from scratch . To source U-joints we go by dimensions and configurations. Here is a sample of how we go about it. see the following attachments.
https://spicerparts.com/resources/measuring-u-joints
after you click on the link select the style of joint you need (not the smokable type :no-no-no: ) and it will bring up a list of sizes in that configuration.
Once we know what we are after we just order the part, usually through a custom drive line/PTO fabricating shop.
Edited by saddlebum
An alternative to sourcing U-joint components for the XVZ12/XVZ13 (ALL XVZ as well as most Yamaha shaft drive vehicles):
Spider: 2HR-46187-00
Bearing cups: 93399-99926-00
Circlips: 93440-20088-00
This entire assembly is available from several non-Yamaha sources.
Usually listed for ATVs. Do a search for 2HR-46187-00. Kimpex part number158267. Sells for $20 or less.
For instance:
https://www.mfgsupply.com/atv/atvsusp/atvsuspyam/atvsuspyamujoints/19-1003-ref4-atv-rear-drive-shaft-engine-side-u-joint.html
http://iowamotorparts.com/yamaha_atv_u-joints.htm
https://www.kimpex.com/en-us/products/atv/suspensions-and-parts/universal-joints/kimpex-yamaha-u-joint
