Davin Posted July 10, 2017 Posted July 10, 2017 Going for a ride on Thursday to pick up a 98 RSTD. Riding up with my brother on the RSV and we will ride a bike each on the way home. I was looking at buying either a Buell, a Roadliner or another Royal Star. Just wanted soemthing a little lighter than the RSV for a town bike. Stumbled across a 98 RSTD for $2800 US which is $3800 AU. I love the RSV so much I couldnt pass up another of these V4's at that price. Comes with the standard windshield and the baggershield in the pics. Thursday can't come quick enough. Sent from my SM-G930F using Tapatalk
RandyR Posted July 10, 2017 Posted July 10, 2017 Looks like a clean well kept '98. congrats on your find.
Condor Posted July 10, 2017 Posted July 10, 2017 Nice find, but I gotta warn ya. Put two V4's together and they have a tendency to reproduce....
BlueSky Posted July 10, 2017 Posted July 10, 2017 You are probably aware that the RSTD V4 has about 75hp instead of the 98hp in the Venture.
Sylvester Posted July 10, 2017 Posted July 10, 2017 You are probably aware that the RSTD V4 has about 75hp instead of the 98hp in the Venture. Yep but that can be corrected.
Davin Posted July 10, 2017 Author Posted July 10, 2017 You are probably aware that the RSTD V4 has about 75hp instead of the 98hp in the Venture. Yeah I know they have less power. This one's going to be a daily ride to work type bike. My ride to work is short which has been putting pointless miles on the venture. Sent from my SM-G930F using Tapatalk
Chaharly Posted December 12, 2017 Posted December 12, 2017 How is that? Weren't the rubber tubes that hold the carbs on the motor smaller in diameter? So you'd put ones on from a 99 or newer, probably modify that airbox, and maybe jet the carbs? Just my guess
BlueSky Posted December 12, 2017 Posted December 12, 2017 The RSTD (before 2005) carbs are 28mm vs 32mm for the Venture. There may be other differences such as cams but I do not know.
Davin Posted December 17, 2017 Author Posted December 17, 2017 Weren't the rubber tubes that hold the carbs on the motor smaller in diameter? So you'd put ones on from a 99 or newer, probably modify that airbox, and maybe jet the carbs? Just my guessThe frames on a 96-01 RS RSTC and RSTD are different to the frames on a 99-13 RSV -RSTD. This is to accommodate different air box systems, handlebar mounted instruments, dog bone upper cylinder braces and the larger carbs. Retrofitting larger carbs to a 96-01 wouldn't be easy or cheap Sent from my SM-G930F using Tapatalk
Davin Posted December 17, 2017 Author Posted December 17, 2017 Current pics of the 98RSTD I picked up. Sent from my SM-G930F using Tapatalk
Chaharly Posted December 17, 2017 Posted December 17, 2017 Current pics of the 98RSTD I picked up. https://uploads.tapatalk-cdn.com/20171217/1a86108689459145d79dcbc67435711b.jpghttps://uploads.tapatalk-cdn.com/20171217/4625bbf22f0d5115f377a98a1a96af61.jpghttps://uploads.tapatalk-cdn.com/20171217/8939f687e8288df31fccb9a9b805c774.jpghttps://uploads.tapatalk-cdn.com/20171217/bbe9ccddf45fbc674eaaea80b3a4c1f3.jpghttps://uploads.tapatalk-cdn.com/20171217/b4d8b7a8cf64552cab679a0defa7b860.jpghttps://uploads.tapatalk-cdn.com/20171217/90cb3597cdd399583e572e1d3f4b709b.jpghttps://uploads.tapatalk-cdn.com/20171217/07196fe0ce297d624ec390ba7e520373.jpghttps://uploads.tapatalk-cdn.com/20171217/a9ad0e23a7770d4a56dfeca4f34439df.jpghttps://uploads.tapatalk-cdn.com/20171217/09ea08b79b4ec29eaae54b56816471a6.jpg Sent from my SM-G930F using Tapatalk I really like the front wheel setup on your 99 as well
slowrollwv Posted December 17, 2017 Posted December 17, 2017 The frames aren't that much different. I know a few that have changed motors from one to the other.
Davin Posted December 17, 2017 Author Posted December 17, 2017 I really like the front wheel setup on your 99 as wellThat roadliner wheel looks better and improves handling. I love it. The brakes are better too, only thing that changed was the roadliner rotors but the brakes grab a lot better. Sent from my SM-G930F using Tapatalk
