garyS-NJ Posted September 2, 2016 Posted September 2, 2016 Working on an '86 and found the carbs were reassembled minus a one of the brackets that hold the carb sets together Sent from my VS987 using Tapatalk
garyS-NJ Posted September 2, 2016 Author Posted September 2, 2016 Whoops, that posted before I finished... Not the larger brackets that hold the left and right carb sets together but rather the smaller brackets that hold the front carbs to rear.... Seems I can't post a picture here from my gazillion dollar phone. I'm also missing the tiny circlips that hold. The choke rod in the linkage (linking left side to right side choke). And one of those tiny white plastic choke rod bushings is damaged.. These parts are not even shown in the boats.net exploded assembly diagram so I doubt I could get them from the stealer. Any other sources/ideas. I'm guessing the circlips are standard hardware... Sent from my VS987 using Tapatalk
garyS-NJ Posted September 2, 2016 Author Posted September 2, 2016 Whoops, that posted before I finished... Not the larger brackets that hold the left and right carb sets together but rather the smaller brackets that hold the front carbs to rear.... Seems I can't post a picture here from my gazillion dollar phone. I'm also missing the tiny circlips that hold. The choke rod in the linkage (linking left side to right side choke). And one of those tiny white plastic choke rod bushings is damaged.. These parts are not even shown in the boats.net exploded assembly diagram so I doubt I could get them from the stealer. Any other sources/ideas. I'm guessing the circlips are standard hardware... Sent from my VS987 using Tapatalk http://uploads.tapatalk-cdn.com/20160902/2278e588ddb074842aac1647c3035380.jpg Working on an '86 and found the carbs were reassembled minus a one of the brackets that hold the carb sets together Sent from my VS987 using Tapatalk Sent from my VS987 using Tapatalk
luvmy40 Posted September 2, 2016 Posted September 2, 2016 Check with your local R/C hobby shop for the small e clips and bushings. I picked up a variety pack of clips from one for $3.00 and it had clips for the enricher circuit linkage. That top bracket should be easy to fabricate.
garyS-NJ Posted September 3, 2016 Author Posted September 3, 2016 Awesome idea hobby shop. I need one bracket. Thought about fabbing it but I'm not getting paid for this job.. Sent from my VS987 using Tapatalk
Condor Posted September 3, 2016 Posted September 3, 2016 Awesome idea hobby shop. I need one bracket. Thought about fabbing it but I'm not getting paid for this job.. Sent from my VS987 using Tapatalk I had some but they were in Mr. Z's garage when it went up in smoke...
yamagrl Posted September 4, 2016 Posted September 4, 2016 Awesome idea hobby shop. I need one bracket. Thought about fabbing it but I'm not getting paid for this job.. Sent from my VS987 using Tapatalk Since it's your bike just write yourself a check. That oughta fix that not gettin paid problem!
garyS-NJ Posted September 4, 2016 Author Posted September 4, 2016 Its not my bike. Not even a friends. In working for rent Sent from my VS987 using Tapatalk
luvmy40 Posted September 5, 2016 Posted September 5, 2016 I'm not sure how close the carb set up is between the '83 and the '86 models but it just occurred to me that, on my carb bank the bracket you are missing is not the same as the one in place. It incorporates a spring retainer for the throttle linkage and has a cut out for the push-pull throttle cable. It may not be that easy to fabricate.
KIC Posted September 5, 2016 Posted September 5, 2016 Gary, If you an post a picture of the exact parts you need and are missing, I can look to see if I have them in my box from when I took my 87 carbs apart. I can look tomorrow if I know what I am looking for, but I leave for a week on Tuesday and wont be able to do anything until after I return. May you can look at other threads that show carb rebuild etc and copy a picture. Using Paint on your computer you can circle the needed part.
yamagrl Posted September 5, 2016 Posted September 5, 2016 http://uploads.tapatalk-cdn.com/20160902/2278e588ddb074842aac1647c3035380.jpg Sent from my VS987 using Tapatalk I think this is what you need. http://www.ebay.com/itm/89-Yamaha-XVZ1300-XVZ-13-1300-Venture-choke-cable-cabel-bracket-carb-carburetor-/311621467205?hash=item488e163c45:m:mP7olVkzNGq45M-ogfMXQkQ&vxp=mtr
snyper316 Posted September 5, 2016 Posted September 5, 2016 I can't believe I missed that plate it the pusher Sent from my TBQG774 using Tapatalk
garyS-NJ Posted September 5, 2016 Author Posted September 5, 2016 Thanks but I don't need the cable holders, I need one of the flat rectangular plates. Sent from my VS987 using Tapatalk
yamagrl Posted September 5, 2016 Posted September 5, 2016 Thanks but I don't need the cable holders, I need one of the flat rectangular plates. Sent from my VS987 using Tapatalk That is the bracket for the left side. There is only one rectangular bracket and it goes on the left bank.
garyS-NJ Posted September 5, 2016 Author Posted September 5, 2016 Holy smokes, are you sure? Seemed those flat brackets would hold each two carb bank (fore to aft) together and then the side brackets hold the left bank to the right. Parts fische on boats.com doesn't show the plates at all. Sent from my VS987 using Tapatalk
yamagrl Posted September 5, 2016 Posted September 5, 2016 Holy smokes, are you sure? Seemed those flat brackets would hold each two carb bank (fore to aft) together and then the side brackets hold the left bank to the right. Parts fische on boats.com doesn't show the plates at all. Sent from my VS987 using Tapatalk Yep. The right bank has a simple rectangular bracket but left side bracket not only racks #2 to #1 but also provides cable guide.
Prairiehammer Posted September 6, 2016 Posted September 6, 2016 (edited) Yamagrl is correct. Here's a clearer picture of 1983 cabs showing that bracket. And a picture of 1991 carbs shot from a lower angle, showing that bracket in a semi-profile. It is not a simple plate as the right side is. Here is another shot of that bracket. It serves a throttle cable holder as well as joining the carbs. This is from a VMX12. Same as XVZ13/12. Edited September 6, 2016 by Prairiehammer
cimmer Posted September 8, 2016 Posted September 8, 2016 There are parts on ebay as of now. http://www.ebay.com/itm/Yamaha-Venture-XVZ-1200-Off-1983-XVZ1200-carburetor-mikuni-mount-rails-/351456907325?hash=item51d476d03d:g:icwAAOSwHnFVqBIA&vxp=mtr Rick F.
Prairiehammer Posted September 8, 2016 Posted September 8, 2016 There are parts on ebay as of now. http://www.ebay.com/itm/Yamaha-Venture-XVZ-1200-Off-1983-XVZ1200-carburetor-mikuni-mount-rails-/351456907325?hash=item51d476d03d:g:icwAAOSwHnFVqBIA&vxp=mtr Rick F. But not the one Gary needs.
yamagrl Posted September 8, 2016 Posted September 8, 2016 This one is still available http://www.ebay.com/itm/89-Yamaha-XVZ1300-XVZ-13-1300-Venture-choke-cable-cabel-bracket-carb-carburetor-/311621467205?hash=item488e163c45:m:mP7olVkzNGq45M-ogfMXQkQ&vxp=mtr&rmvSB=true
yamagrl Posted September 9, 2016 Posted September 9, 2016 Nice, listed as a choke cable bracket! This one is still available http://www.ebay.com/itm/89-Yamaha-XVZ1300-XVZ-13-1300-Venture-choke-cable-cabel-bracket-carb-carburetor-/311621467205?hash=item488e163c45:m:mP7olVkzNGq45M-ogfMXQkQ&vxp=mtr&rmvSB=true The price has been lowered. I think I might buy it and put it up for sale on this site for like maybe 50 bucks. Do you know anybody that might need one?
Prairiehammer Posted September 9, 2016 Posted September 9, 2016 This one is still available http://www.ebay.com/itm/89-Yamaha-XVZ1300-XVZ-13-1300-Venture-choke-cable-cabel-bracket-carb-carburetor-/311621467205?hash=item488e163c45:m:mP7olVkzNGq45M-ogfMXQkQ&vxp=mtr&rmvSB=true @garyS-NJ you better snap this up.
