dharnie Posted February 2, 2008 Share #1 Posted February 2, 2008 Anyone have a trunk light and if so can you please comment as to what you have and maybe post a pic or 2? Link to comment Share on other sites More sharing options...
Guest BluesLover Posted February 2, 2008 Share #2 Posted February 2, 2008 If you mean a light to illuminate the inside of the trunk, then this is what I use: http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/Products/Dotitlights/ I picked a couple up at my local h/w store for under $10. Cheers, Link to comment Share on other sites More sharing options...
big_mike Posted February 2, 2008 Share #3 Posted February 2, 2008 what a great idea i'm going to try one also i've been looking at adding a light in the trunk how is the elumination? Link to comment Share on other sites More sharing options...
KeithR Posted February 2, 2008 Share #4 Posted February 2, 2008 Some of those clip on book lites are not bad either. Keith Link to comment Share on other sites More sharing options...
Guest BluesLover Posted February 2, 2008 Share #5 Posted February 2, 2008 how is the elumination?It does the trick for me. I found that one was actually good enough. Cheers, Link to comment Share on other sites More sharing options...
big_mike Posted February 2, 2008 Share #6 Posted February 2, 2008 great thanks i'm gona try one or two Link to comment Share on other sites More sharing options...
Thom Posted February 2, 2008 Share #7 Posted February 2, 2008 you 2nd geners don't even have a trunk lite ? or are you talking the the side bags ? do you have a built in mirror for the Nav. ? Link to comment Share on other sites More sharing options...
Condor Posted February 3, 2008 Share #8 Posted February 3, 2008 1stGen Mark II Royales come stock with a nifty trunk light and vanity mirror combination. They can sometimes be found on Ebay. They're run thru a contact switch, but I bet they can be modified to actuate with something like a mercury switch. To my knowledge mercury switches aren't being made any longer because of EPA regs, but there has to be a substitute. Link to comment Share on other sites More sharing options...
Squidley Posted February 3, 2008 Share #9 Posted February 3, 2008 I had what Blues lover has on my '99. It worked great, but I would get the thicker 3M 2 sided tape as it will need it for the curve of the trunk lid Link to comment Share on other sites More sharing options...
Guest Rae Kelly Posted February 3, 2008 Share #10 Posted February 3, 2008 I like your tires. What brand and size are they? Your bike looks great - congradulations. Rae Link to comment Share on other sites More sharing options...
spear Posted February 3, 2008 Share #11 Posted February 3, 2008 If you mean a light to illuminate the inside of the trunk, then this is what I use: http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/Products/Dotitlights/ I picked a couple up at my local h/w store for under $10. Cheers, I have 3 of these lights, given to me by my daughter last birthday. I contemplated putting 1 on the underside of my top-box lid but decided not to, as there is always a strong possibility of something inside the box turning it on by bumping it, or indeed having the box loaded to the top and closing the lid down also activating it. A chance of flattening the batteries or maybe the heat (if there's any from the LEDs) doing some damage to something within. You also have to remember that once you attach these lights with the double-sided tape you cannot replace the batteries without pulling the unit away and ruining the tape. I suppose you could apply more tape - but as you've probably guessed by my input IT'S JUST SEEMS LIKE TOO MUCH TROUBLE! Link to comment Share on other sites More sharing options...
dray Posted February 3, 2008 Share #12 Posted February 3, 2008 its just a thought but under the hood of your old chevy trucks there is a small light with a cord on a spool you could use in the trunk or pull it all the way up to the front tire if needed its only about 3x4x2 it would make a great light for emergences to Link to comment Share on other sites More sharing options...
2WHEELSFORME Posted February 3, 2008 Share #13 Posted February 3, 2008 I used two tag lights from an Auto Parts place, chrome and tough. Easy to wire from a fused line to the battery and thru a switch inside the trunk. LEDs won't run the battery down even if you leave it on overnight. Link to comment Share on other sites More sharing options...
Crash Posted February 3, 2008 Share #14 Posted February 3, 2008 I've got what Blueslover has too, great little lights! Link to comment Share on other sites More sharing options...
SteveP Posted February 4, 2008 Share #15 Posted February 4, 2008 Another thumbs up for the mini stick-on lights. A word of advice: be sure to mount it in the exact center if you plan on putting two helmets in the trunk... if it's off to the side, it'll hit the top of the helmet and (1) turn the light on and (2) possibly scratch the helmet. Other than that-- it throws plenty of light, I can twist it off the base to change batteries & LEDs don't generate enough heat to damage anything if it happens to get left on. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted February 4, 2008 Share #16 Posted February 4, 2008 I keep a small LED flashlite in the trunk...anyone think of that? You can use it for looking around in the saddlebags at nite, digging thru all the accumulated junk in the trunk, shine it in that stupid little oil sight glass to check the oil...hand it to a friend whos lost his keys at nite, illuminate the tire when you have to change it on the road...hang it by the wrist-strap from the throttle while you overhaul the motor at 3:30 am on a Monday morning on Route 3...you get the idea. 2nd gens are manly mens bikes...we dont need no stinkin make-up mirror and trunklite! Link to comment Share on other sites More sharing options...
Condor Posted February 4, 2008 Share #17 Posted February 4, 2008 2nd gens are manly mens bikes...we dont need no stinkin make-up mirror and trunklite! Tell that to the navigator..... Link to comment Share on other sites More sharing options...
big_mike Posted February 4, 2008 Share #18 Posted February 4, 2008 wait a minute who said anything about a make-up mirror the older i get the more light i need and the less i worry about make-up, {did that come out right} well you know what i wean.:rotf::rotf: Link to comment Share on other sites More sharing options...
dharnie Posted February 5, 2008 Author Share #19 Posted February 5, 2008 I got a sylvania dot-it at parts store. It would not stick onto lid. So I used a piece of industrial strength velcro and also was able to stick the light onto the lid where it curves where it closes over the latch mechanism on the bottom part thus avoiding any objects that would be put into the trunk! Link to comment Share on other sites More sharing options...
Christo Posted February 6, 2008 Share #20 Posted February 6, 2008 If you mean a light to illuminate the inside of the trunk, then this is what I use: http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/Products/Dotitlights/ I picked a couple up at my local h/w store for under $10. Cheers, Ditto - best bang for the buck. I have them in all the bags on the bike. Link to comment Share on other sites More sharing options...
sleadhed Posted February 6, 2008 Share #21 Posted February 6, 2008 I've got a 3 led crank up flash light. $6.99 on sale at wally world. I've had it for 3 years and haven't had to replace the batteries yet:rotf::rotf: Link to comment Share on other sites More sharing options...
