Michael_Bishop Posted May 3, 2011 Share #1 Posted May 3, 2011 Carbon One your lift adpter works great. I tried it out today. That not me in the picture. It's a neighbor. Link to comment Share on other sites More sharing options...
SilvrT Posted May 3, 2011 Share #2 Posted May 3, 2011 What .... is that Carbon One holdin yer bike up?? I don't see no "lift adapter" .... [ATTACH]56295[/ATTACH] Link to comment Share on other sites More sharing options...
Phoneman1981 Posted May 3, 2011 Share #3 Posted May 3, 2011 Hello: Dang, now I may have to get one also!!!!! Thanks for posting... Link to comment Share on other sites More sharing options...
bongobobny Posted May 3, 2011 Share #4 Posted May 3, 2011 Believe it or not, I'm thinking of one for the trike!! Larry be da man!! Link to comment Share on other sites More sharing options...
uechi kid Posted May 3, 2011 Share #5 Posted May 3, 2011 I use mine all the time. Now if I can just get something like it for my Kawasaki Mean Streak. Link to comment Share on other sites More sharing options...
RedRider Posted May 3, 2011 Share #6 Posted May 3, 2011 If, I mean, when you get one, I recommend getting the model with the legs. Makes it VERY steady and you can pull the jack out of the way. Spring for the couple extra bucks and you won't regret it. RR Link to comment Share on other sites More sharing options...
Guest scarylarry Posted May 3, 2011 Share #7 Posted May 3, 2011 If, I mean, when you get one, I recommend getting the model with the legs. Makes it VERY steady and you can pull the jack out of the way. Spring for the couple extra bucks and you won't regret it. I agree also helps the tires when put it way for the winter Link to comment Share on other sites More sharing options...
SilvrT Posted May 3, 2011 Share #8 Posted May 3, 2011 I agree also helps the tires when put it way for the winter That's where mine sits all winter .... in fact, all FALL, WINTER, and most of SPRING (frikkin weather!!) Link to comment Share on other sites More sharing options...
Carbon_One Posted May 4, 2011 Share #9 Posted May 4, 2011 Believe it or not, I'm thinking of one for the trike!! Larry be da man!! Bob I've done some researching on doing an adapter for the trikes. For the Tri-Wings it was no problem but for the Hannigan trike that was a different game all together. I just haven't figured out a way to build a lift adapter for them. One problem is they sit a lot lower to the ground thus making it harder to get under the bike with an adapter plus a jack. That alone requires one to drive up on boads or whatever. Then the framing in the rear presents a lot of problems too. Anyhow I haven't given totally up just yet. On my trike the balance point has shifted a good 12" to the rear. Larry Link to comment Share on other sites More sharing options...
Godlover Posted May 5, 2011 Share #10 Posted May 5, 2011 Got mine today! I had one when I had my 2000 and knew it would be one of my first purchases when I bought my TD! Thanks Larry! Link to comment Share on other sites More sharing options...
Skid Posted May 5, 2011 Share #11 Posted May 5, 2011 Carbon One's Lift Adapter with legs....I love it. Link to comment Share on other sites More sharing options...
