ken Posted December 12, 2010 Posted December 12, 2010 It seems milwaukee tool has come out with a battery powered heated jacket. Has anyone here tried it yet? http://www.tools-plus.com/milwaukee-2330.html
RandyR Posted September 12, 2011 Posted September 12, 2011 (edited) I was about to post that Home Depot has these on sale, but the above link has a better price. Has anyone adapted the Milwaukee jackets to run off motorcycle power? they are 12volt, so it should be doable? Or has anyone used one with the 12v battery pack that is used in common with power tools? A heated jacket for $110 sounds like a fair price. attached is a pic of the jackets 12v connection, looks like a cord with a 12v plug of some kind to the battery pack. should be easy to make a mate for it to run off a motorcycle. $152 with battery and charger on Amazon.com [ame=http://www.amazon.com/gp/product/B0048EJXK2]Amazon.com: Milwaukee 2331-XL M12 12-Volt X-Large Heated Jacket Set: Home Improvement@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41Iz9qJ9KGL.@@AMEPARAM@@41Iz9qJ9KGL[/ame] Edited September 12, 2011 by RandyR
Flyinfool Posted September 12, 2011 Posted September 12, 2011 What I have figured out so far. The battery is a 1400mAh. They claim 6 hours of heat from a charge. I am going to assume that this time would be on the low setting. After a little quick math that means that the jacket is drawing about 1/4 amp @ 12V. If my assumption is correct then it is most likely 1/2 amp at medium heat and 3/4 amp at full heat. Well withing the electrical capacity of our anemic electrical systems. the wattage of the jacket seems to 3, 6 or 9 watts. That is about the same amount of heat as one of the old fashion large Xmas tree bulbs. That does not sound like a lot of heat to me. Does anyone know the power of a heated jacket that is made for bikes? As far as performance, there is about a 6 inch square patch in the center of the back and two more 6 inch square patches behind the two chest pockets. these are the only areas that are heated. I have never owned a heated garment of any kind. is it normal and effective to only have a few patches of heat?
darthandy Posted September 12, 2011 Posted September 12, 2011 When I was looking for heated clothing last year (It does get a wee bit cool in the Fall hereabouts!) I checked the ratings for some gloves, socks and vests. Those with battery power always had the absolute lowest ratings for any use other than hiking ... when your own body generates a fair amount of heat anyway...you just need well insulated clothing. I would be very suspicious of a battery heated jacket...it just doesn't seem likely that the amount of heat generated would be of much use...especially after checking out Flyin"s figures. Andy
uechi kid Posted September 12, 2011 Posted September 12, 2011 When I hooked up my wife Gerbing jacket an gloves last year that combination required a 10 amp fuse, if that helps.
Gary N. Posted September 12, 2011 Posted September 12, 2011 I've been running two Gerbings heated jackets with heat controllers for a couple of years and haven't had a problem. They have full coverage heat from wrist to neck and full body front and back. Plug and play with no battery to go dead. Not cheap, but you usually get what you pay for.
Mobile Posted September 13, 2011 Posted September 13, 2011 Hi,up here in Winnipeg MB. I've been able to extend my riding season and be much more comfortable with my Grebings electric jacket and jacket liner, when its not to cold I use the jacket its light weight, but as it gets colder I use the jacket liner under my leather jacket or under a riding jacket I bought these for my wife and myself in 1995 and they work very well, they consume 77watts, but with the heat troller the heat can pulsate rather than being at a consistant temp.Our weather from now till the winter sets in can be very cold but if you have the right clothing the riding can be quite invigorating ! > mobile
saddlebum Posted September 13, 2011 Posted September 13, 2011 If you need a heated jacket while working you can't possibly working hard enough.
waterbug Posted September 13, 2011 Posted September 13, 2011 I have a battery powered vest that works great but on hi you get about 3to4 hours out of it so a extra battery would be best! It helps take the chill out. I think they are blaze and they make a few things if you google them. I have heated gloves and the are the best! Only bad thing is my thumb will get very cold when I'm riding in30 degree weather as it doesn't seem to have much heat in it.
micdin2083 Posted July 27, 2017 Posted July 27, 2017 Milwaukee TV205494 Black X-Large M12 Heated Jacket is best jacket among all jackets I have used. It can be used for 6 hours with one time battery charge. The outer layer of jacket is water and wind resistant. If someone want to know more about this jacket then check below link: heated jacket reviews
uncledj Posted July 27, 2017 Posted July 27, 2017 I have one of the Milwaukee heated jackets and must say they work quite well. I never did the math on how much heat they put out, but will say that even when it's pretty cold out, the "Hi" setting is usually too warm unless I'm wearing a heavy sweater underneath. The sweater puts a layer of insulation between me and the jacket. It comes in handy as I've a bit over 2 mile walk. through the woods. to my stand, and the jacket allows me to dress light so I don't sweat on the way in, then turn on the heat when I've been sitting a while and start to get cold. I think 6 hrs is a stretch on the time it'll heat on a battery pack though. I keep 2 or 3 extra packs for a day in the deer stand and usually end up changing to the second pack halfway through the day. Haven't needed to put a 3rd in. All in all, ...for the money, I'd give them a high rating. Hope this helps.
Sylvester Posted July 28, 2017 Posted July 28, 2017 I have the DeWalt heated jacket and it is great, but now I heard that DeWalt has a 60 volt battery pack and it extends the run time of the 20 volt pack.
