craigatcsi Posted September 7, 2010 Posted September 7, 2010 (edited) I am ready for new tires on my 07 Venture. I have decided to give Wide Whitewalls a try. - The wider the better. I currently have Avon Venoms and are very happy with them, but Avon doesn't make them in WWs Do any of you have a suggestion as to which WWs to go with? I also read somewhere on here about going with a narrower front tire for improved slow speed handling. So that is a possibility also. Craigr Edited September 7, 2010 by craigatcsi Title
pegscraper Posted September 7, 2010 Posted September 7, 2010 When did Avon quit making Venoms with WWs? I have them.
bongobobny Posted September 7, 2010 Posted September 7, 2010 Dunlop D404's and Continental both make WSWs...
Eck Posted September 7, 2010 Posted September 7, 2010 The diameter of the stock size 150/80HB-16 and the smaller width size, MT90-16, both have a diameter of 25.100" http://www.venturerider.org/forum/showthread.php?t=86&highlight=wide+white+wall+tires MT90HB-16 on the front. This tire is 1" narrower than stock, but the same diameter. bike sits exactly the same height front and rear. MT90HB-16 (or 130/90-16) Front Avon Venom-X AM41 MT90B16 74H Rear Avon Venom-X AM42 150/90B15 80H (All AM41s are front tires, and AM42s are rear tires.) 150/90HB15 rear: Tires Unlimited is showing it available, as part #T2848922, $142.68. The actual Avon website does show a 150/90B15 WW ^80H (http://www.swmototires.com/ Dunlop D404 150/80HB-16 Wide Whitewall Front $98.95 Dunlop D404 150/90HB-15 Wide White Wall Rear $92.95
FutureVentures Posted September 7, 2010 Posted September 7, 2010 I have the WWW Maxxis Classics on mine and really like em. They're purdy and ride realllll nice. Then, get yourself some Westleys Bleache White to keep em nice n white, nothing else works as well. http://www.westleys.com/
StarFan Posted September 7, 2010 Posted September 7, 2010 I have Dunlop 404´s white walls on mine and like them very much. Have ridden around 6.000 miles and have a little more than 50% left. They will at least go 10.000 miles. Great handling and I keep them at 36 pounds. The whitewalls are easy to keep clean and still look like new.
cokyodi Posted September 7, 2010 Posted September 7, 2010 Just put some white Walls from venom on my bike. They make them. A close second was the continental, have not heard much about them but they look well made.
bj66 Posted September 7, 2010 Posted September 7, 2010 (edited) I run the 404's, and like em. I have about 5000 miles on em so far, and so far so good. As far as cleaning them I read on here to try the origional goop hand cleaner. It works good, just wipe it on with a paper towel, dont even have to scrub real hard. Rinse it off with a hose. Just keep it on the sidewalls only. Not on any of the surface that contacts the road. Edited September 7, 2010 by bj66
jburrell Posted September 7, 2010 Posted September 7, 2010 I have the Dunlop 404 WWW tires and have not had any issues and have gone 6k miles so far. I also went to the narrower tire and love it. I will never go back to stock size on the front. The bike rides a lot "lighter" with the narrower front tire, handling at slow speeds is greatly improved and althought others complain about high speed issues I have not seen any issues on the highway due to the new size. Now about cleaning these things. I have tried all the cleaners and a "SOS" pad is the best at cleaning them. I have tried Tire Bright and all the others and some work well but SOS gets em really clean. OF course you gotta get close to the tire to scrub it. I have been unable to find anyting that helps keep the brake dust off the whitewalls so far. I have tried 2 or 3 off the shelf items and finally gave up and just accepted the fact that I will have to clean the tires regularly. my
BradT Posted September 8, 2010 Posted September 8, 2010 "SOS" pad is the best at cleaning them. Dunlop 404's WWW for me. They work and do not normally have any problems. Brad
craigatcsi Posted September 8, 2010 Author Posted September 8, 2010 I have the Dunlop 404 WWW tires and have not had any issues and have gone 6k miles so far. I also went to the narrower tire and love it. I will never go back to stock size on the front. The bike rides a lot "lighter" with the narrower front tire, handling at slow speeds is greatly improved and althought others complain about high speed issues I have not seen any issues on the highway due to the new size. Now about cleaning these things. I have tried all the cleaners and a "SOS" pad is the best at cleaning them. I have tried Tire Bright and all the others and some work well but SOS gets em really clean. OF course you gotta get close to the tire to scrub it. I have been unable to find anyting that helps keep the brake dust off the whitewalls so far. I have tried 2 or 3 off the shelf items and finally gave up and just accepted the fact that I will have to clean the tires regularly. my Which sizes do you run then? craigr
