dingy Posted September 6, 2009 Share #1 Posted September 6, 2009 (edited) Gear position Indicator upgradefor standard Ventures (Non-Royales) I have installed a gear position indicating system on my 1983 Venture. This is the stock model without the dash readout from the factory. This is the second Venture I have owned. The first one was a 1984 Royale. Two of the things I really miss from that bike were the gear indicator and the cruise control. The cruise control is coming later. I have all of the stock parts now needed to install it. I obtained a Neutral Switch Assembly from a 1984 Venture Royal through an Ebay auction for under $10.00. This assembly will exchange with the stock neutral switch assembly from a standard Venture. The neutral switch assembly is located between the back end of the stator cover and the front of the middle drive. It sets back in about four inches and is difficult to see, but is accessible. Removal of the middle drive cover is needed to access. To indicate what gear the bike is in I mounted three LED lights in the gauge cluster above the volt gauge. The left light is lit it indicates 1st gear. The left light and the center lights lit indicate 2nd gear. The center light lit indicates 3rd gear. The center light and right lights lit indicate 4th gear. The right light lit indicates 5th gear. The neutral light works as normal. In neutral none of the LED’s are lit. I could also use five LED’s, using one for each gear, but I like the 3 light system as it is easy to see and once familiar with the pattern, it is very easy to determine what gear I am in with a quick glance down at the gauges. I initially used a red, green and amber LED’s but the green and amber had poor visibility in the daytime. I replaced with all red ones. I also painted the part of the LED’s that are inside of the cluster with black paint to keep the light from the instrument cluster from bleeding through the LED’s translucent housing. I used four diodes and three LED’s from radio shack for the light logic circuit. Four IN4004 rectifier diodes. Price $.99 for two Three Red LED assemblies. Price $1.99 each The new Neutral Switch Assembly has a six pin plug on the end that sets in the same area that the stator and rectifier plugs are near the fuel pump. I had two spare diode assemblies that I have obtained in the past and used the plug from one of these to mate up with the plug on the Neutral Switch cable. I had to take one extra wire connector from the second diode assy. As the diode assembly plug only used five wires. You do not need to use this connector if you do not want to though. I retained this plug as I will be replacing the wiring harness when I install the cruise control. I put the diodes in the circuit near the plug connections on the end of the neutral switch assy. I then ran three 18 gauge wires up to the instrument cluster. I used a trailer four conductor plug I had to make a connection at the instrument panel. I have attached a PDF file with pictures and a wiring schematic to install this. Edited October 6, 2009 by dingy text correction Link to comment Share on other sites More sharing options...
Ozlander Posted September 6, 2009 Share #2 Posted September 6, 2009 Good job, you do good work. Link to comment Share on other sites More sharing options...
Dano Posted September 6, 2009 Share #3 Posted September 6, 2009 Nice job Dingy! Great work and nice write up. I think this ought to go in the 1st gen tech library, we'll work on Don to get it in there. How about it, Boss? Wanna help us out here? Dano Link to comment Share on other sites More sharing options...
Freebird Posted September 6, 2009 Share #4 Posted September 6, 2009 No problem. Great article and it is now copied to the tech library. Thanks much. Link to comment Share on other sites More sharing options...
Smitty161 Posted September 6, 2009 Share #5 Posted September 6, 2009 Right on!!!!! Thank you, thank you, thank you!!!!! Link to comment Share on other sites More sharing options...
iphlue Posted May 25, 2014 Share #6 Posted May 25, 2014 I'm wanting to do this to my 83. I realize this is an old thread and now it seems the part # 41R-82540-01-00 is obsolete. Can you recommend a source or is ebay my only luck on this one? Link to comment Share on other sites More sharing options...
Neil86 Posted May 25, 2014 Share #7 Posted May 25, 2014 (edited) There is a new one on ebay right now..... http://www.ebay.com/itm/YAMAHA-NUETRAL-SWICTH-ASSEMBLY-PART-41R-82540-01-00-/231234886957?pt=Motorcycles_Parts_Accessories&hash=item35d6ac5d2d&vxp=mtr or try the online places that still show the part available....it might take a few days to find out they can't either.... Edited May 25, 2014 by Neil86 Link to comment Share on other sites More sharing options...
mabeline Posted May 27, 2014 Share #8 Posted May 27, 2014 Would this work on a Second Gen. It would be cool to have a gear indicator. I know it shows 5th and also 4th if you've had the cruise on. It would be easy to hide! Link to comment Share on other sites More sharing options...
dingy Posted May 27, 2014 Author Share #9 Posted May 27, 2014 Would this work on a Second Gen. It would be cool to have a gear indicator. I know it shows 5th and also 4th if you've had the cruise on. It would be easy to hide! Yes. Gary Link to comment Share on other sites More sharing options...
mabeline Posted May 28, 2014 Share #10 Posted May 28, 2014 Thanks Gary A project for the winter, if not sooner!! Link to comment Share on other sites More sharing options...
Michel Posted May 29, 2014 Share #11 Posted May 29, 2014 (edited) On my 1200 I put this system http://img4.hostingpics.net/pics/114490speed.jpg http://img4.hostingpics.net/pics/895676tableau.jpg Edited May 29, 2014 by Michel Link to comment Share on other sites More sharing options...
Neil86 Posted May 29, 2014 Share #12 Posted May 29, 2014 Looks good! Link to comment Share on other sites More sharing options...
rcbailey56 Posted June 9, 2014 Share #13 Posted June 9, 2014 Folks, I never stop being impressed by the ingenuity of the folks on this site. Awesome! Great work Dingy! Link to comment Share on other sites More sharing options...
baylensman Posted June 9, 2014 Share #14 Posted June 9, 2014 HMMMM has me wondering about an IC and LED indicator from good ole radio shack.http://www.learningelectronics.net/vol_6/chpt_7/9.html Link to comment Share on other sites More sharing options...
