Reed Posted May 17, 2009 Share #1 Posted May 17, 2009 Has amy one found a good way to clean the fins on the moter? Any products that you can spray on & wash off that work? or what kind of brush works well? I to have spent a lot of money on things that don't work! "THANKS" Link to comment Share on other sites More sharing options...
Eck Posted May 17, 2009 Share #2 Posted May 17, 2009 I just use the handle of a toothbrush and one of those micro fiber rags.. The flat end section of the toothbrush fits between each fin real nice and the rag cleans it very well. Link to comment Share on other sites More sharing options...
GeorgeS Posted May 17, 2009 Share #3 Posted May 17, 2009 Tried something different this time. I sprayed down the entire carb bank, and engine with a big can of WD-40, let it sit for 30 min. then hit the whole thing again with a mix of 409, and soap, let that sit, Then gave it a water blast with my High Pressure Sprayer. Ahhh its clean now. But be sure to re - lubricate all the carb linkage parts, etc. etc. Link to comment Share on other sites More sharing options...
Road Kill Posted May 18, 2009 Share #4 Posted May 18, 2009 I use Scrubbing Bubbles just spray it on and let it do the work for you. I use it to clean the entire motor section of all my bikes. It sure does make the the crome pop when it dries. Link to comment Share on other sites More sharing options...
hydraulicman Posted May 18, 2009 Share #5 Posted May 18, 2009 I use my Wife, she does a great job. Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 18, 2009 Share #6 Posted May 18, 2009 I hit every puddle I see!!! Link to comment Share on other sites More sharing options...
KiteSquid Posted May 18, 2009 Share #7 Posted May 18, 2009 You mean we have to wash our machines??? Link to comment Share on other sites More sharing options...
Russ Posted May 18, 2009 Share #8 Posted May 18, 2009 The dirt's what's holding it together... Link to comment Share on other sites More sharing options...
wolfman1 Posted May 18, 2009 Share #9 Posted May 18, 2009 The best and fastest cleaner..... Scrubbing Bubbles foaming bathroom cleaner. Spray it on your warm fins and leave it a few minutes, then just rinse it off. Great cleaner and won't harm anything. Been using it for years now. Cheers, Steve Link to comment Share on other sites More sharing options...
MamaMo Posted May 20, 2009 Share #10 Posted May 20, 2009 Can you use Scrubbing bubbles on the whole bike? Plastic too? Never thought about Scrubbing bubbles. Link to comment Share on other sites More sharing options...
pegscraper Posted May 20, 2009 Share #11 Posted May 20, 2009 Well, it is used on plastic toilet seats. I'm not sure I'd want to use it on anything painted though. But I may be trying this on my fins and other engine crevices. Link to comment Share on other sites More sharing options...
Ponch Posted May 20, 2009 Share #12 Posted May 20, 2009 The best and fastest cleaner..... Scrubbing Bubbles foaming bathroom cleaner. Spray it on your warm fins and leave it a few minutes, then just rinse it off. Great cleaner and won't harm anything. Been using it for years now. Cheers, Steve Careful with the scrubbing bubbles on clear coated aluminum parts and polycarbonates. I sprayed mine down one fine day, got an emergency phone call and had to leave the bike for about two hours. When I came back I had streaks on the front forks and wind deflectors that are still there a year later. Link to comment Share on other sites More sharing options...
pegscraper Posted May 20, 2009 Share #13 Posted May 20, 2009 Etched the surface. This is exactly why I wouldn't want to use it on paint. It will be pretty hard on paint. And I wouldn't leave it on the bare aluminum fins any longer than necessary. Of course, emergencies interrupt things sometimes. Link to comment Share on other sites More sharing options...
eagleeye Posted May 20, 2009 Share #14 Posted May 20, 2009 I clean my plastic shower surround with this stuff. I can't wait to try it on the red engine on my XL250R. That baby ought to look really sharp. Steve Link to comment Share on other sites More sharing options...
Dragonslayer Posted May 21, 2009 Share #15 Posted May 21, 2009 I found an engine degreaser at the auto part store that is in a aerosol can that comes out of the knozzle as a expanding foam. (Like Scrubbing Bubbles)Spray on let foam sit and work untill it desolves into liquid and runs off carring dirt and grease with it then hose it off with high pressure water and it's clean. Shines chrome up good and doesn't seem to hurt anything else. If you got a really dirty spot you can use a brush with it while it is foamy. Link to comment Share on other sites More sharing options...
Disciple Rider Posted May 21, 2009 Share #16 Posted May 21, 2009 OK, What about the name of the product?? Thanks Link to comment Share on other sites More sharing options...
wolfman1 Posted May 28, 2009 Share #17 Posted May 28, 2009 i've been using Scrubbing Bubbles for several years now with no problems. I guess I just don't leave it on there long enough to have problems. If you use it like I do I've had no problems. I wet the bike. I then spray the whole bike with the stuff. i let it sit a few minutes and rince it off. No problems. Now bugs and caked stuff need extra clleaning, but it works for me with most stuff. If therea a better, safer product that does as good, I'm all eyes and ears Cheers, Steve Link to comment Share on other sites More sharing options...
Kandaje Posted May 28, 2009 Share #18 Posted May 28, 2009 Greetings... I can add to that too. Was looking around the house for some ammonia, noticed the Girl Friend had stocked the bathroom cupboard with a can of Scrubbing Bubbles, then noticed that the tub/shower was also clean! Took it out and sprayed it on, let the bubbles run off, then wiped the Tersiphone down with a sponge, and went Huh! Stuff works good!... So I put the GF on the back of my nice sparkling Bike and took her out to dinner for cleaning the bathroom!... Link to comment Share on other sites More sharing options...
