jrcain32 Posted December 15, 2008 Share #1 Posted December 15, 2008 Hey all. My bike has been sitting awhile (2 weeks) and I started to take it for a spin yesterday so I started her up and let her run while I got my duds on. One thing led to another and I did not get to go on my ride so I shut her off and went about doing something else. A while later I walked by and noticed a spot of "clear oily substance" on the floor behind the side stand. At first I thought it was water but I touched it and it is thick like oil but clear. I felt up under the frame in the area I believe the leak is from and I felt something but not sure what are where it is coming from. I will investigate more when I get home. Any ideas what it could be? Looking at the left side of the bike it is behind the kick-stand. What is puzzeling to me is that it is clear in color. Oil would be darker and my oil level is good. Link to comment Share on other sites More sharing options...
N3FOL Posted December 15, 2008 Share #2 Posted December 15, 2008 It could be motor oil...report back and hopefully it is not too serious. Link to comment Share on other sites More sharing options...
Tom Posted December 15, 2008 Share #3 Posted December 15, 2008 Shock? Link to comment Share on other sites More sharing options...
Squeeze Posted December 15, 2008 Share #4 Posted December 15, 2008 Shock? Shock ! Link to comment Share on other sites More sharing options...
N3FOL Posted December 16, 2008 Share #5 Posted December 16, 2008 Someone at home might be playing tricks on him. Link to comment Share on other sites More sharing options...
V7Goose Posted December 16, 2008 Share #6 Posted December 16, 2008 There is a cluster of vent tubes right in that spot, including crank case, air plenum and coolant overflow. Coolant often feels oily, and just one drop of oil does not always show dark color unless it is really old and nasty. I'd keep an eye on it but not be too worried as long as the bottom of the shock is dry. Goose Link to comment Share on other sites More sharing options...
flb_78 Posted December 16, 2008 Share #7 Posted December 16, 2008 Hydraulic oil out of your shock. Get on eBay and buy a Works Performance shock now. Link to comment Share on other sites More sharing options...
Dano Posted December 16, 2008 Share #8 Posted December 16, 2008 Hydraulic fluid from clutch slave? I assume they're still using the same setup. It would run down the frame to the kickstand and drip from there. Clear fluid and feels like oil. What does the winner get for a prize???!!! Dan Link to comment Share on other sites More sharing options...
N3FOL Posted December 16, 2008 Share #9 Posted December 16, 2008 The winner gets to help jrcain32 fix the leak. Link to comment Share on other sites More sharing options...
MAINEAC Posted December 16, 2008 Share #10 Posted December 16, 2008 Check all of the above suggestions then check the shifter rod where it comes out of the case... Mine seeps a little and my shifter linkage is kinda sloppy... The screw that hols on the shifter fell off once and I think I'm missing a bushing or something... I gotta fix it this winter... My Mechanic/Bro says it's a PITA to fix the shifter rod so I just been keeping an eye on it... I've done 62,000 since 6/05 and haven't had to add a drop of oil between changes.. Link to comment Share on other sites More sharing options...
N3FOL Posted December 16, 2008 Share #11 Posted December 16, 2008 Hydraulic fluid from clutch slave? I assume they're still using the same setup. It would run down the frame to the kickstand and drip from there. Clear fluid and feels like oil. What does the winner get for a prize???!!! Dan I see his bike is a 99, so if I am not mistaken his is also a 2nd Gen Venture. When my previous bike sprung a leak on the jugs, it bothered me a lot. Hope he can narrow down what that fluid is and whether or not it is a true leak. Link to comment Share on other sites More sharing options...
Kidh2 Posted December 16, 2008 Share #12 Posted December 16, 2008 You sure it's not a Harley??? Sorry......just kidding, I couldn't resist ! Link to comment Share on other sites More sharing options...
jburrell Posted December 16, 2008 Share #13 Posted December 16, 2008 I agree about the clutch slave. I just experienced the same thing and the clear oil substance is "brake fluid" from the slave or clutch MC. Rebuild both and save yourself some problems later trying to figure out why it still fails. just my 2 c worth Link to comment Share on other sites More sharing options...
N3FOL Posted December 17, 2008 Share #14 Posted December 17, 2008 jrcain32's is a '99 and your is also a '99. Does this tell me that after 9 years or so, my '07 Venture will or may have the same leak down the road. Link to comment Share on other sites More sharing options...
