This stream auto-updates
  1. Today
  2. I build various break out harnesses for lighting systems, rear brake and turns, inside the fairing turns, aux power system and behind the rear tag jumper adapters. Also I have a rear light bar system that mounts under the trunk. I also build trailer harnesses for 4, 5 and 6 wire systems, completely plug and play no cutting or splicing of wires. Photos to come in the near future. PM me for details.
  3. Winter is truly making its presence felt. I am near the MD/PA line and we are freezing tonight. 14 degrees is way too cold for me. We expect to get a good amount of snow by Sunday. The only consolation I see is that we are getting a little more daylight day after day.
  4. -18cel(1f) here in Ontario Canada and chance for more snow tonight over a foot a few days ago!
  5. Yesterday
  6. Update! Bike is running amazingly well… My shifting is good but a little stiff. Will need to assess!
  7. Last week
  8. N3FOL
    Not Happy
    Do you think Don can install a countdown timer on this site (until Spring) At least something to stare at on the monitor all day.
  9. Red Ryder
    Not Happy
    Hey all, it's only 61 more days until spring 😃
  10. 23 this morning but clear. Got about 10 minutes worth of snow yesterday on towards evening!
  11. Good morning to all. I guess I'll just bundle up and start clearing some snow. 26° outside.
  12. N3FOL
    Not Happy
    Time for Don to buy a snowmobile or perhaps you might already have one.
  13. Woody
    Not Happy
    24 degrees and windy
  14. Freebird
    Not Happy
    I wish. It’s 14 degrees and about 10” of snow here.
  15. N3FOL
    Not Happy
    It will be 2 months since my last ride. This weather is not cooperating.
  16. Skid
    Not Happy
    Is it Spring yet?
  17. Goor morning to all once again. It is snowing here. 29°F. No riding and got called in to work this afternoon. Have a great day.
  18. It couldn’t be this simple!! Positive battery wire was loose… really?? She fired right up! But….. tach is out. I did check #2 and it does have spark. Bike is back up and running though, will keep assessing on the tach.
  19. Spray some starter fluid into the air cleaner intake and see if it starts. If so, its a fuel problem.
  20. Bike was running great and now. …. Urgh puff of smoke / loud pop coming from single carb . Bike does not run. All electrics work . I have spark on all 4. If my Cdi was bad , I wouldn’t have spark, correct? any help is appreciated.
  21. Hmmm. I can't believe nobody lives near you. Hopefully someone will chime in.
  22. Good morning. Happy Thursday. Looks like I'll be drinking more whole milk than 2%. Thank God I am also a meat eater. We are back to winter temps once again. Windchill is at 10 degrees. No ride for me for a few days then I'll see. Have a great day!
  23. I am way too scared to ride the bike on F the 13th. Not at all ashamed to admit that.
  24. Earlier
  25. That would be great.Thanks
  26. I just used the fuel line segment that came from the petcock and looped it back into the fuel inlet at the back of the carbs. Removed the rest of the fuel line and the pump. When I get a chance, I'll take and post pictures.
  27. I got in 80-90 miles today.
  28. I've heard a bit about this before. Did u just remove the pump and join the inlet and outlet hoses together or reroute the supply line directly to the carbs?
  1. Load more activity
