- Yesterday
N3FOL started following Weekend project.
Nice work. Just in time for Thanksgiving!
Our kitchen is decidedly lacking in counter space. The spot next to the range where we keep the recycle/garbage bin is about the only area it is feasible to add any horizontal surface at all. I'd been thinking about building this for a while, but just got to it yesterday. Some wood filler on the nail holes, milk paint, and Renaissance Wax are all that's needed to finish. That'll will probably be more work than building the stupid thing!
- 1 reply
- 3
I finally had some free time to hit the range with the 6mm ARC build. The final build was as pictured in my OP but I had swapped the Mil Spec trigger for a Rise Armament, Rave140 trigger. After getting the scope dialed in at 100 yards with no suppressor, I installed the JK Armament VERSA X .30 cal can and had 4 rounds left in the magazine. The group, while off aim point was stupid tight. All four shots are completely covered by a nickel. Under 1/2 MOA! I'd call that solid. I'm waiting for the NFA tax to go to $0.00 in January to pick up the SILENCERco Omega 300 can that is going to live on this upper before I adjust the scope to match the can.
Only 263 days to go!
I've owned a boat since 1986 and I love my boat. If I lived further south and near a large lake or ocean, I'd sell the bike and live on the water.
- Last week
I have an 86 1300, need to replace the cdi/tci I was looking at the ignitech but I found a company here in California (Regulatorrectifier.org) that is making a plug and play one as well. Does anyone have any experience with this one? I am going to get it but just wondering if anyone had any insight before I buy. Here is a link to the product. https://www.regulatorrectifier.com/products/1984-1993-yamaha-venture-royale-xvz1300-cdi-ignitor-unit-assy
I was working at the Turkey Point Nuclear Plant during my stay in Homestead from Jan 10, 2010 until August 31, 2013 during the power uprate modifications. During that time housing was dirt cheap after the recession. A nice 1800 sq ft home could be bought for about $130k. I should have bought one. I say one home go on the market that was almost new, 6000 sq ft, on 7 acres that was priced about $330k. We went to Penney camp too a few times. There were a lot of burglaries at that time so it prompted me and my wife to get concealed carry permits. We used to stop at the indoor range/gun shop in Key Largo and practice before going fishing on the weekends. I rode my Kawasaki to work every day I could. Lots of good memories.
Good morning ventureriders! Another foggy morning, but the weekend looks promising for some rides. Ride safe. TGIF!
Weird starting problem
Marcarl replied to megamile's topic in Royal Star Venture Tech Talk ('99 - '13)
Grab a small cable, the size of the battery cable or so, clamp it onto the load side (starter) of the relay and then touch the other side of the relay. If there is no response touch it to the battery. Don't matter if the key is off or on. Report back. -
I lived in Key Largo for a couple of years in the mid 80s. I was doing contract work at Turkey Point power plant outside of Homestead. Actually bought a house at MM98. Wished I'd kept it....My cellphone bill today is more than my mortgage payment was then. Been back a couple of times and while I also love it down there, it's not the same as it was. A lot more traffic and congestion. I still like going back though. Penney Camp Park was pretty cool.
We are thinking of maybe taking a TT to Florida and living in it for a month at a time after my wife retires. Hotels cost a fortune for an extended stay. And as stated it is your own place which we would like. It's hard to get but a camping site in Bahai Honda State Park would be ideal. My next to last contract job (3 1/2 years) I lived in Homestead FL, close to the Keys and we loved it down there. We fished a lot, soaked in the warm clear water a lot, went to Key West a lot, just thoroughly enjoying the area. We also saw many tourist attractions around Miami and southern Florida. It was my favorite contract job location. Now, we spend a week in the FL Keys almost every year.
'99 Intermittent Starting - Bad Ground?
BratmanXj replied to BratmanXj's topic in Royal Star Venture Tech Talk ('99 - '13)
A HD mechanic buddy helped me with the actual implementation.... but we basically made the starter system always hot after the key so the bike will crank with the kill switch on or off. The kill switch effectively toggles the SCCR on and off. He did most of the system diagnostic and I can't give you much information on exactly how. I'll see if he still has the scratch-pad laying around his shop. -
megamile started following '99 Intermittent Starting - Bad Ground?
megamile replied to BratmanXj's topic in Royal Star Venture Tech Talk ('99 - '13)
Quote: "I ended up bypassing the the safety system and the bike is working fine." How did you bypass the SCCR? Having starting issues on mine and I wonder if that relay might be part or all of the problem... -
megamile replied to megamile's topic in Royal Star Venture Tech Talk ('99 - '13)
Update 11/18/25: Pulled and had battery tested; fully charged and tested fine. Cleaned all connections I could find, Dielectric greased them. Tested starter relay; no continuity with power applied. Changed relay. Still the same issue. Pulled and checked SCCR; tested ok. Can't reach starter terminal to apply power directly. Pulled ignition switch; ordered new one as I'm pretty sure contacts are toast. Also ordered new SCCR just in case. djh3_88 has built an ignition bypass relay for me; waiting for shipment. Pulling bar switch housing today to check and clean contacts. Only other thing I can think of would be a worn and partially broken wire somewhere; I think if a wire were chafed and grounded I would be blowing a fuse somewhere; fuses are all good. Haven't heard of any self-resetting circuit breakers on this bike... Maybe intermittent ground issue? Other than battery ground terminal I have no idea where any other ground wires/straps might be located. Very frustrated at this point; hoping new parts wil help. -
I don't know that I'd want to live in one, but the nice thing about a RV is that you're taking a bit of "Home" with you. Everything doesn't seem quite as foreign when you have a small, familiar place to retreat to. I find that I'm typically a bit more comfortable in my small motorhome than in a hotel room.
@bpate4home Very nice! Glad you had fun with fellow riders in your area.
Got in a good ride over the weekend. Met with a group of 2 Indian riders and 3 Harley riders. Round Trip 250 miles and 7.5 hours with a long stop for lunch. Bunch of back roads and little traffic. Not as aggressive as before the stroke but the confidence is coming back.
They say the same thing about RVs. I've no complaints. I rarely use it, but it's nice to have when I do use it.
No ride today. Maybe tomorrow. Good evening to all!
- Earlier
I need a 2nd happy day for the pontoon. I use the fishing boat a lot, we live 10 minutes away from KY Lake which is one of the largest man made lakes. 160,000 surface acres 100% free to use. I spend more time cleaning the pontoon than we’ve ever used it.
I'm 81 with heart issues. And mostly, I just didn't use the boat any more. I'm sure I will miss it. It's such a great feeling to be out on the water in my own boat!
The family's pontoon boat is 25yrs old and just keeps plugging along... Mom is 77 and decided this year she wanted a new boat. We picked up a '21 Trifecta with 20hrs on it last weekend in an early season snowstorm in Indiana. Hopefully this one serves us as well as the last one. The sellers oldest brother bought it as a "last hurrah" when he was diagnosed with cancer 2yrs ago. The other brothers were happy to see it go to a family that would take care of it and treasure it. They are local to our cottage and we told them they have an open initiation to come take a ride anytime.
Those Boston Whalers are nice boats. I’m sure you will miss it. I understand though. I sold my last boat a couple of years ago. Same reason you did. I still have two Yamaha Waverunners and never took them out this year and only once last year. I really should sell them too.
BlueSky started following Second happiest day of boat ownership
Yes, Wednesday I sold my 1998 18' Boston Whaler Ventura. I bought it in 2007. My wife and I enjoyed it very much but we are older and just didn't use it much any more. I sold it to a young couple who plan to have a lot of fun with it. Hopefully, it will serve them well.
