juggler Posted August 25, 2006 Posted August 25, 2006 This happened a few months ago. When leaving work one day I found my boss sitting in the parking lot with a dead car. He left his lights on all day. Since he had cables I said sure, I'd try to give his car a jump. I mean after all both are 12 volt systems. Well after leaving the cables hooked up for about 5-10 minutes (yes the bike was running and reving) we couldn't get enough juice to flow to the car battery. I guess there just isn't enough juice to really do a jump start. Maybe I could have trickle charged his battery for an hour then maybe it would start. Anyways, another co-worker came out and we used his car to jump start the bosses car. It started right up then. Nothing fried on any vehicle, so lessoned learned the easy way.
Condor Posted August 25, 2006 Posted August 25, 2006 I think it all depends on the battery. I've read where a Chevy truck with a 350ci in it was successfully started with a VR with an Odyssey battery. The stator doesn't put out enough amps by itself to be strong enough to turn a bigger motor.
awsmsrv Posted August 25, 2006 Posted August 25, 2006 Anyone ever tried to jump a bike from the car? I wonder if that would fry things on the bike. (The mind is working too hard, I think.)
Condor Posted August 25, 2006 Posted August 25, 2006 Used to start my son's XS850 all the time by jumpering it with the Suburban. He never had any money to by a better battery.
Grandpagak Posted August 25, 2006 Posted August 25, 2006 i have done it many times on several different bikes , with no problem.. but i always leave the vehicle engine turn off..
BradT Posted August 26, 2006 Posted August 26, 2006 Well after leaving the cables hooked up for about 5-10 minutes (yes the bike was running and reving) we couldn't get enough juice to flow to the car battery. I have heard reving the engine is not good idea, on either a car or bike. To much power draw can overheat things causing trouble. Not sure if this is true or not, but I never rev them Brad
GeorgeS Posted November 6, 2006 Posted November 6, 2006 I carry a home made set of cables on the bike. I made them up with #10 wire. Don't use the heavy car jump cables.
Yammer Dan Posted November 6, 2006 Posted November 6, 2006 Took a regular 9 ft. household extension cord, cut of plugs put clamps on and works great for bike and I did charge a car batery with it once. Hooked it up and ran about 15 min and car started. Guess it depends on how dead battery is.
Guest VentureCruiser Posted December 24, 2006 Posted December 24, 2006 Took a regular 9 ft. household extension cord, cut of plugs put clamps on and works great for bike and I did charge a car batery with it once. Hooked it up and ran about 15 min and car started. Guess it depends on how dead battery is. Not sure it would work on a bike, but I've heard of cars being jumped with the two cigarette plugs on each end of the wires. Would make it easy to hook up if it works.
Bvinson Posted December 28, 2006 Posted December 28, 2006 I have a buddy that has a hopped up Honda Accord. He as well as most of the others in his car group all use the Odyssey 680 for their battery. They say it will spin over a maxed out V6 or 4 cylinder as well as any larger battery.
friesman Posted April 26, 2008 Posted April 26, 2008 When I first got my 85 VR a couple of months ago I started it with a jump off my 07 escape. I left the ignition off as I didnt want to fry an electrical on either machine. I used a heavy set of jumper cables and the VR fired right off and removed the jumper immediately on firing to avoid overload. I replaced the battery on the ride the next day, I figured if it won't start around 0 theres' not much life left in the battery. Brian
AZSpyder Posted April 26, 2008 Posted April 26, 2008 Years back I had a 305 Honda that wouldn't run with a dead battery. We once took the battery out of my friends Pinto after it was running (should have fried something in the car but didn't) and wired it to the Honda with speaker wire. I rode it back home with the battery on the seat between my legs and the Pinto following. Jerry
