Bob B Posted May 29, 2014 Share #1 Posted May 29, 2014 Has anyone installed a external oil line to the clutch gear? Looks like you could tap in the plug on the right side where some people install a oil pressure gauge. Then drill and tap a hole in the area of the gear. Dont appear to be a big deal to try. BB Link to comment Share on other sites More sharing options...
Eck Posted May 29, 2014 Share #2 Posted May 29, 2014 I have never heard of anyone doing this Bob..... However, if you decide to take a shot at this, it would pay off to video your process of how it was done and if it works as you expect it to, we can post it in the tech article section. I love guinnie pigs... Link to comment Share on other sites More sharing options...
Drreb Posted May 30, 2014 Share #3 Posted May 30, 2014 Hmmmm interesting I have a oil pressure gauge attached there. Link to comment Share on other sites More sharing options...
djh3 Posted May 30, 2014 Share #4 Posted May 30, 2014 You could use some braided stainless steel line (aeroquip type). Shoot put a T in it and still run an oil press gauge. Link to comment Share on other sites More sharing options...
Bob B Posted May 30, 2014 Author Share #5 Posted May 30, 2014 I dont see where it could hurt, May need to restrict the passage. Ive been want to do clutch upgrade and that would be the time to do it. BB Link to comment Share on other sites More sharing options...
RussLightwing Posted June 4, 2014 Share #6 Posted June 4, 2014 HI I would appreciate any help possible in installing the gauge or extra line to feed the clutch gear I have proved absolutely its lack of oil making a weird situation (cutch whine) worser I have now carved some micro oil divets in the gear drive and clutch gear and when oiled is 50 % better just need oil YESSSSSS OH give me OIL gauge where the buffalo roam and clutches are silent all day soft and quiet on the range where the royal stars and tour deluxes play:fingers-crossed-emo whineee TAMED 25% better YESssss I have an 08 royal star and I put in a I basket last year it helped a bit !!!! I noticed that on the side stand while changing gears there is no oil in clutch chamber!!!!!! HI the MAIN DRIVE GEAR SITS DRYYYYYY all the time on the side stand HMMMMMMMMM:detective: I Now stand the bike up vertical when home. it coats the gears in a bath of oil which flows passively into the clutch chamber=I USE a combo of lucAs OIL 20/50 AND MOTOR kote also lucas oil additive helps with the noise too best yet! tried it for a week now well see if its accumulative:cool10: I TRIED it leaned over on side stand again for two days and loud WHIiiine was back there isn't enough oil on that gear while driving really BUT if it is soaked it sticks which is lucas oil specialty so stand er up pour in your engine kote let it sit for day and 25% quieter try er out boys good luck THERE is in fact a center stand available from Rivco:080402gudl_prv: http://www.rivcoproducts.com/products/product.php?productid=60&cat=202&page=1 now for windshield pouches to tone down reflective noise HAS any body tried that????? Link to comment Share on other sites More sharing options...
YamahaLarry Posted June 4, 2014 Share #7 Posted June 4, 2014 Has anyone installed a external oil line to the clutch gear? Looks like you could tap in the plug on the right side where some people install a oil pressure gauge. Then drill and tap a hole in the area of the gear. Dont appear to be a big deal to try. BB It could cause you to have an oil pressure drop unless you somehow use a small orifice to only allow a small amount of oil to dump. Link to comment Share on other sites More sharing options...
MikeWa Posted June 4, 2014 Share #8 Posted June 4, 2014 It could cause you to have an oil pressure drop unless you somehow use a small orifice to only allow a small amount of oil to dump. Propane supply houses usually have a selection of gas jets one of which should work. Or many auto engines use an oiler jet to lubricate the piston wrist pin. One of those could also work just fine. I have often thought of this as a cure. But with my bike still being under warranty I am in no hurry to try. I used to do something similar to Chevy timing chains. Virtually stopped chain wear. Link to comment Share on other sites More sharing options...
Bob B Posted June 15, 2014 Author Share #9 Posted June 15, 2014 Added the oil line last week while installing the Barnett spring conversion. First, I would call it well worth the time (about a hour), the cost (about $15). No, it didnt eliminate the noise completely, but it sure helped. More so at highway speed. After opening the case i seen there was a nice compartment right over the driven clutch gear. Thats when the idea to pump the oil to the void and meter it down from there to direct oil to the gear. A few pointers: I used push to connect air line fittings that swivel. 1/8NPT to 5/32 airline 90s Makes install easy, takes up little room, I used a 1/4 NPT to 1/8 NPT bushing in the oil acess plug to allow tightening to reinstall after drilling and tapping. I used .045 drill bit for orfice. If i have it apart again i would drill the hole larger. Other info: The clutch basket turns counterclockwise, that being said you adding oil after the contact has been made. Oiling from the other side should be a better angle but much harder to do! In closing, after 300 miles today the FB6 is gone from my head! Your results may vary.. Link to comment Share on other sites More sharing options...
BRandx51 Posted June 19, 2014 Share #10 Posted June 19, 2014 I'm surprised there has been no comments on this since it seems to be the #1 issue people have with the bike. Did you take more photos while you where doing this? I'd be interested in seeing them. Link to comment Share on other sites More sharing options...
Ace Posted June 19, 2014 Share #11 Posted June 19, 2014 Awesome idea, I may just have to do this. Link to comment Share on other sites More sharing options...
Bob B Posted June 19, 2014 Author Share #12 Posted June 19, 2014 Sorry i forgot about pictures. I worked on it over a couple of evenings trying different fitting and hose configurations before deciding to keep it simple. Link to comment Share on other sites More sharing options...
RussLightwing Posted July 27, 2014 Share #13 Posted July 27, 2014 (edited) I will try to find a solid place without that flange/ gap I think thoo BUUUTTT what is the size of the oil outlet from the bike what MM 17 for the oil gauge pls???? ?? Thanks cant wait to try this awesome IDEA ahhh SILENCE-ISH BTW I have built a side stand to lean it over on the right soaking the clutch before a ride and it helps a lot but this is the better idea by far OIL feed yes!!! Edited July 27, 2014 by RussLightwing spelling Link to comment Share on other sites More sharing options...
Chaharly Posted October 28, 2014 Share #14 Posted October 28, 2014 Has anyone installed a external oil line to the clutch gear? Looks like you could tap in the plug on the right side where some people install a oil pressure gauge. Then drill and tap a hole in the area of the gear. Dont appear to be a big deal to try. BB So has anyone done this yet? Link to comment Share on other sites More sharing options...
Madcow Posted October 28, 2014 Share #15 Posted October 28, 2014 Sweet!! Maybe a pass through fitting where you can bring a small bit of the hose into the case and align it so it pours just to the bottom of the motor gear? The oil will be pulled into the contact area and maybe get rid of the Jetson's twrrrk?? Gotta make the effort to do this when I do my clutch this fall. I'll take pix too. Link to comment Share on other sites More sharing options...
eagleeye Posted October 28, 2014 Share #16 Posted October 28, 2014 Chaharly, Go up 5 posts and you'll see that Bob has done it. Bob, What is the small black line going down from that pocket? Was that there or did you put it there? Thanks, I got an I basket a couple of years ago and put it in, but it made my whine louder, so after maybe 50-100 miles took it out and it's on my shelf. Steve Link to comment Share on other sites More sharing options...
Bob B Posted October 29, 2014 Author Share #17 Posted October 29, 2014 Chaharly, Go up 5 posts and you'll see that Bob has done it. Bob, What is the small black line going down from that pocket? Was that there or did you put it there? Thanks, I got an I basket a couple of years ago and put it in, but it made my whine louder, so after maybe 50-100 miles took it out and it's on my shelf. Steve That black line is the line i added go into the pocket. Bob Link to comment Share on other sites More sharing options...
Chaharly Posted October 29, 2014 Share #18 Posted October 29, 2014 Chaharly, Go up 5 posts and you'll see that Bob has done it. Bob, What is the small black line going down from that pocket? Was that there or did you put it there? Thanks, I got an I basket a couple of years ago and put it in, but it made my whine louder, so after maybe 50-100 miles took it out and it's on my shelf. Steve Would that I basket be for sale by chance? Link to comment Share on other sites More sharing options...
Chaharly Posted October 29, 2014 Share #19 Posted October 29, 2014 (edited) Looking at the pictures you showed me, and this picture from The Venturers website it looks like you can put a small line where I've marked it with a blue arrow. This will be putting the oil where it needs to be right? Will it have enough pressure to squirt or is it just a trickle? Edited October 29, 2014 by Chaharly Forgot Attachment Link to comment Share on other sites More sharing options...
djh3 Posted October 29, 2014 Share #20 Posted October 29, 2014 I have a question on this subject I just thought of the other day. For the most part the first and second gen engines are , the same. So why doen no one complain about clutch whine on the 1st gen? Could you install a clutch basket for a first gen in a second gen? Link to comment Share on other sites More sharing options...
Flyinfool Posted October 29, 2014 Share #21 Posted October 29, 2014 I have a question on this subject I just thought of the other day. For the most part the first and second gen engines are , the same. So why doen no one complain about clutch whine on the 1st gen? Could you install a clutch basket for a first gen in a second gen? I have asked that question many times, never got a good answer. I have a first gen so the only whine I hear is just before I leave the house alone..... Link to comment Share on other sites More sharing options...
Madcow Posted October 29, 2014 Share #22 Posted October 29, 2014 My first gen had the whine but no where near as loud as my second gen. Jes sayin' Link to comment Share on other sites More sharing options...
eusa1 Posted October 29, 2014 Share #23 Posted October 29, 2014 all wine questions are supposed to go through b2mom:confused24: don't nobody tell her I said that:rotf: Link to comment Share on other sites More sharing options...
Chaharly Posted October 29, 2014 Share #24 Posted October 29, 2014 So using the parts described will it be enough to shoot the oil or will it just sort of run out Link to comment Share on other sites More sharing options...
RussLightwing Posted April 2, 2015 Share #25 Posted April 2, 2015 hi cant find the airline air tubes still looking how about break cable and banjo bolts with stainless cover and maybe at the back of the case under the exhaust still on top but solid case there how large diameter for banjo hole do you think thanks Russ Link to comment Share on other sites More sharing options...
