I washed the Venture today and after backing it back in the shop to put it back together, I noticed some oil dripping underneath the center of the bike. Looked it over and it looks like the shock is leaking.
A couple of questions here.
Will it hurt to continue to ride the bike with a bad shock?
And second, who can I get to rebuild this shock?
Thanks for any help.
13 hours ago, RDawson said:
I texted @dfitzbiz contact info to you. He’ll rebuild it.
Thank you, Ronnie. I have sent him a text and am waiting to hear back from him.
If he’s traveling it may take some time to hear back from him.
6 hours ago, Paul Martin said:
Steve, if you're mechanically inclined and wanted to try and tackle it yourself, see this writeup:
Thank you Paul. That looks very doable for me.
I got the shock off this afternoon. It took about 20 minutes to get it set in the vise and start draining it.  I made the bracket to press it up to change the O ring but stopped for dinner. It looks like it will be an easy fix, but I didn't get the fork oil today so it will be Tuesday before I can reinstall it.
  • Like 1
Share some pics when you can!  Here's mine just now - dry 950 miles later.  And if yours was low on shock fluid and was pogo sticking, you will be amazed at how much better the ride is when you get it fixed.
Edited by Paul Martin
  • Like 1
WELLLLLLL..... It was NOT the shock.  The shock was had plenty of oil in it and was not leaking. However, since I had it off, I changed the O ring and oil. I was putting it back on, got all 3 bolts in and could not find the lock nut for the 3rd bolt.  🤔 So, I didn't get it finished today. I'll get a new nut tonight and finish it the first thing in the morning.
The other side of the equation is the problem. Where did you clear yellow oil come from that was under my bike after we washed it. I didn't start it to move it out to be washed or when I moved it back in the shop.
Here are some pics of the oil and the frame I built to fix it.
IMG_3704.thumb.JPG.4bb968405234d27c362e94d5ec8106ec.JPGIMG_3707.thumb.JPG.37de70c85274e41b05625eb99246d6c8.JPG
To say the oil was dirty is an understatement.
Now I will keep an eye out for oil leaks.
Ok now where did that plastic cup of clean oil come from?  Is that your new shock oil that you put into the shock, or is that the mystery oil that came from somewhere else on your bike?
If that isn't new shock oil, then the first thing I would suspect is crankcase oil blowing out breather tubes that come out down near where the lower shock mount is.  But I'm at a loss as to what caused it to leak out if you didn't run the engine when you washed the bike.  But also, your profile says this is a 2010 RSV trike.  Never seen one up close.  Does the trike setup have any additional oil reservoirs down under?
Happy belated birthday by the way!
The clear yellow oil is the new Yamalube shock oil. The black stuff is what drained out of the shock. Well over 125ml.
The engine hadn't been running for a couple of days before I saw the oil on the shop floor.
Edited by Steve S
I got a new lock nut and finished installing the shock this morning. I took it out to the Yamaha shop for a new rear tire, and it rode great.  Going to take a ride down the Natchez Trace with my bro in law next week. I'll share a report on that ride when we got home.
  • Like 1
Still puzzling about the yellow oil patch.  If you are in the habit of filling the oil up near the top of the sight glass it tends to blow out the crankcase and back into the air intake, then out the tubes.  If there's more oil in the crankcase than you thought and it smells like gasoline you may have a stuck carb float letting gas into the engine and down into the crank.  A lot of the guys on this site and the owners manual says to shut the petcock off between runs to avoid that problem.  Hopefully that's not what you have going on.
  • Like 1
Thank you Paul.  I'll check the for gas. I did notice the oil level was at the top of the sight glass.
Oil level should be below the midpoint.  If above that it was overfilled or gas is getting in the oil.   Overfill equals mess due to oil expelled.  Gas in oil can result in blown engine
Just to be clear on this, the level in the sight glass is with the bike vertical, not leaning on the side stand. When I had my Venture and my Royal Star, I used a mechanics mirror with an extendable shaft, so I could see the sight glass while straddling the bike to hold it vertical. Alternately a  1-1/2" to 2" thick piece of wood under the side stand will hold it almost vertical, just be careful not to bump the bike or turn the handle bars,  as it could cause the bike to fall over to the right side .
  • Like 3
I changed the air filters and did a carb sync on the Venture today getting ready for a trip down the Natchez Trace tomorrow.  While I had it sitting level, I checked the oil level, and it was dead center of the sight glass. And I have not seen any more oil on the under the bike. So MAYBE, I was wrong about the oil coming from the bike. It could have been some oily drippage from the washing we gave it.  I'll keep a close watch one it and see how it goes.
  • Like 1
  • 3 weeks later...
Update on the Venture engine.  I changed oil today and put 3.9 quarts, OK. I put the whole gallon in, and put the used oil in the gallon jug. It filled the jug back to just below the level it was before I poured it in the engine. I figure the difference is the amount in the oil filter.  This tells me it is not getting gas into the oil, which is very good news.
The other side of the coin means I have no idea where the oil in the floor came from. But I know the engine is doing well so I am not going to worry about it.
I’m thinking that the oil came from under your garage floor… there’s an oil well there just waiting for you to start drilling!🛢️🛢️🛢️
