  Nope.   I don't need a stator, at least not yet.
  I was thinking of getting a replacement stator / gasket to keep handy in case of failure, which seems to sometimes happen, and usually at a bad time.
  I see there's stators readily available online, but prices are all over the map.
  What should I look for and what should I avoid?
  Opinions appreciated.
stay away from the chinese crap! your better off to pay a little more for us stuff or mother yamaha stuff. i've not had much luck lately with china crap! just my opinion!🤔
  • Like 1
I would stay away from the high output stators, I put one in my first 1999 venture. I replaced the engine after only about 10,000 miles and when I checked the stator it had burned half of the stator, looked as bad as the one that I replaced with at least 70,000 miles on it. Higher output equals more heat.
  • Like 3
RM?
I see a lot of Ricks, some OEM and some OEM used.   Caltric seems to be all over the place...(cheap)
Cheap seems nice as an emergency spare, but I've been burnt by Mr. Cheap a few times.     Again, just as an emergency spare I don't know if I should spring for the extra $$$ just for the piece of mind.    I'm so confused....
Rick's was a good choice as well. Know that the present stator will fail sometime down the road, especially if you load it with more than stock or run the battery down regularity.
So how long did it last? what if any addition load do you have that draws from the battery. (Extra lights, upgraded audio, heated clothing.)
I realize that aftermarket in this case is much, much cheaper and OEM is crazy high price but are these aftermarkets absolutely junk but they seem to sell them every day.
I am looking at a new stator - gasket - and Rectifier and dealer quote is $595.44 including tax. Don't think i will go that route so looking at aftermarket even if it lasts
a few years.
I’ve got 90k miles on the OEM and counting. If it fries I figure one more OEM will last the rest of my life, small investment for that many miles.
I will agree on avoiding high-output stators. I got like 5k miles on mine. I was then frustrated and bought a 30 dollar one from Amazon and got like 20k or more miles out of it.
Now I'm running a Rick's stator. 10-15k miles on it so far and working good. We'll see how long it lasts.
  • Like 1
  I get that a high output stator can create more heat, but is that still true if I'm not putting any additional load on it?
  It seems to me that you'll only get more heat when you create more of a load.
  Looking at a "Ricks" 40a for $179.
  Keeping in mind that I may never even need it;  just don't want to get stuck somewhere.
You can always change it out in the back yard of the air bnb at 1:00 a.m. right? 🤣🤣🤣
Edited by RDawson
  • Like 1
Expand
Stators always put out full production, it's the voltage regulator/rectifier that controls the flow.
  • Like 1
 put in a high out put stator, new regulator, new regulator only lasted one day n it blew the main fuse by the battery, didn't make it one day. i think it totally fried the new regulator!
