kapebretoner Posted April 15, 2016 Share #1 Posted April 15, 2016 Any body know where I can buy glass fuses online for a 89 venture royale. Can't get them in ml local area. Link to comment Share on other sites More sharing options...
yamagrl Posted April 15, 2016 Share #2 Posted April 15, 2016 Ebay http://www.ebay.com/itm/100PCS-5X20MM-GLASS-QUICK-FAST-BLOW-FUSES-TUBE-AUTO-CAR-0-2A-15A-/322043803241?hash=item4afb4e7669:g:cMAAAOSwHxVW66Wj I also think I have seen them in Walmart Link to comment Share on other sites More sharing options...
Flyinfool Posted April 15, 2016 Share #3 Posted April 15, 2016 Another great reason to convert to a new ATM fuse box. What happens if you need a fuse while on the road and you can not find one? The glass fuses and their holders are also a very well documented source of electrical gremlins on these bikes. Link to comment Share on other sites More sharing options...
10spd Posted April 15, 2016 Share #4 Posted April 15, 2016 Another great reason to convert to a new ATM fuse box. What happens if you need a fuse while on the road and you can not find one? The glass fuses and their holders are also a very well documented source of electrical gremlins on these bikes. I can't remember. Doesn't one of the members sell a kit to replace the old with the new? Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
yamagrl Posted April 15, 2016 Share #5 Posted April 15, 2016 Skydoc http://www.venturerider.org/forum/photopost/showproduct.php?product=59&title=first-gen-vr-fuse-box-upgrade-kit&cat=17 Link to comment Share on other sites More sharing options...
kapebretoner Posted April 15, 2016 Author Share #6 Posted April 15, 2016 thanks yamagrl. ordered some on ebay Link to comment Share on other sites More sharing options...
djh3 Posted April 16, 2016 Share #7 Posted April 16, 2016 Another great reason to convert to a new ATM fuse box. What happens if you need a fuse while on the road and you can not find one? The glass fuses and their holders are also a very well documented source of electrical gremlins on these bikes. EZ fix. Wrap a piece of chewing gum wraper around the blown fuse and your good to go. Link to comment Share on other sites More sharing options...
Flyinfool Posted April 16, 2016 Share #8 Posted April 16, 2016 Link to comment Share on other sites More sharing options...
Yammer Dan Posted April 16, 2016 Share #9 Posted April 16, 2016 And keep a bag of Marshmallows to toast while bike burns!!! LOL!!! The tin foil repair is good if you get caught out somewhere but bears watching!! Link to comment Share on other sites More sharing options...
bongobobny Posted April 16, 2016 Share #10 Posted April 16, 2016 Saw the head off of a 6mm bolt and insert... Link to comment Share on other sites More sharing options...
syscrusher Posted April 16, 2016 Share #11 Posted April 16, 2016 Lots of photos and info in this thread: http://www.venturerider.org/forum/showthread.php?105380-Easy-How-to-Fuse-Box Link to comment Share on other sites More sharing options...
djh3 Posted April 17, 2016 Share #12 Posted April 17, 2016 LOL yea buddy. I sure hope nobody takes this as serious fix. What I had done in past was I had some sort of old car, I sure dont remember what it was. but I took a glass fuse, knocked the glass out, soldered in a wire and a couple spade connectors a AGC or whatever fuse would sit in. Then a zip top bag with a couple common sizes 5,10 15 amp AGC fuses. Then if the glass fuse blew, I could plug the glass ends in slots and install the AGC "temp" fuse and get where I was going. Link to comment Share on other sites More sharing options...
videoarizona Posted April 18, 2016 Share #13 Posted April 18, 2016 LOL yea buddy. I sure hope nobody takes this as serious fix. What I had done in past was I had some sort of old car, I sure dont remember what it was. but I took a glass fuse, knocked the glass out, soldered in a wire and a couple spade connectors a AGC or whatever fuse would sit in. Then a zip top bag with a couple common sizes 5,10 15 amp AGC fuses. Then if the glass fuse blew, I could plug the glass ends in slots and install the AGC "temp" fuse and get where I was going. Now that is a great idea!! Link to comment Share on other sites More sharing options...
djh3 Posted April 18, 2016 Share #14 Posted April 18, 2016 Oh I had a pick up that I use to pull a race car trailer with. It developed a short in the wiring and would occasionally pop the fuse for the tail lights. I bought a circuit breaker and wired it in the same way. Then if it happened to pop the breaker I could reset and still have lights and no ticket. I did finally rewire the trailer and the problems went away. Link to comment Share on other sites More sharing options...
