Hummingbird Posted March 2, 2016 #1 Posted March 2, 2016 Ok - I give up I'm looking for info on oil filters for my 2009 RSV. I've been nearly an hour seraching here and in the 2nd gen tech area and come up empty. I'm most likely not using the right search words but I really thought that oil change, RSV, oil filters and other terms would bring something besides 1st gen info. If someone could point me in the right direction I sure would appreciate the help.
T.J. Posted March 2, 2016 #2 Posted March 2, 2016 http://www.venturerider.org/forum/showthread.php?96009-Oil-Filter-Comparisons-Hey-I-m-no-Engineer Maybe this will help. I know there was a cross reference chart once upon a time. I will see if I can find it.
Hummingbird Posted March 2, 2016 Author #3 Posted March 2, 2016 http://www.venturerider.org/forum/showthread.php?96009-Oil-Filter-Comparisons-Hey-I-m-no-Engineer Maybe this will help. I know there was a cross reference chart once upon a time. I will see if I can find it. T.J. THANK YOU no need for a cross reference chart, it looks to like the Purolater PL14612 is fine and I might go to the Rotella 6 oil, I always seem to gravitate to Mobil1 for my bikes. Unlike some, I'm not anal about oil and filters because I have yet to hear about an engine failure due to oil or filter use. My problem is that I don't know how to search correctly for info. Thanks Again, Hummingbird aka -Dick Byrd
T.J. Posted March 2, 2016 #4 Posted March 2, 2016 It is not always easy to find stuff. Believe me, I just got lucky. Glad it helped you.
T.J. Posted March 2, 2016 #5 Posted March 2, 2016 I just had to find it. There is another one some place. http://www.venturerider.org/forum/showthread.php?523-Oil-Filters Have fun. You will need to go all the way to the end to understand the chart.
Eck Posted March 2, 2016 #6 Posted March 2, 2016 (edited) The following is a cross referencefor oil filters that work on your second generation Venture. Amsoil has new filters. clean at 98.7percent@15microns. New number is EaOM103. [TABLE=class: MsoNormalTable] [TR] [TD] Brand [/TD] [TD] Part Number [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Baldwin [/TD] [TD=width: 296, bgcolor: transparent]B1400 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Fram [/TD] [TD=width: 296, bgcolor: transparent]PH6017A [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Napa Gold [/TD] [TD=width: 296, bgcolor: transparent]#1358 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Perf-form [/TD] [TD=width: 296, bgcolor: transparent]PFJ503 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Purolator [/TD] [TD=width: 296, bgcolor: transparent]PL14612 does not work anymore - They changed the threaded end from concave to a convex flange and the O-ring wont seal now - (Thanks Kirby). [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Purolator [/TD] [TD=width: 296, bgcolor: transparent]ML16819 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]WIX [/TD] [TD=width: 296, bgcolor: transparent]51358 = Cost is $9.99 at Oreilly auto parts- Madison [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Yamaha [/TD] [TD=width: 296, bgcolor: transparent]3FV-13440-00-00 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]AC Delco [/TD] [TD=width: 296, bgcolor: transparent]PF2135 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Amsoil [/TD] [TD=width: 296, bgcolor: transparent]SMF103 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Carquest [/TD] [TD=width: 296, bgcolor: transparent]85358 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Honda [/TD] [TD=width: 296, bgcolor: transparent]15410-MCJ-000 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]K&N [/TD] [TD=width: 296, bgcolor: transparent]KN-303 or Chrome KN-303C [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]STP [/TD] [TD=width: 296, bgcolor: transparent]SMO 17 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Bosch [/TD] [TD=width: 296, bgcolor: transparent]3300 [/TD] [/TR] [TR] [TD=width: 73, bgcolor: transparent]Mobile [/TD] [TD=width: 296, bgcolor: transparent]M1-108 [/TD] [/TR] [/TABLE] Edited March 3, 2016 by Eck
Hummingbird Posted March 2, 2016 Author #7 Posted March 2, 2016 Eck - Thanks for the chart and I don't know if you use Honda filters or not but I have 6 or 8 Honda OEM oil filters that I have no need for - do you ?
T.J. Posted March 2, 2016 #9 Posted March 2, 2016 Eck - Thanks for the chart and I don't know if you use Honda filters or not but I have 6 or 8 Honda OEM oil filters that I have no need for - do you ? Are these Honda's # 15410-MFJ-D01? If so and Eck is not interested. I could use them, or at least some of them, on my Honda ST1300 if the numbers match.
Zzyzx Posted March 2, 2016 #10 Posted March 2, 2016 Here is another cross reference chart to add to what Eck and TJ posted that I found when searching alternative filter brands. The chart cross references RSV filters that can be used on other bike and even some car and vise-versa. Yamaha Venture and TD Oil Filters Fram PH6017A replacement oil filters: • AC-Delco PF2135 • AMSOIL EAOM103 • ARCTIC CAT 3201-044 • ARCTIC CAT 3201-451 • AUTOEDGE AL6017A • Baldwin B1400 • Baldwin B7285 • CARQUEST 85358 • CARQUEST 85365 • ChampLab PH2876 • ChampLab PH7015 • ChampLab PH7028 • DENSO 115010-5390 • Donaldson P502067 • EMGO 10-26920 • EMGO 10-82230 • EMGO 10-82251 • Fleetguard LF3925 • Fram PH6017A • HASTINGS B7285 • HASTINGS LF113 • HIFLO HF198 • HIFLO HF204 • HIFLO HF303 • K & N KN-198 • K & N KN-204 • K & N KN-303 • K & N KN-303C • KAWASAKI 16097-0002 • KAWASAKI 16097-0003 • KAWASAKI 16097-0004 • KAWASAKI 16097-1058 • KAWASAKI 16097-1061 • KAWASAKI 16097-1063 • KAWASAKI 16097-1064 • KAWASAKI 16097-1066 • KAWASAKI 16097-1067 • KAWASAKI 16097-1068 • KAWASAKI 16097-1070 • KAWASAKI 16097-1072 • LUBER-FINER PH2876 • LUBER-FINER PH7015 • LUBER-FINER PH7028 • MELROE 6671057 • MERCRUISER 35-822626 • MERCRUISER 35-822626Q04 • MERCRUISER 35-822626Q1 • MERCRUISER Q03 • MERCURY 35-8222626Q03 • MERCURY G590000-G760299 • MERCURY G760300-1B226999 • MERCURY P086824-P325499 • NAPA 1358 • NAPA 1365 • NAPA PS1358 • Parts Master 61358 • POLARIS 2520799 • POLARIS 2540086 • POLARIS 3084963 • POLARIS 3089996 • Purolator ML16817 • Purolator ML16819 • ROBIN 2576730111 • SIERRA 18-7902 • SIERRA 18-7909 • SIERRA 18-7910 • SIERRA 18-7911 • SIERRA 18-7911-1 • SIERRA 18-7913 • SILVERLINE 21358 • STP PH7028 • TOHATSU (Marine) 3R0076150M • TRIUMPH MOTORCYCLE T1210200 • TRIUMPH MOTORCYCLE T1210444 • WARNER PH7015 • WESTERBEKE 30220 • Wix 51358 • Wix 51365 • YAMAHA 3FV-13440-00 • YAMAHA 3FV-13440-00-00 • YAMAHA 3FV-13440-10-00 • YAMAHA 5DM-13440-00 • YAMAHA 5GH-13440-00 • YAMAHA 5GH-13440-00-00 • YAMAHA 5GH-13440-10-00 • YAMAHA 5GH-13440-20-00 • YAMAHA 5GH-13440-50-00 • YANMAR 124450-35100 OE Part numbers matching this oil filter: • Honda 15400-P0H-305 • Honda 15400-P0H-305PE • Honda 15400-PFB-004 • Honda 15400-PFB-007 • Honda 15400-PFB-014 • Honda 15400-PJ7-015 • Honda 15400-PLM-A01PE • Honda 15400-PM3-405 • Honda 15400-POH-305 • Honda 15400-POH-305PE • Honda 15400-ZJI-004 • Honda 15400-ZW4-003 • Honda 15410-MCJ-000 • Honda 15410-MCJ-003 • Honda 15410-MCJ-505 • Honda 15410-MFJ-D01 • Honda 15410-MM5-013 • Honda 15410-MM9-003 • Honda 15410-MM9-013 • Honda 15410-MM9-405 • Honda 15410-MT7-003 • Kubota 15853-32430 • Nissan 3R0076150M
Eck Posted March 2, 2016 #11 Posted March 2, 2016 Eck - Thanks for the chart and I don't know if you use Honda filters or not but I have 6 or 8 Honda OEM oil filters that I have no need for - do you ? How much are you asking for them Hummingbird? (You can send me an email if you wish with your reply). I'm afraid that by the time I purchase them from you and then add the postage to get them here, that I may be paying more for them than what they would be worth... Also, here is a cross reference for the Honda 15410-MFJ-D01 oil filter : AC-Delco PF2135 AMSOIL EAOM103 ARCTIC CAT 3201-044 ARCTIC CAT 3201-451 AUTOEDGE AL6017A Baldwin B1400 Baldwin B7285 CARQUEST 85358 CARQUEST 85365 Champ PH2876 Champ PH7015 Champ PH7028 DENSO 115010-5390 Donaldson P502067 EMGO 10-26920 EMGO 10-82230 EMGO 10-82251 Fleetguard LF3925 Fram PH6017A HASTINGS B7285 HASTINGS LF113 HIFLO HF198 HIFLO HF204 HIFLO HF303 Honda 15400-P0H-305 Honda 15400-P0H-305PE Honda 15400-PFB-004 Honda 15400-PFB-007 Honda 15400-PFB-014 Honda 15400-PJ7-015 Honda 15400-PLM-A01PE Honda 15400-PM3-405 Honda 15400-POH-305 Honda 15400-POH-305PE Honda 15400-ZJI-004 Honda 15400-ZW4-003 Honda 15410-MCJ-000 Honda 15410-MCJ-003 Honda 15410-MCJ-505 Honda 15410-MFJ-D01 Honda 15410-MM5-013 Honda 15410-MM9-003 Honda 15410-MM9-013 Honda 15410-MM9-405 Honda 15410-MT7-003 K & N KN-198 K & N KN-204 K & N KN-303 K & N KN-303C KAWASAKI 16097-0002 KAWASAKI 16097-0003 KAWASAKI 16097-0004 KAWASAKI 16097-1058 KAWASAKI 16097-1061 KAWASAKI 16097-1063 KAWASAKI 16097-1064 KAWASAKI 16097-1066 KAWASAKI 16097-1067 KAWASAKI 16097-1068 KAWASAKI 16097-1070 KAWASAKI 16097-1072 Kubota 15853-32430 LUBER-FINER PH2876 LUBER-FINER PH7015 LUBER-FINER PH7028 MELROE 6671057 MERCRUISER 35-822626 MERCRUISER 35-822626Q04 MERCRUISER 35-822626Q1 MERCRUISER Q03 MERCURY 35-8222626Q03 MERCURY G590000-G760299 MERCURY G760300-1B226999 MERCURY P086824-P325499 NAPA 1358 NAPA 1365 NAPA PS1358 Nissan 3R0076150M Parts Master 61358 POLARIS 2520799 POLARIS 2540086 POLARIS 3084963 POLARIS 3089996 Purolator ML16817 Purolator ML16819 ROBIN 2576730111 SIERRA 18-7902 SIERRA 18-7909 SIERRA 18-7910 SIERRA 18-7911 SIERRA 18-7911-1 SIERRA 18-7913 SILVERLINE 21358 STP PH7028 Suzuki 16097-1072 TOHATSU (Marine) 3R0076150M TRIUMPH MOTORCYCLE T1210200 TRIUMPH MOTORCYCLE T1210444 WARNER PH7015 WESTERBEKE 30220 Wix 51358 Wix 51365 YAMAHA 3FV-13440-00 YAMAHA 3FV-13440-00-00 YAMAHA 3FV-13440-10-00 YAMAHA 5DM-13440-00 YAMAHA 5GH-13440-00 YAMAHA 5GH-13440-00-00 YAMAHA 5GH-13440-10-00 YAMAHA 5GH-13440-20-00 YAMAHA 5GH-13440-50-00 YANMAR 124450-35100
Hummingbird Posted March 2, 2016 Author #12 Posted March 2, 2016 Are these Honda's # 15410-MFJ-D01? If so and Eck is not interested. I could use them, or at least some of them, on my Honda ST1300 if the numbers match. why yes they are ! I have 5 of them and an EMGO chrome filter as well as the "cup" wrench to take them off. I must have used a couple of the filters on the Honda trikes I had last year. I don't need any of them unless the wrench fits the Purolater PL14612 filter.
T.J. Posted March 2, 2016 #13 Posted March 2, 2016 why yes they are ! I have 5 of them and an EMGO chrome filter as well as the "cup" wrench to take them off. I must have used a couple of the filters on the Honda trikes I had last year. I don't need any of them unless the wrench fits the Purolater PL14612 filter. I will wait for your response to Eck because he has first pick and then you can let me know how much and we will go from there. Thanks
Hummingbird Posted March 2, 2016 Author #14 Posted March 2, 2016 How much are you asking for them Hummingbird? (You can send me an email if you wish with your reply). I'm afraid that by the time I purchase them from you and then add the postage to get them here, that I may be paying more for them than what they would be worth... I think they're worth about $9 each on the retail market but then I'm not in retail. I have no idea how much it might cost to mail them to you but I would really like to sell the chrome wrench with the filters.
Kirby Posted March 2, 2016 #15 Posted March 2, 2016 Purolator PL14610 and PL14612 used to work but don't anymore. They changed the threaded end from concave to convex flange so now they won't seal the O-ring now. We had a long discussion about this several months ago.
Hummingbird Posted March 2, 2016 Author #16 Posted March 2, 2016 Purolator PL14610 and PL14612 used to work but don't anymore. They changed the threaded end from concave to convex flange so now they won't seal the O-ring now. We had a long discussion about this several months ago. What was the end result ?
Freebird Posted March 2, 2016 #17 Posted March 2, 2016 The end result was that they won't work anymore. I you have old ones with the concave bottoms they should be fine but not new ones with the flat bottom.
Du-Rron Posted March 2, 2016 #18 Posted March 2, 2016 What was the end result ? See here. http://www.venturerider.org/forum/showthread.php?101114-Purolator-PL14459-Oil-Filter&highlight=pl14459
Hummingbird Posted March 3, 2016 Author #19 Posted March 3, 2016 See here. http://www.venturerider.org/forum/showthread.php?101114-Purolator-PL14459-Oil-Filter&highlight=pl14459 Thanks Du-Rron, I guess I'll stick with purolater, just change the number.
Hummingbird Posted March 3, 2016 Author #20 Posted March 3, 2016 There was 2 people interested in the Honda filters I have but evidently I'm too greedy so if they have any value at all let me know before I throw them in the trash Friday.
Eck Posted March 3, 2016 #21 Posted March 3, 2016 I think they're worth about $9 each on the retail market but then I'm not in retail. I have no idea how much it might cost to mail them to you but I would really like to sell the chrome wrench with the filters. Go ahead and sell them to anyone who wants them buddy. It would be cheaper for me to just continue buying them locally when I need one I think. Many many thanks though for thinking of me!!
Hummingbird Posted March 3, 2016 Author #22 Posted March 3, 2016 You're welcome eck and thanks for the filter info
Du-Rron Posted March 3, 2016 #23 Posted March 3, 2016 There was 2 people interested in the Honda filters I have but evidently I'm too greedy so if they have any value at all let me know before I throw them in the trash Friday. Your Honda 15410-MFJ-D01 is the same filter as a Yamaha 5GH-13440-30 (40 & 50) which is the same as the PL14459.... Meaning you can use your current Honda Filters on your Yamaha RSV
djh3 Posted March 3, 2016 #24 Posted March 3, 2016 Purolator PL14610 and PL14612 used to work but don't anymore. They changed the threaded end from concave to convex flange so now they won't seal the O-ring now. We had a long discussion about this several months ago. Yup here is the thread for that. OK so with that being said I was in an Oreilies auto parts the other day and they had WIX filters on sale. So I grabbed the equivalent filter and it looks like it is made the correct way to use. Have not checked the Purolator to see if they changed it back or not.
T.J. Posted March 3, 2016 #25 Posted March 3, 2016 Your Honda 15410-MFJ-D01 is the same filter as a Yamaha 5GH-13440-30 (40 & 50) which is the same as the PL14459.... Meaning you can use your current Honda Filters on your Yamaha RSV Thanks for bringing that to my attention.
