jfman Posted January 31, 2016 #1 Posted January 31, 2016 Dumb move of the month: My new battery is still in the box so I borrowed the battery from my other bike to start the Venture but I was distracted and I reversed the poles. I put in on for a sec that I realized what had happened when it sparked at the pole. I put the battery on the correct way and there is no power anywhere. I looked at all of the fuses in the the fuse box and they all look good. I also looked at the big(main) fuse in the fuse box and it looks good as well and same for the lone fuse that is encased. What did I likely fry?
jfman Posted January 31, 2016 Author #2 Posted January 31, 2016 Ok guyz I figured out that the fuse I had fried was the fuse on the left (thin metal blade setup) That was the main fuse I guess. What is the cylindrical lone fuse to the right of the fuse box for then?
Prairiehammer Posted January 31, 2016 #3 Posted January 31, 2016 jfman said: What is the cylindrical lone fuse to the right of the fuse box for then? In a rubber in line fuse holder? If so, it is for the CLASS.
jfman Posted January 31, 2016 Author #4 Posted January 31, 2016 Ok I confused that one with the main fuse. Thanks!
jfman Posted February 1, 2016 Author #6 Posted February 1, 2016 Ozlander said: Does it charge now? YES
Marcarl Posted February 2, 2016 #9 Posted February 2, 2016 Just turn the bike around, then all should be alright I think :think:
Larry1963 Posted February 2, 2016 #10 Posted February 2, 2016 Prairiehammer said: In a rubber in line fuse holder? If so, it is for the CLASS. Second time I heard this term CLASS, so what is CLASS.
Larry1963 Posted February 2, 2016 #11 Posted February 2, 2016 jfman said: Dumb move of the month: My new battery is still in the box so I borrowed the battery from my other bike to start the Venture but I was distracted and I reversed the poles. I put in on for a sec that I realized what had happened when it sparked at the pole. I put the battery on the correct way and there is no power anywhere. I looked at all of the fuses in the the fuse box and they all look good. I also looked at the big(main) fuse in the fuse box and it looks good as well and same for the lone fuse that is encased. What did I likely fry? Safety Rule 2. Always, and we do mean always check the polarity of the battery before hooking up the leads.
Jayceesfolly Posted February 2, 2016 #12 Posted February 2, 2016 CLASS = Computer Leveling Air Suspension System. System only works with key in ACC position. See http://www.venturerider.org/forum/showthread.php?114508-Air-ride&highlight=class. for more info. See also: http://www.venturerider.org/forum/showthread.php?114778-Class-Air-Pressure&highlight=class
bongobobny Posted February 3, 2016 #13 Posted February 3, 2016 Larry1963 said: Second time I heard this term CLASS, so what is CLASS.CLASS is something 2nd Gen Ventures don't have! Yet another nice feature lost to Cheaper, Better, Faster (choose one)...
Larry1963 Posted February 3, 2016 #14 Posted February 3, 2016 Now I know, I learned something today, therefore I do not have to learn anything else LOL
