Venturous Randy Posted December 21, 2014 Share #1 Posted December 21, 2014 As part of my changeover to the MKII forks on 83, I am wanting to slide the forks up a little in the tripple tree. When I changed my springs to Progressives, even though I did not use any spacers on the springs, it raised the front of my bike up some. I will be transfering these springs and won't be using any air and wondering if any others had done this and what did they do about the holes where the air goes into the tube. I suspect the holes will be up under the clamped area, but feel they would still need some type of seal to keeping from leaking shock fluid. RandyA Link to comment Share on other sites More sharing options...
MiCarl Posted December 21, 2014 Share #2 Posted December 21, 2014 The holes should be closed off (air tight) somehow. Not only do you want to keep dirt out but the captured air acts as a spring. You want to look very carefully at whether the fender will hit anything when the forks are compressed. Link to comment Share on other sites More sharing options...
Marcarl Posted December 21, 2014 Share #3 Posted December 21, 2014 If I have it right, there is a ciriclip on the fork that sits right under the top part of the triple tree. This is there to prevent the fork from sliding any higher into the tree. You cannot clamp the tree tight enough to prevent movement, so the ciriclip is there so that the fork bottoms out. Somehow you would have to deal with that issue as well. Link to comment Share on other sites More sharing options...
MiCarl Posted December 22, 2014 Share #4 Posted December 22, 2014 The circlip is there to keep the air collar from sliding down. The trees will hold the fork in place. Link to comment Share on other sites More sharing options...
Venturous Randy Posted December 22, 2014 Author Share #5 Posted December 22, 2014 The circlip is there to keep the air collar from sliding down. The trees will hold the fork in place. That is what I was thinking. I was just getting ready to go out to the garage to check this out. I guess if I could remove the air collar and move it up that thickness, it would be as Marcarl stated. I don't think the tubes can be moved up much, or they will be hitting stuff above the tripple tree. RandyA Link to comment Share on other sites More sharing options...
MiCarl Posted December 22, 2014 Share #6 Posted December 22, 2014 Unless the motorcycle is now too tall for you I'd suggest you not do anything. It's not that the progressive springs raised the front, it's that they eliminated the drop caused by the old springs. If it is too tall, I'd look to modifying the seat before changing the suspension geometry. Link to comment Share on other sites More sharing options...
Venturous Randy Posted December 22, 2014 Author Share #7 Posted December 22, 2014 Unless the motorcycle is now too tall for you I'd suggest you not do anything. It's not that the progressive springs raised the front, it's that they eliminated the drop caused by the old springs. If it is too tall, I'd look to modifying the seat before changing the suspension geometry. You are probably correct on the spring height, it is just taller than it was before I changed them. As far as the seat, I have a Corbin that has been scooped out and is lower. I have put about 150,000 miles on this bike and just looking at some possible changes as part of my front end rebuild and was wondering if anyone had done this. Being inseam challenged can have its moments of frustration in those unsettling times when you are going over. RandyA Link to comment Share on other sites More sharing options...
dingy Posted December 22, 2014 Share #8 Posted December 22, 2014 High Heels may be the easiest. http://i1007.photobucket.com/albums/af193/gdingy101/heels_zps8609e308.jpg You may prefer more of a platform style. Gary Link to comment Share on other sites More sharing options...
Prairiehammer Posted December 22, 2014 Share #9 Posted December 22, 2014 High Heels may be the easiest. http://i1007.photobucket.com/albums/af193/gdingy101/heels_zps8609e308.jpg You may prefer more of a platform style. Gary O.M.G.! The image is permanently burned into my retinas. I think I will have to apply for SSDI, now. Link to comment Share on other sites More sharing options...
MiCarl Posted December 23, 2014 Share #10 Posted December 23, 2014 You may prefer more of a platform style. Gary If you decide to go that route make sure and get the matching riding gear: http://www.returnofkings.com/wp-content/uploads/2014/05/PM710126.jpg Link to comment Share on other sites More sharing options...
Venturous Randy Posted December 23, 2014 Author Share #11 Posted December 23, 2014 I have never seen a thread go this bad so quick in my life. RandyA Link to comment Share on other sites More sharing options...
dingy Posted December 23, 2014 Share #12 Posted December 23, 2014 Just offering suggestions to help you get the most out of your Venture. Gary Link to comment Share on other sites More sharing options...
Venturous Randy Posted December 23, 2014 Author Share #13 Posted December 23, 2014 Just offering suggestions to help you get the most out of your Venture. Gary And, I bet you want me to give you a "Thanks" for that don't ya? NOT!!!!!!!! RandyA Link to comment Share on other sites More sharing options...
dingy Posted December 23, 2014 Share #14 Posted December 23, 2014 No, but I bet you had the cursor over the "LIKE" button. Gary Link to comment Share on other sites More sharing options...
Marcarl Posted December 23, 2014 Share #15 Posted December 23, 2014 Is that your new riding partner Gary?? Link to comment Share on other sites More sharing options...
Venturous Randy Posted December 23, 2014 Author Share #16 Posted December 23, 2014 If you decide to go that route make sure and get the matching riding gear: http://www.returnofkings.com/wp-content/uploads/2014/05/PM710126.jpg See, that brought back another memory. As a teen of the 60's, I never got to wear bell bottom pants because when I bought them and had them shortened to fit, they were not bell bottoms any more. RandyA Link to comment Share on other sites More sharing options...
dingy Posted December 24, 2014 Share #17 Posted December 24, 2014 On a more practical note, you might be able to plug holes with JB weld, then file residue down smooth to block air ports, they are rather small. Guessing maybe 3/32" dia. You won't be able to raise forks much, maybe 3/4" before you have clearance issues with fairing. Then as mentioned above, you will run into clearence issue with fork brace when front end is full collapsed. Front end has 5 1/2" travel. I have a set of adjustable fork preload caps that wouldn't fit on Tweety, they are on Hybrid for now. Picture shows them, bike is dusty from where I blew insulation into garage attic & sidewalls a few weeks ago. Gary Link to comment Share on other sites More sharing options...
Venturous Randy Posted December 24, 2014 Author Share #18 Posted December 24, 2014 When I received this fork set, it had a really thick fork brace and I was wondering if that was going to be a problem on repositioning the tubes. RandyA Link to comment Share on other sites More sharing options...
