mike042 Posted September 17, 2014 Posted September 17, 2014 my full face helmet the kind that flips up in front has developed a squeak when lifting, and when im wearing it its like nails on a chaulkboard!!!! whats a good lub to put on hinges that wont eat the plastic or smell up inside of helmet?
kevin-vic-b.c. Posted September 17, 2014 Posted September 17, 2014 "white grease" you should be able to find it at auto parts stores. It is what is recommended for door hinges and alike as it can be cleaned off clothing. I buy it in spray form at Canadian Tire ..... Auto Zone, NAPA or similar in the USA I assume. and I guess the old 3in1 oil will do also... very fine light oil.
SilvrT Posted September 17, 2014 Posted September 17, 2014 Silicon spray lube works best on plastic parts.
Prairiehammer Posted September 17, 2014 Posted September 17, 2014 Typically, plastic on plastic is lubed with silicone. BTW, di-electric grease IS silicone. Most modern helmets, if not made of fiberglass, are composed of polycarbonate. A bad polycarbonate lubricant is any petroleum based lubricant. Petroleum based lubes may cause cracking.
ACE50 Posted September 17, 2014 Posted September 17, 2014 Silicon spray lube works best on plastic parts. every silicone spray that says it stops squeaks, I found just makes the squeaks worse.
ACE50 Posted September 17, 2014 Posted September 17, 2014 Typically, plastic on plastic is lubed with silicone. BTW, di-electric grease IS silicone. Most modern helmets, if not made of fiberglass, are composed of polycarbonate. A bad polycarbonate lubricant is any petroleum based lubricant. Petroleum based lubes may cause cracking. I was going to say that but it slipped my...........................what's that name for_______.
Dragonslayer Posted September 17, 2014 Posted September 17, 2014 http://www.tickld.com/cdn_image_article/a_861_20140914110406.jpg
SilvrT Posted September 17, 2014 Posted September 17, 2014 every silicone spray that says it stops squeaks, I found just makes the squeaks worse. It's not designed for creaking joints in humans ......
djh3 Posted September 17, 2014 Posted September 17, 2014 I guess its silicon. Anyways the stuff is sort of gel like and is for O rings. Got some for the pool strainer lids and such.
