EFM Auto Clutch
Cougar
Well My Basket is at EFM for the MOD now.
I also sent him all new steal plates and all new Barnett Carbon Fiber Disks
I had laying around and never installed yet.
Will post pic's and stuff later. this will be nice not
having to pull the clutch lever in at all. you can if
you want to. its about a 1/4 pull if you use it.
He is making it a bit different do to the weight of the Trike.
(adding more weight to something)
Will post pics of both baskets side by side when it arrives.
If this (groundhog day effect) will ever go away I will post
what I feel about this option. so much snow and ice for so long.
I also talked with Hannigan and they now make a parking brake
for the RSV Trike. OH MY !!! so many add-ons .
Jeff
EFM is right down the road from me. (On my way to work) We put one on a Roadstar, We didn't like it and took it off. The shims he has though, that come with the EFM worked on the Burnett and we got total lock up so, it wasn't a total loss.
Had it on for a few days, did not like the mannerisms of it. I guess if you had to you can get used to it. It just does not engage and disengage as one would like. I think we determined in our case it did not work like he said it would nor how the video shows. The part about the choice of using the clutch or not, we found to be not true. At least on our install. We could not sit at a light and Rev the engine without leaping into the intersection. At highway speeds it got real tricky backing out of it.
It's a little tricky to set up, we had the case off about ooooooo 8 times making adjustments with adding shims and stuff. It's trial and error. You could get lucky and get it right first time. I hope!
His shop has some of the neatest machinery, Thats for sure! It Is a cool clutch especially for someone who had a clutch hand limitation . My determination was it's best left for a trike. It would be ideal for a trike!
MOD is DONE... will be shipped out tomorrow...
( 1 day turn around )
Garry did a bunch of stuff even added extra holes for
more oil flow.... the other thing he mentioned is that
I remove the fluid from my clutch master cyl... and
a few other things I will get into later. this outta be
interesting . He ahs it set up pretty good for the Trike
he says. there are 34 steel balls in the plate and 6 titanium's
balls for the Trike Wight.
Will keep you posted , but should be able to test it in the garage I hope
be another month before I can ride tho. if I am lucky.
Jeff
Well, I was hoping, The guy is a genius, he has an incredible shop and going into a trike you made a great choice. Once you get it dialed in and get used to its manners you should be fine. I just don't advise it on two wheels. Unless for some reason you NEED it, like left hand don't work or whatever.
Let us know. Study up on the directions they are good, but do just as they say. Most time he will answer the phone. But he's not in a lot.
Pictures soon!
Yeah, Mike, It might be nice not to pull in the
clutch lever while in a turn on a trike for a change :-)
there IS tweaking to do for sure.
Just hoping this will work out !!
Soon Jay !!!
Some photos of the EFM auto clutch for you folks.
EFM
[ATTACH]82564[/ATTACH]
OEM
[ATTACH]82563[/ATTACH]
EFM Pressure Plate
[ATTACH]82567[/ATTACH]
And Installed and other stuff
[ATTACH]82565[/ATTACH]
NOTICE ALL THE EXTRA DRILLED HOLES ADDED for more oil to the clutch plates.
[ATTACH]82566[/ATTACH]
[ATTACH]82569[/ATTACH]
[ATTACH]82570[/ATTACH]
Wish me luck !!
The inners .....
[ATTACH]82734[/ATTACH]
(number 2 photo)
In this photo you can see the Titanium balls this will be the first one
to the left at the bottom from the CENTER steel ball, it will have a darker
tint to them , then count six over to see the next one.
[ATTACH]82735[/ATTACH]
[ATTACH]82736[/ATTACH]
[ATTACH]82737[/ATTACH]
Saving these pics to show folks later what things are about
if they need help.. so Far I just have to make one more adjustment
and I am loving it so far. really kicks in great.
My set-up is for Trikes ONLY..
There are 6 Titanium Balls in this set-up for the weight of the Trike.
When you hold the 2 different kinds you really can feel the weight differences.
2 wheelers will be just a little different.
More testing tomorrow after a adjustment. not sure if I have
to take the cover off yet.. I did do as a member told me to do
is to just oil around the gasket and it stays sealed just fine , this
way I can remove the cover and not ruin the gasket. seem so far
that there are no leaks. :-)
Another report to follow SOON.
OH I also had Garry make me another stronger cover plate that
the, 12 bolts on into. from .50 to .100 thickness.
Jeff
After talking a bit more with Garry,
I was not shifting in the right manner for the auto
clutch, you must let off the throttle just a tad then shift
for no slip. so the set-up was perfect from the get go.
The first time I road with it I was letting the RPMs drop as if you
used the clutch lever. (that will cause the slip)
I road more today and I absolutely love it.:D
So if anyone want to go this route for there trike it will
take a few miles to learn it. kind of like going from 2 wheels
to 3 wheels. I just wish It the roads and weather would get better
soon so I can really work this clutch harder.
I think the hardest part is not wanting to pull the clutch lever in all the time :)
I do think that it is a good thing for a Trike . Not sure for the 2 wheelers tho.
If you decide to go this route feel free to call me or email me in the future.
Now to add the Parking Brake.
  • 3 weeks later...
Only did a 30 mile ride just a while ago.
To test the new tires and get the Ride-On stirred up.
Tomorrow I will go for a longer ride I hope.
But so far the EFM auto Clutch works perfectly on my Trike.
I really enjoy it. so crazy not using the clutch lever..
more to follow!
  • 4 weeks later...
YES, I like it, still learning the down shifting part .
I think I almost have that figured out.
Garry the owner will make anything right but he is the
type of person that thinks that we should know what he
is talking about, his instructions are not to bad
but no pictures at all.
If you should decide to do this call me when your ready
and we can go over a few things.
Seems to work really well tho. still deciding if I want
to put my OEM clutch disk back in to see how they work.
I had some brand new Barnett Carbon Fiber disks laying
around so I tossed them in there. I did learn if you don't
use anything on the gasket for the cover you can removed
it several times :-) I do not have any leaks.
So for now I am keeping the set-up this way, only have about 200
miles on the EFM now, I just need to get more riding time in.
I have no future plans on going back to the stock clutch at this time.
As far as the parking brake its still in the (works).
Hannigan had a problem with the vendor that supplied
some of the machined parts and they said they do not
want to do the parts for them anymore. Soooo Hannigan
is having another company re-tool for the parts they need.
This HAS to be done as in Canada it is a law to have a parking brake
on there Trikes.
So I am thinking about another month for the parking brake.
For now I am using a looped Velcro on the front brake OR I just
use a little portable wheel chalk I have in the trunk. or park with
nose in against something LOL
I like what you have posted. I posted to your original post that the EFM may help. I don't have the EFM but a buddy does, on a two wheeler Venture, and he loves it.
Now I am looking at a trike, so I will give EFM a call when I decide which kit I will buy.
:farmer:
