Bert2006 Posted February 23, 2014 Share #1 Posted February 23, 2014 For those who did the HID conversion, where did you locate the ballast. Pictures would be great:bowdown: Link to comment Share on other sites More sharing options...
dacheedah Posted February 23, 2014 Share #2 Posted February 23, 2014 Mine is in the fairing on the left side looking from the front, I ran an extra ground wire to the battery to the HID, without it it caused noise on my radio. I have the upgraded ballast. Link to comment Share on other sites More sharing options...
Old Miner Posted February 23, 2014 Share #3 Posted February 23, 2014 Ditto that but with a sponge pad underneath. Link to comment Share on other sites More sharing options...
BoomerCPO Posted February 23, 2014 Share #4 Posted February 23, 2014 Mine is in the fairing on the left side looking from the front, I ran an extra ground wire to the battery to the HID, without it it caused noise on my radio. I have the upgraded ballast. Boomer....who sez HID iz de only way to light up de night... Link to comment Share on other sites More sharing options...
RedRider Posted February 23, 2014 Share #5 Posted February 23, 2014 Under the fairing. I used double sided tape and have not had a problem with several years and 10's of thousands of miles. RR Link to comment Share on other sites More sharing options...
dacheedah Posted February 23, 2014 Share #6 Posted February 23, 2014 And while you are in there, pull each electrical and intercom connector apart, inspect, clean if necessary and dielectric grease. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted February 23, 2014 Share #7 Posted February 23, 2014 In the trash. Along with the rest of the kit. Link to comment Share on other sites More sharing options...
k9cottage Posted February 23, 2014 Share #8 Posted February 23, 2014 on the left side with double sided tape only makes a noise in the radio when it is firing up it is my second one $19 from ebay the first one must have had a hole in it cause it let all the smoke out and we all know they won't work when there is no smoke in the box :-) Link to comment Share on other sites More sharing options...
BradT Posted February 24, 2014 Share #9 Posted February 24, 2014 Boomer....who sez HID iz de only way to light up de night... Agree ! On the left side with two sided tape. Not coming of without a knife. BRad Link to comment Share on other sites More sharing options...
wes0778 Posted February 24, 2014 Share #10 Posted February 24, 2014 In the trash. Along with the rest of the kit. :sign yeah that::sign yeah that: Link to comment Share on other sites More sharing options...
dacheedah Posted February 24, 2014 Share #11 Posted February 24, 2014 Definately see deer at night much better, cleaner light than the halogens Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted February 24, 2014 Share #12 Posted February 24, 2014 Get an E-code headlamp housing for that HID if you decide to keep it. Oncoming drivers will thank you. Link to comment Share on other sites More sharing options...
djh3 Posted February 24, 2014 Share #13 Posted February 24, 2014 I mounted mine on the left side with the thin metal bracketry they sent in kit. I carved it up so it would work using the mount scres for some piece of electronic equip under the faring. Link to comment Share on other sites More sharing options...
Bert2006 Posted February 24, 2014 Author Share #14 Posted February 24, 2014 Thanks guy's, looks like left side it will be. I am actually putting in an LED kit, but it has an electronic module that is separate from the lamp. Similar conection set-up as HID. Link to comment Share on other sites More sharing options...
djh3 Posted February 24, 2014 Share #15 Posted February 24, 2014 Cant remember now if I had just the one bracket you can see or if it is secured by another lower. Pretty sure I would have secured it down and not allowed it to flop around. Link to comment Share on other sites More sharing options...
mcgwire723 Posted March 4, 2014 Share #16 Posted March 4, 2014 dacheedah: Was the radio noise you are referring to background static? My 12 RSV had a HID installed when I got it, but it also has annoying static in the head sets. Thanks Link to comment Share on other sites More sharing options...
Atoolnut Posted March 4, 2014 Share #17 Posted March 4, 2014 Get an E-code headlamp housing for that HID if you decide to keep it. Oncoming drivers will thank you. What is e code housing and where to buy it Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted March 5, 2014 Share #18 Posted March 5, 2014 (edited) What is e code housing and where to buy it Just google e code headlamps...I got mine on Amazon but they seem to only sell them in pairs. There are other vendors who sell them. They ARE legal in the USA for motorcycles. On low beam, (when adjusted properly) they have a sharp cutoff at the horizon to the left, and a 'lift' of light to the right for lighting up signs. The cutoff means your new HID light wont be blinding oncoming drivers. And they put all the light from your headlight on the road in front of you where it belongs. The Hella units that I use, also have a VERY slight blueish tint to the reflector...this makes a standard H4 Bulb look less yellowish. It will look a lot better even with a regular H4 bulb. I think the better solution is to install a standard H4 bulb with e-code housing than to waste your money on a cheap HID unit that might make RFI hash on your radio, might fail either in the bulb or ballast, and will put out offensive glare to oncoming drivers. The last thing I want on a dark lonely road at night is a 4-wheeler coming at me doing 80mph and who cant see the center line. http://headlightservices.com/Headlamps.html http://headlightservices.com/FAQs.html Edited March 5, 2014 by tx2sturgis Link to comment Share on other sites More sharing options...
