Keysyrider Posted December 2, 2013 Posted December 2, 2013 Finally I am going to mount my draggers on the floorboards. Should be a lot of fun at night. http://www.gmanindustries.com/shop/pc/viewPrd.asp?idproduct=841
wrenchrob Posted December 2, 2013 Posted December 2, 2013 I like those.. Sounds like another project for this winter. I wonder if I can make a set. Will hve to think about this one. Thnks for the iddea
Jimbob66 Posted December 2, 2013 Posted December 2, 2013 Finally I am going to mount my draggers on the floorboards. Should be a lot of fun at night. http://www.gmanindustries.com/shop/pc/viewPrd.asp?idproduct=841 These are super cool looking on the twisties at night. Couple of things though .. If you ever ride with someone it is VERY distracting to the fellow behind you. I found this out the hard way on our last organized ride. I also saw the exact same fellow snag one on a manhole lip coming out of the hotel. He lost about 3/4 of the floorboard in the middle of the street and had to ride back to New Orleans (From Kentucky) with a little stub for a footrest. Just a few things to think on. They do put on a great show though!
Triple J Posted July 5, 2015 Posted July 5, 2015 With all the cracks on the crappy roads here in MN, I see bad things happening.
Flyinfool Posted July 5, 2015 Posted July 5, 2015 I think I would deepen the undercut at the base of the thread so that there is a designed failure point if it should snag on something in the road. pure titanium, grade 2, 99.2% TI, rod can be bought for $126 for a 1 foot bar, 1 inch dia, gets less expensive as quantity increases. (I only looked at the first supplier that came up on google.) It would not be real hard to turn down the end, thread it and cut to length. Higher strength grade 5 is 90% TI and is actually less expensive at $109 per foot, but harder to machine.
slowrollwv Posted July 5, 2015 Posted July 5, 2015 I think I would deepen the undercut at the base of the thread so that there is a designed failure point if it should snag on something in the road. pure titanium, grade 2, 99.2% TI, rod can be bought for $126 for a 1 foot bar, 1 inch dia, gets less expensive as quantity increases. (I only looked at the first supplier that came up on google.) It would not be real hard to turn down the end, thread it and cut to length. Higher strength grade 5 is 90% TI and is actually less expensive at $109 per foot, but harder to machine. Soooo how many sets can you get per foot??????????????
Flyinfool Posted July 5, 2015 Posted July 5, 2015 They are about 1.5 inches long. So a set would take 3 inches. So about 4 sets per foot. Might have to make a few sets to get the designed fail point correct. So the the TI would brake away before any damage to the bike or rider.
Eck Posted July 5, 2015 Posted July 5, 2015 That's what my foot pegs and crash bars look like when I go around curves........
djh3 Posted July 5, 2015 Posted July 5, 2015 The 900 vulcan had holes under the floorboards. I guess manufacturing pickup point or something. Anyways on this tab under the boards was a hole and guys were taping them out and putting soft grade bolts in them for the same effect. 1/4x20 soft bolt from hardware store about .08 each.
