hell yea Posted November 26, 2013 #1 Posted November 26, 2013 any ideas fond this in my box off venture:confused24: parts
Huggy Posted November 26, 2013 #2 Posted November 26, 2013 Looks like a lead for some sort of owner added accessory.
Kirby Posted November 26, 2013 #3 Posted November 26, 2013 Looks like a quick connection for a battery charger. Wire it up to your battery then all you do is plug in the connection to the charger.
Black Owl Posted November 26, 2013 #4 Posted November 26, 2013 Quick connect for battery charger. Or a piece of wire thingy to drive Bubber crazy....
bongobobny Posted November 26, 2013 #5 Posted November 26, 2013 Uhhh, no, that's shrink tube on the end of a filter capacitor, not a connector. It's for noise suppression for the radio but by the size of it it probably isn't very effective... Or maybe it's an LED. We need bigger picture of the black end and different angles...
ragtop69gs Posted November 26, 2013 #6 Posted November 26, 2013 Looks like the blasting cap for the ejection seat. HANDLE IT WITH CARE !
Eck Posted November 26, 2013 #7 Posted November 26, 2013 (edited) It looks more like the quick disconnect / connector for a heated vest or some type of clothing to me . It sure don't look like a battery tender cord. The ends of battery tender cords are "off set" in length with male/female ends \ Edit: I have to agree with Bongobobny (below post) in that it appears to look more like a capacitor ...the end would not plug into a heated garment as I originally thought. Edited November 28, 2013 by Eck
CaptainJoe Posted November 26, 2013 #8 Posted November 26, 2013 Looks like a 12 volt connection to an adult accessory. Wait a minute... only Harley riders use those...:stirthepot:
Kirby Posted November 26, 2013 #9 Posted November 26, 2013 Ok, I agree with the others, not a connection for battery charger. Maybe it's what my grandaddy always told me. When I asked about things, he would always say, "It's something to make little boys like you to ask questions".
hell yea Posted November 27, 2013 Author #10 Posted November 27, 2013 so far the radio suppressor is the best bet but im cluless when it cums to electrical s
bongobobny Posted November 28, 2013 #11 Posted November 28, 2013 Yah, just install it across your battery. It should not draw any current at all. How a capacitor works: A capacitor is just two pieces of tin foil separated by an insulator, and then rolled up into a cylinder. Each piece of foil has a lead attached to it. When you hook it up to a battery each piece of foil becomes the same voltage as what it is connected to. Once charged up, which only takes a few milliseconds, these pieces of foil tend to keep the exact same voltage difference between them. When you initially turn any device on, the battery voltage "spikes" or changes for a split second. The capacitor will resist this change in voltage and reduce the spike. These spikes can make a noise in the audio system. What you have, if it is indeed a filter and not a light, isn't very big and will probably have very little effect. Most noise capacitors for good noise filtering are more like the size of a flashlight...
hell yea Posted November 28, 2013 Author #12 Posted November 28, 2013 its definitely not a light seams to be solid metal under the heat shrink :confused24:its a triky one
bongobobny Posted November 28, 2013 #13 Posted November 28, 2013 Yup! Small filter capacitor for noise then...
Rolltide Posted November 28, 2013 #14 Posted November 28, 2013 Looks like the plug for the flux capacitor ..............this is what makes time travel possible:12101:
hell yea Posted November 29, 2013 Author #15 Posted November 29, 2013 was wandering why i was stuck in the 80s
paysaw Posted November 29, 2013 #16 Posted November 29, 2013 It could be a hum-bucking coil on the end of a power cable to an audio device.The black case could be where the fuse goes.There could be the other part of the fuse holder with cables missing.
Huggy Posted November 30, 2013 #18 Posted November 30, 2013 Come on now!! Whats wrong with you guys anyway??? It's plain to see that its thingumabob for the doohickey that keeps it from becoming a Hardley!!!!
KIC Posted November 30, 2013 #19 Posted November 30, 2013 Nope...no DooHickey on the Venture... the only bike I know that officially has a DooHickey is the Kawasaki KLR650. And I have the special tools to remove and fix the DooHickey !!
Karaboo Posted November 30, 2013 #20 Posted November 30, 2013 That looks like a part of this replacement cable from Sierra. Look at the bottom of the picture. http://www.sierra-mc.com/proddetail.asp?prod=JM-YV-41
Eck Posted November 30, 2013 #21 Posted November 30, 2013 Karaboo said: That looks like a part of this replacement cable from Sierra. Look at the bottom of the picture. http://www.sierra-mc.com/proddetail.asp?prod=JM-YV-41 I think Karaboo wins the contest here...I agree it is the same as the cord in the bottom picture. Let us know what the winning prize was..............
bongobobny Posted December 1, 2013 #22 Posted December 1, 2013 Yuop !! that;s the critter!! Meant to eliminate or minimize noise inn the intercom!!
hell yea Posted December 3, 2013 Author #23 Posted December 3, 2013 Karaboo's Avatar Karaboo Karaboo is offline 1990 XVZ13DA;1982 XS650SJ Karaboo has a Profile Picture Supporting Member Join Date: Apr 2013 Location: Find Karaboo on Google Maps! Colfax United States WI Default That looks like a part of this replacement cable from Sierra. Look at the bottom of the picture. http://www.sierra-mc.com/proddetail.asp?prod=JM-YV-41 __________________:cool10: yep have the rest of that kit as well well dun
Huggy Posted December 3, 2013 #24 Posted December 3, 2013 Karaboo wins a real live RED SQUIRREL!!!!!!!
