Hi again,
I've had my '02 for a week and am having questions:
To get the intercom to work from my helmet to my girl's, is all I need a headset like this in each of our helmets?
http://www.jmcorp.com/linkpix/HS-8154B-FF-L.jpg
Thanks in advance!
Danny
You are welcome sir, just got some for our bike, we have composite helmets so used the ones with boom mikes. I did not buy the most expensive ones from J&M. They work great for intercom, but so so for music. :322:
When you install them, it may require some cutting of the foam. If the speakers are pressing on the ears they will become painful in a short period of time.
RR
Intercom system....Ya gotta be kidding right?????
Boomer....who sez de wife is a lot less noisy and de ride is more peaceful without a Intercom system on de scoot....:rotf:
Once you plug them in you will have to adjust the volume by the control on the left handle bar. I think its the middle switch. Just sort of tab thru until it says IC then you use the up/down lever to adjust the inter com volume. However the higher you go the more background "swoosh" you get. The mic is "open" all the time. It kills my ears so I put a couple of puch to talk switches inline on mine. they were like $30 ea. Cheaper than the mic mutes thing.
I have a pair of Yamaha (made by J&M) headsets for full face helmets I'd like to sell...installed briefly and removed so the sticky backed Velcro isn't included. Took 'em out because I did not like the cords and moved the Scala headsets to the new helmets.
$250 for both, shipped in US.
As a side note. If you have the IC vol set up so you can hear the intercom you may also notice an increase in road noise. Since the IC is 'always on' the mic's can pick up and amplify all sorts of extraneous noises. Just something for you to be aware of.
Mike
You can get the velcro at any hardware and cut to size.
