rbig1 Posted May 25, 2013 Posted May 25, 2013 pulled radio apart today. found two chewed up wires repaired them and disassembled the rest of connectors sanded and lubed all. hooked up head set that came with bike. nothing so cleaned all connectors where they plug in all joints. played with them till all worked. my problem is you have to eat the mic to get sound out of it. if you blow on it will stop radio but have to put in mouth to get voices thru. how do ya clean microphone:think:
DragonRider Posted May 25, 2013 Posted May 25, 2013 There is a mute button for volume, it may be muted. pulled radio apart today. found two chewed up wires repaired them and disassembled the rest of connectors sanded and lubed all. hooked up head set that came with bike. nothing so cleaned all connectors where they plug in all joints. played with them till all worked. my problem is you have to eat the mic to get sound out of it. if you blow on it will stop radio but have to put in mouth to get voices thru. how do ya clean microphone:think:
rbig1 Posted May 25, 2013 Author Posted May 25, 2013 is that on radio. the red button and the one beside it isnt marked any more. i know the far one changes station. not real sure about next row am fm button wont work yet think the one next to it is loc- distance
bongobobny Posted May 25, 2013 Posted May 25, 2013 No, the mute button is where the volume control and tone control is... EDIT The red button is for setting the push buttons.
MiCarl Posted May 26, 2013 Posted May 26, 2013 There is no mute button for the mike on a stock system. What are you checking the mic with? Mic is for intercom or CB transmit, you won't be able to hear it through dash speakers.
rbig1 Posted May 26, 2013 Author Posted May 26, 2013 trying to talk back and forth with each other. in helmets with radio playing in helmets. stops music. but mic has to be on lips for it to come through other helmet. otherwise stops music but no voice. dont have cb on bike but all the wiring and switches are there just no unit.
playboy Posted May 26, 2013 Posted May 26, 2013 Have you pulled the foam cover off to see which way the mic is facing.
painterman67 Posted May 26, 2013 Posted May 26, 2013 IC volume is set to ? Mike I was thinking the same thing
rbig1 Posted May 26, 2013 Author Posted May 26, 2013 if the ic volume is on right bottom had it all over the scale. dont have the covers for any of the mics or ear pieces.
pmelah Posted May 26, 2013 Posted May 26, 2013 how many pins does the head set plug have do you 4 pin or 5 pin may have wrong type head set as i think you have to have a powered mic 5 pin din plug or it may be 5 pin no power 6 pin power but i could be wrong been a long long time(24 yrs.) since i messed with mics and radio head sets
saddlebum Posted May 26, 2013 Posted May 26, 2013 Try another head set that you know is working. Then you can a least narrow it down to the head set or the bike. Also check and make sure you have proper SWR match on the CB antenna. Or even if the antenna is a CB antenna. I have seen cases were the antenna was replaced, but by one from another bike that did not have a CB installed on the bike. The two antennas look and fit the same except that the CB model has a loading coil approx. 1/2 way up the antenna while the none CB one has no loading coil and is just a simple antenna.
