star4772 Posted August 23, 2012 Posted August 23, 2012 RSTD no stereo. I want to set up and use my sirius radio system. I will have speakers in front on handle bars and in speaker pockets on trunk. Question is what do I need to power my sirius radio to work (besides 12 volt socket) Will I have to install a stereo with an aux output or can I get something that will work other then a stereo that can be tucked away and out of site. Any suggestions? Joe
Eck Posted August 23, 2012 Posted August 23, 2012 You should not need anything else.. The stereo SHOULD already have a 12 volt hot wire, a ground wire, and most likely 4 speaker wires. Solder all connections, and use shrink tape to seal them from the elements.. Instructions should also come with the unit of which I would read first prior to installing..
sarges46 Posted August 23, 2012 Posted August 23, 2012 You could just get a smallish mp3 player that has a AM/FM radio built in and use the sat. radio to send its signal to that and use the small ear buds.
friesman Posted August 23, 2012 Posted August 23, 2012 I just use the Scala headsets with FM radio and a jack to hookup an mp3 player. No need to hook anything up and with the speakers in the helmet you still hear traffic around you.. I also use a Garmin 765t gps with its fm transmitter turned on so I get the directions to the headset, but the gps unit also has a slot for an sd card that I fill with music and stream it to my headsets using the FM transmitter in the GPS and then set the Scala headset to recieve that frequency.. No wires, nothing to install on the bike. brian
BradT Posted August 24, 2012 Posted August 24, 2012 My first suggestion was that maybe you should have purchased the venture instead of the RSTD but that would not be nice, would it ??? I think your going to need an amp as I doubt there is enough power to power speakers so that it sounds decent, but I may be wrong. Another option is too use a J&M CB and run it through the headset vs the speakers. Have fun and hope you get the sound your looking for Brad.
star4772 Posted August 24, 2012 Author Posted August 24, 2012 My first suggestion was that maybe you should have purchased the venture instead of the RSTD but that would not be nice, would it ??? I think your going to need an amp as I doubt there is enough power to power speakers so that it sounds decent, but I may be wrong. Another option is too use a J&M CB and run it through the headset vs the speakers. Have fun and hope you get the sound your looking for Brad. Thanks BRADT yes maybe RSV would solve everything but wanted to be differant this time. My first thought was J&M I might still go that was. Joe
Freebird Posted August 24, 2012 Posted August 24, 2012 I agree with Brad that you will need some type of amp. You would think that somebody would make something for just that purpose and they probably do but I did a Google search after seeing your post and didn't find anything.
ragtop69gs Posted August 24, 2012 Posted August 24, 2012 Joe, Take a look at these. http://www.bossaudio.com/off-road-products/amplifiers/
Freebird Posted August 24, 2012 Posted August 24, 2012 There you go. Something like that is exactly what I had been trying to find. I knew somebody must make something to do what you wanted.
star4772 Posted August 24, 2012 Author Posted August 24, 2012 Joe, Take a look at these. http://www.bossaudio.com/off-road-products/amplifiers/ I was looking at something like that on E-Bay would that amp with the aux output allow me to run my sirius radio? Joe
Freebird Posted August 24, 2012 Posted August 24, 2012 I don't know what you saw on Ebay but probably. I looked at the specs on the one posted and it has a 1/8" output jack. That means you can use a 1/8" patch cord from the output of your Sirius unit, Ipod, whatever and feed it right into that amp and then to your speakers. So if you see one on Ebay and it has the stereo jack, it should work just fine.
eusa1 Posted August 24, 2012 Posted August 24, 2012 do a search for amplified speakers, you can buy them with an amp inside them just like computer speakers have.
ragtop69gs Posted August 24, 2012 Posted August 24, 2012 (edited) I was looking at something like that on E-Bay would that amp with the aux output allow me to run my sirius radio? Joe Yes it will Joe. Mickey Shorr sells them and a similar one by another maker. I think it was about $120 - $140 and came with speakers that sounded pretty good. It is small and would not take much room in the tour pack. The MC500 is what I saw in the show room. Edited August 24, 2012 by ragtop69gs
