dharnie Posted January 14, 2008 Share #1 Posted January 14, 2008 Front lighting on a budget. I like other drivers to see me at night and day! They are not the RSV classic look and add nothing to value of bike. I spent only $35 on these from WalMart. Mounted on front side reflector brackets (removed reflectors) and fork shield brackets. Link to comment Share on other sites More sharing options...
eagleeye Posted January 14, 2008 Share #2 Posted January 14, 2008 Looks lit up to me--------------- I see a headlight and 4 other lights. Which are you talking about? Do have more tech info on the lights? Steve Link to comment Share on other sites More sharing options...
KiteSquid Posted January 14, 2008 Share #3 Posted January 14, 2008 Could you please post a photo that details the mounting of the lights. I have a set of inexpensive lights I have not yet mounted but would like to put them in a similar location as you did.... Link to comment Share on other sites More sharing options...
Black Owl Posted January 14, 2008 Share #4 Posted January 14, 2008 Nice set up. Hopefully that will get the cagers attention.... Link to comment Share on other sites More sharing options...
steinbjg Posted January 14, 2008 Share #5 Posted January 14, 2008 Need more information on the lights mounted on the side reflector mounts. Link to comment Share on other sites More sharing options...
Grandpagak Posted January 14, 2008 Share #6 Posted January 14, 2008 NICEEEE...... Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted January 14, 2008 Share #7 Posted January 14, 2008 Wonder how long the stator and battery will tolerate that! Link to comment Share on other sites More sharing options...
AKRefugee Posted January 14, 2008 Share #8 Posted January 14, 2008 Been looking at a similar set up. Can you post some close up daylight pics of the mounting? Link to comment Share on other sites More sharing options...
Color01 Posted January 15, 2008 Share #9 Posted January 15, 2008 I also like to see the brackets. Link to comment Share on other sites More sharing options...
flb_78 Posted January 15, 2008 Share #10 Posted January 15, 2008 5 lights could net ya a ticket from Barney Fife. There is a limit on how many you can run in many states and the amount of light they emit. You shouldn't have a problem during daylight hours, but at night, I believe you'll have a problem if you keep them all on with oncoming traffic. Link to comment Share on other sites More sharing options...
dharnie Posted January 15, 2008 Author Share #11 Posted January 15, 2008 I edited on my 1st post with more pics for those who requested it and who are following this post. Link to comment Share on other sites More sharing options...
AKRefugee Posted January 15, 2008 Share #12 Posted January 15, 2008 Thanks for the additional pics. Picked up some similar lights at Wally World and have been thinking about that same spot on the deflector for mounting mine. Any noticeable bouncing of the lights at night? Link to comment Share on other sites More sharing options...
Color01 Posted January 16, 2008 Share #13 Posted January 16, 2008 Front lighting on a budget. I like other drivers to see me at night and day! They are not the RSV classic look and add nothing to value of bike. I spent only $35 on these from WalMart. Mounted on front side reflector brackets (removed reflectors) and fork shield brackets. how much light do you have from the smaller lights that you have mounted on the reflector brackets. ? and did you connect them to the headlight or did you use a switch. ...because I hate to take the fairing apart. Link to comment Share on other sites More sharing options...
dharnie Posted January 16, 2008 Author Share #14 Posted January 16, 2008 have the lowest ones pointing low like fog lights. the upper ones come close in the middle just under headlight. use the garage wall for adjustments. gives me extra lighting BUT idea was to BE seen which is excellent results ran wires hidden along brake lines and found a switched wire under tank. no need to remove fairing comes on with headlights - did not use supplied optional switch. * also I used one of the inline fuses supplied with each set of lights and tied all 4 lights to it Link to comment Share on other sites More sharing options...
Guest BluesLover Posted January 16, 2008 Share #15 Posted January 16, 2008 I've been thinking of adding lites at the lower level as you have done. What type/brand did you use for the lowers? I like the looks of that set up. Cheers, Link to comment Share on other sites More sharing options...
dharnie Posted January 16, 2008 Author Share #16 Posted January 16, 2008 fib 78 - just to let you know Barney Fife gave me a hi-by. he was on his HD patrol bike with a mask over his mouth/chin since it was in 30+ degrees in AM and as he passed me he knodded his head & thumb up and Of course I was cool and acknowledged him back. He had to see the lights! Link to comment Share on other sites More sharing options...
dharnie Posted January 16, 2008 Author Share #17 Posted January 16, 2008 blues lover - they are no special brand - all 4 lights are 55watts each. heck even if 2 were monted it still gives plenty of visability both ways! Link to comment Share on other sites More sharing options...
Color01 Posted January 16, 2008 Share #18 Posted January 16, 2008 I've been thinking of adding lites at the lower level as you have done. What type/brand did you use for the lowers? I like the looks of that set up. Cheers, He used the lights from walmart. Link to comment Share on other sites More sharing options...
dharnie Posted January 17, 2008 Author Share #19 Posted January 17, 2008 Will be installing switch this weekend to be able to turn off the lights. Too much drain on battery with key on & engine not running and my battery is only 2 weeks new! Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted January 17, 2008 Share #20 Posted January 17, 2008 Will be installing switch this weekend to be able to turn off the lights. Too much drain on battery with key on & engine not running and my battery is only 2 weeks new! Well...I hate to say I told ya so...but.... Link to comment Share on other sites More sharing options...
dharnie Posted January 21, 2008 Author Share #21 Posted January 21, 2008 questions were posted whether battery could handle extra current needed for lights - the answer is no it cannot. after I charged the battery I took my wife for her 1st ride on my recently aquired RSV. I was fortunate enough to find a neighbor less than a mile from where the bike died and was able to jump it to ride it home instead of it being towed! Can the lights withstand the vibration mounted on lower part of fork? No as can be seen from pic. Next is to spend the xtra bucks to get the tried & proven after-market light bar! I am thinking of adding 2 xtra tail/brake lights that use the same 1057 dual element bulb that is the standard Yamaha bulb. My questions - anyone ever have any battery drain from: 1 - using the passing lights? 2 - using any other rear tail/brake or running lights? Link to comment Share on other sites More sharing options...
Freebird Posted January 21, 2008 Share #22 Posted January 21, 2008 I have the OEM Yamaha passing lamps and on the rear, the Harley tail light/license plate bracket assembly. I'm also running the Pilot LED under the trunk. I've been running this way for about 7 years with no problems. Passing lamps are usually on all the time. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted January 21, 2008 Share #23 Posted January 21, 2008 Hey dharnie...most of the folks on here already know what you found out....you cant run lots of electrical accessories on the Venture and expect it to survive. I'm thinkin that some of us MAY have been amused that you had the cajones to just go ahead and hang as many lights as a 747 has on it on your bike. The stator and battery will handle the stock loads, plus SOME added goodies, but you cant go hanging multiple high wattage lights on it! You can do a search thru the forums, using search terms such as, stator, watts, capacity, etc, and you will find some pertinent info. In brief, it seems we are limited by the stator and battery to a couple of passing lights, 35watts each, a heated vest, heated gloves or grips, and a couple of extra low-current goodies, like a GPS, satellite radio, or maybe some small extra brake or running lights. Not a heckuva lot more than that, though. There are some ways to 'gain' some capacity, if you feel you need to. The first, is to reduce the running amps, by converting some or all of your lighting(other than the headlight) to LED type lighting. This will save SOME current. The other is to upgrade the stator, which will cost a few hundred dollars, and get you some more amperage, but the jury is still out as far as reliability issues. Another way some people 'cheat' and save some wattage is to disconnect the carb heaters, they draw about 60 watts. I have not done this, so I cant speak to how it affects the rideablilty. One other way to gain some surplus current, and at the same time increase forward visibility, is to install a headlight modulator. These will cost around a hundred dollars, or less, and reduce the headlight drain by an average of about 2 amps, when on. You cant run a modulator at night, so the savings is not there when you may need it most for running other lights, but it does slightly lessen the load on the battery and stator when in use. I have installed the Kisan headlight modulator, Radiantz LED brake/tail lamp and Hot Grips brand heated grips, along with my Widder heated vest that I run when its cold. I also have installed a Kisan Charge Guard battery monitor, and so far, all is well...that is, when I can ride, since between work and the cold weather, its been hard to get more than about 200-500 miles a month on the bike recently. Heres hoping you settle on a reasonable amount of forward lighting. And oh yeah, buying cheapo hardware is actually more expensive in the long run. But you knew that, right? Let us know how it goes. Link to comment Share on other sites More sharing options...
AKRefugee Posted January 22, 2008 Share #24 Posted January 22, 2008 Wow what an informative thread. dharnie, thanks for the follow up on the results. Sorry about your expense but will say saved me a lot of work and cost here. Thanks to every one else. As always I am learning a lot about this ride very quickly from the info you all provide. Link to comment Share on other sites More sharing options...
