Royal Star Posted March 24, 2011 Posted March 24, 2011 Commuting to work today about 65 mph with cruise control on and felt a slight hesitation and then a very loud squeal. Pulled over to the shoulder to check things out. Did not see anything abnormal. Got rolling again and when I started passing 40 MPH the sound came back again and the entire bike seemed to be very rough. Called a tow truck and had the bike dropped off at the shop. The shop could not find anything wrong. Anyone else ever experience this? I suspect the front brakes were binding or a bad bearing. Shop said the brakes and bearings were good. John in San Diego
Reddog170 Posted March 24, 2011 Posted March 24, 2011 I had an old Honda that made a squealing sound at higher speeds, turned out to be in the shaft drive. Do not know if that will help out here but it is a thought. Shaun
FreezyRider Posted March 24, 2011 Posted March 24, 2011 My last RSV did this.....it would come and go. Couldn't figure out what it was, but it sounded like it was coming from the area of my left foot. One night coming home from supper it started squealing really loud, and my wife said she thought it was coming from the back, not from the front....even though it still sounded to me like it was from my front left. Well, I put it up on my lift, started it up and began running through the gears. It was immediately obvious that it was coming from the rear end. I started tearing into it expecting to find that the rear drive had a bad bearing, but instead found it to be the rear wheel bearing on the right side. Nothing there but bits and pieces. I could not believe that it was still driveable with a bearing being that bad. New bearings on both sides solved the problem. Don't know if yours is similar, but is something to check. Joe
Eck Posted March 24, 2011 Posted March 24, 2011 Qout):....found it to be the rear wheel bearing on the right side. Nothing there but bits and pieces. Seen this before myself....squeels like heck too...
Royal Star Posted March 25, 2011 Author Posted March 25, 2011 Thanks everyone for the ideas on the cause of the squeal. Even after the shop took the bike out for a high speed ride, they could not duplicate. Sounds like having the wheel bearings changed out would be a good mitigation strategy. John
