XV1100SE Posted January 24, 2011 Share #1 Posted January 24, 2011 (edited) I'm considering getting passing lights for my '09 RSV and not sure what you get when you order them. I see that the passing lights requires mounts as well. If someone can clarify.... Passing lamps -STR-4XY35-10-00 => are these JUST the lights? Passing lamp mounts - STR-3XY35-40-00 => is this the bar that the lights and turn signals attach to? Where do I get the recommended "spacer" from? Not sure I want the OEM lights if there is a better looking and more functional option. Is the Rivco 4" 55/60w a good choice? www.cruisercustomizing.com/detail.cfm?model_id=42&Category_ID=49&manufacturer_ID=11&product_ID=36682&related=short Also... for the switch, has anyone used the Show Chrome accessory block? http://www.canadamotorcycleaccessories.com/Dual_Accessory_Switch_Block_1_inch_Cruiser_Bars_P24870.php Edited January 24, 2011 by XV1100SE added Rivco 4" 55/60 option Link to comment Share on other sites More sharing options...
bongobobny Posted January 24, 2011 Share #2 Posted January 24, 2011 To answer your first question, yes those are just the lights, you have to also order the mounting arm. Spacers should be acquired at any hardware store... Link to comment Share on other sites More sharing options...
bongobobny Posted January 24, 2011 Share #3 Posted January 24, 2011 Now, I just clicked on the link for the Rivco, and I don't think those will mount on the light bar.. Link to comment Share on other sites More sharing options...
ahoutzer Posted January 24, 2011 Share #4 Posted January 24, 2011 If you are referring to the spacer block that is used to hold the light bar further away from the fairing, to make fairing front removal easier, I have one. I recently lost my passing light bar to a deer and did not replace it. I just got a stock turn signal set from eBay instead. This means that I my passing lamp bar spacer is no longer being used. If you or anyone else here wants the spacer block, i would appreciate a small sum in addition to the shipping costs - maybe ten or fifteen dollars plus shipping. I don't remember what i originally paid for it, but i would like to defray the cost of repairing my bike after the deer, so hence the ten or fifteen bucks. I also have a pair of H7616 sealed-beam bulbs for the passing lights. They are way brighter than the stock sealed beam bulbs, and shine in a narrow spot pattern. I would like ten or fifteen plus shipping for those as well. Come to think of it, I also have the stock bulbs. Link to comment Share on other sites More sharing options...
XV1100SE Posted January 24, 2011 Author Share #5 Posted January 24, 2011 AHoutzer - PM sent Link to comment Share on other sites More sharing options...
OutKast Posted January 25, 2011 Share #6 Posted January 25, 2011 I sent PM also about the spacer block if XV1100 does not take it. Can anyone give us the current vendor for the spacer block? Looked all through the classifieds and got nothing! The guy should add to the "member vendors". Link to comment Share on other sites More sharing options...
Rickster Posted January 25, 2011 Share #7 Posted January 25, 2011 This is what most have used I got one from Tony contact him. You are talking about the spacer that moved the light bar away from your fairing correct? Submitted by Tony Dathan. Problem: One of the common complaints about the Yamaha passing light kit for the RSV is that it mounts so close to the fairing that removing the fairing becomes very difficult requiring one to either remove or loosen the passing light bracket. Installation: When the bracket arrives you will need 2 3/8" NC x 3/4" long bolts and lock washers. I got these at Home Depot for under two bucks. Undo your light bar. Use the 8mm bolts to fasten the bracket where the light bar was and then using the 3/8" bolts bolt the light bar to the bracket. Most of us that have the bracket can now split the fairing without touching the light bar or at least just loosening it a few turns. Might depend on the actual lights you have. Basically you undo the light bar, put the bracket where the bar was, then mount the light bar to the bracket! How to get one: You can contact me at dathan@shaw.ca The price at this time is $27.50 USD. That includes the postage as well! The following are some shots I've taken in the past! #5 shows the clearance between the back of the light and the fairing. This started as a way of my being able to clean between the light and the fairing. Taking the fairing off without touching the light bar was just a huge bonus! Attached Thumbnails Link to comment Share on other sites More sharing options...
saddlebum Posted January 25, 2011 Share #8 Posted January 25, 2011 To answer your first question, yes those are just the lights, you have to also order the mounting arm. Spacers should be acquired at any hardware store...To answer your question properly. You first off need a first gen to even require passing lights. to put passing lights on a second gen is just a waste of time and money:witch_brew: Link to comment Share on other sites More sharing options...
Hummingbird Posted January 25, 2011 Share #9 Posted January 25, 2011 To answer your question properly. You first off need a first gen to even require passing lights. to put passing lights on a second gen is just a waste of time and money:witch_brew: that's somewhat true because the second gen will be leading anyway - making way for lessor of Yamaha's production line Link to comment Share on other sites More sharing options...
