1joeranger Posted November 25, 2010 Share #1 Posted November 25, 2010 Seems for Thanksgiving I got a gas leak! Yhea me, I was wondering what to do on this one good day off!! Upon starting the bike I find fuel dripping off the front left engine guard up near the wheel. Pulled the tank cannot see anything and believe I finally will have to pull the airbox for the first time and search around the carbs (virgin territory for me)! Any thoughts or experiences with this?!? Could really use some guidance here! Happy Thanksgiving All!! Link to comment Share on other sites More sharing options...
Kregerdoodle Posted November 25, 2010 Share #2 Posted November 25, 2010 I am no wiz when it comes to that, but from posts that I have read, sounds like you may have a stuck float..tap around on the bowls with the handle of a screw driver and see if that does anything for ya. I am sure that others will have better advise. Good luck and have a Happy Thanksgiving!! Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 25, 2010 Share #3 Posted November 25, 2010 Time for Sea-Foam. Link to comment Share on other sites More sharing options...
BOO Posted November 25, 2010 Share #4 Posted November 25, 2010 Yep Yep Yep sounds like a stuck float. Like Dan said try the seafoam, sometimes it works sometimes you have to take the dang thing apart. Good Luck, BOO Link to comment Share on other sites More sharing options...
1joeranger Posted November 25, 2010 Author Share #5 Posted November 25, 2010 Thanks everyone I'll give the seafoam a try! Then I might try adjusting the floats (maybe). I know V7Goose wrote up a article here somewhere about that. I guess its time to stop being intimatedated by this carbs!! Link to comment Share on other sites More sharing options...
MiCarl Posted November 25, 2010 Share #6 Posted November 25, 2010 Sometimes you can do the following to flush crud out of the float needle: Turn the fuel valve (on the tank) to "OFF". Ride around the block and turn back on. Ride again. If there is crud hung up in the seat drawing the fuel down then filling back up as described above sometimes washes it free. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 25, 2010 Share #7 Posted November 25, 2010 What Carl said works good if the crud you have in there is loose. From your post it sounds as if bike may have sat a while?? The gas we have to use today does not like to sit. If you plan to leave it sit for any time it is best to use Sta-Built or Sea-Foam to help keep the gas from going bad. Link to comment Share on other sites More sharing options...
Monty Posted November 25, 2010 Share #8 Posted November 25, 2010 Also, try to find gas stations that don't use Ethanol in their gas. We have a few stations here, and that's what is in my tank. Link to comment Share on other sites More sharing options...
GeorgeS Posted November 25, 2010 Share #9 Posted November 25, 2010 Each carb bowl has a drain. Drain each one seperatly after putting a good dose of Sea-Foam. Link to comment Share on other sites More sharing options...
1joeranger Posted November 25, 2010 Author Share #10 Posted November 25, 2010 Ride er to work each and every day and fill up at the station that has no ethanol! I won't even put that in my lawn mover!!! Like the idea of draining the bowls. Is that something easy to access?! Thanks everyone!! Link to comment Share on other sites More sharing options...
skydoc_17 Posted November 25, 2010 Share #11 Posted November 25, 2010 Hey Ray, I have attached a pic of a First Gen. Carb. to give you a general idea at what you are looking for. The Phillips Head Screw is the "drain Screw", the black tube is where the gas is going to come from when you turn the drain screw counter clock wise. There is no need to remove the drain screw, just unscrew a turn or two to get the gas to flow out. If you have the tank petcock on there will be an endless flow of fuel (until the tank is empty) With the petcock in the off position, you will only drain the Carb. Bowl. I would do all 4 Carbs. Because your bike sits on the side stand all the time, the two left Carbs. are usually the gunked up ones. This is not an unusual problem and indicates you are not riding the bike enough. (or so, that's what I tell Jean, "going for a Maint. ride honey") There is no need to overdue it with the Seafoam, a few ounces in a tank of gas for a few tanks of gas is better than a can of Seafoam in one tank of gas. Hope this helps, Earl Link to comment Share on other sites More sharing options...
1joeranger Posted November 26, 2010 Author Share #12 Posted November 26, 2010 Really like skydoc_17's idea here unfortunately picture does not jive with my 2nd gen carbs! Anyone got a picture of drain screw? Can you access one without taking parts off? Link to comment Share on other sites More sharing options...
skydoc_17 Posted November 26, 2010 Share #13 Posted November 26, 2010 (edited) Hey Ray, I have attached an exploded view of one of the Carbs. from your bike. I know it is not an actual pic, but this should get you close. The yellow arrows mark the drain plug and drain tube. Sorry for the confusion, Earl Edited November 26, 2010 by skydoc_17 SPELLING! Link to comment Share on other sites More sharing options...
1joeranger Posted November 27, 2010 Author Share #14 Posted November 27, 2010 Earl I have a somewhat similar picture in my Clymer Service Manual. After looking at yours I pulled up the Yamaha Service Manuel I had downloaded. Neither manual show a drain plug or hose!? Link to comment Share on other sites More sharing options...
1joeranger Posted November 27, 2010 Author Share #15 Posted November 27, 2010 Here is what I'm looking at! Link to comment Share on other sites More sharing options...
MiCarl Posted November 27, 2010 Share #16 Posted November 27, 2010 Your service manual does not have it labeled. It screws into the part labeled #14 in the pic from your manual page. You can also see the hose nipple on part #14. Service manuals are rarely as complete as the parts fiche, which is where Skydoc's picture came from. Your service manual quite likely does show the hose. It'll be in the section where it show cable and hose routing. Link to comment Share on other sites More sharing options...
1joeranger Posted November 27, 2010 Author Share #17 Posted November 27, 2010 Cool! Learning all kind of interesting things!! Can that screw be access without removing carbs? If I follow the schematic correctly the screw should be facing inside? I'm gonna go investigate just looking for some pointers here. Thanks!! Link to comment Share on other sites More sharing options...
