sgtjcj Posted May 13, 2010 Share #1 Posted May 13, 2010 I am getting ready to get new tires for my RSTD. On my RoadStar, I have had 4 sets of Venom X, 1 Venom R, 2 Metz 880, and the stock tires. I found that I like the venoms more than any other tire for the heavy cruiser. I am looking at the 2 available for the RSTD one is rated "H" and the other rated "V". The H has a heavier load capacity. Do any of you Venom X owners have an opinion as to which tire would be longer lasting & why? Thanks Link to comment Share on other sites More sharing options...
Kregerdoodle Posted May 13, 2010 Share #2 Posted May 13, 2010 I have a Venum X -H on the front of mine with over 20k on it and still have tread left. it is starting to cup a bit on the outsides but other then that I got my money out of it.. I am getting ready to get new tires for my RSTD. On my RoadStar, I have had 4 sets of Venom X, 1 Venom R, 2 Metz 880, and the stock tires. I found that I like the venoms more than any other tire for the heavy cruiser. I am looking at the 2 available for the RSTD one is rated "H" and the other rated "V". The H has a heavier load capacity. Do any of you Venom X owners have an opinion as to which tire would be longer lasting & why? Thanks Link to comment Share on other sites More sharing options...
hig4s Posted May 13, 2010 Share #3 Posted May 13, 2010 I am getting ready to get new tires for my RSTD. On my RoadStar, I have had 4 sets of Venom X, 1 Venom R, 2 Metz 880, and the stock tires. I found that I like the venoms more than any other tire for the heavy cruiser. I am looking at the 2 available for the RSTD one is rated "H" and the other rated "V". The H has a heavier load capacity. Do any of you Venom X owners have an opinion as to which tire would be longer lasting & why? Thanks Not sure the rating or load capacity will make any difference in longevity, but I firmly believe that higher load capacity is always better and safer on a heavy bikes like these. Link to comment Share on other sites More sharing options...
RandyR Posted May 13, 2010 Share #4 Posted May 13, 2010 http://www.avonmoto.com/products/cruiser-touring-custom/venom 71=761lbs , 74=827lbs, 80=992lbs 2848912 150/90B15 80H 2848913 150/90B15 74V H is rated for 130mph V is rated for >149mph I 'think' the V tire has a lower weight rating because its rated at a higher speed. I have a '74V' rated rear tire on my RSTD with 2,000 miles on it. No problems so far. For the front I see: 2807412 150/80-16 71H 2805012 MT90B16 74H (narrower tire) Any of these tires are rated in excess of what even a heavily loaded bike should put on them. btw. here's a $25 per tire rebate for Avon's bought this month. Link to comment Share on other sites More sharing options...
gibvel Posted May 13, 2010 Share #5 Posted May 13, 2010 V7Goose said that the H lasts longer. When I needed the rear replaced on my Venture I called him from the shop to confirm which one lasted longer. Max sidewall is also 50psi as opposed to, I believe, 42 although he recommends 48 in the rear just cause it handles better. Link to comment Share on other sites More sharing options...
RandyR Posted May 13, 2010 Share #6 Posted May 13, 2010 Just checked a few web sites. SW Moto has the best prices for the Avon Am41. $126.95 shipped for the MT90HB16 #2805012 less $25 rebate thats $102 plus mounting. I'll see if my local shop will come close. They charge $25 for mounting if I bring in the wheel. AVON AM42 150/90HB15 VENOM REAR $142.95 re: H vs V rear. I'll have to see what kind of mileage I get. I didn't realize I was getting the V rated tire until I already had it via a private seller off ebay. If it has better traction, then I'm ok with a lesser tire life. I'll ask Avon what they think. Link to comment Share on other sites More sharing options...
sgtjcj Posted May 13, 2010 Author Share #7 Posted May 13, 2010 Being an Avon fan already, it was probably inevitable that I was going to buy one of the 2. My assumption was that the V rated gripped a bit more which in turn made it softer. I figured I would be buying the H rated for longevity. The rebate pretty much clinches the deal to buy right now. Thanks for the info. btw. here's a $25 per tire rebate for Avon's bought this month. Link to comment Share on other sites More sharing options...
RandyR Posted May 13, 2010 Share #8 Posted May 13, 2010 Here's the reply from Avon tech support: The V rated tire is designed for the Yamaha V Max. It has a stickier compound so it gets a bit less mileage and has less of a load rating as that is not as crucial on this bike as it would be on a tour deluxe. V speed is 149 mph vs H rated which is 130 mph. The handling of the tires is the same for agility and easy turn in. At lower speeds load could be quite similar but I don’t have test results for that so I can’t quote you anything. For your bike I would stick with the H rated tire, especially since the front is H rated so you have a match. Link to comment Share on other sites More sharing options...
CMIKE Posted May 13, 2010 Share #9 Posted May 13, 2010 http://www.jakewilson.com Has a pretty good deal right now... Front 150/80H-16 (71H) Avon Venom AM41 125.99 Rear 150/90HB-15 (80H) Avon Venom AM42 $125.99 Plus you get the $25 rebate per tire... AND FREE SHIPPING. I just bought a set for the VStar Custom that my son rides. Link to comment Share on other sites More sharing options...
greg_in_london Posted May 13, 2010 Share #10 Posted May 13, 2010 Any of these tires are rated in excess of what even a heavily loaded bike should put on them. Speak for yourself - you'd be amazed what these things can pull if you upgrade the suspension enough. I used the use the Conti Tour, but it has been discontinued (in the UK at least), so had to switch to the Avon. Link to comment Share on other sites More sharing options...
frogmaster Posted May 13, 2010 Share #11 Posted May 13, 2010 How soon we forget... Use the search box and enter cracking, sidewall & Avon. Link to comment Share on other sites More sharing options...
Sailor Posted May 13, 2010 Share #12 Posted May 13, 2010 Used the v rated super venoms on my Madura. They were rated for the bike which was 150 mph. I would burn through the rear tire in one season but I rode it hard and it performed well. I now use the venom h on the venture. good performance but longer lasting. Into my third season with it and I think. another three to go at least. Link to comment Share on other sites More sharing options...
sgtjcj Posted May 14, 2010 Author Share #13 Posted May 14, 2010 Indeed. I pulled a 1220 lb. trailer from Mississippi to WA state (3400 miles) with my RoadStar. These bikes will do whatever is asked of them. Speak for yourself - you'd be amazed what these things can pull if you upgrade the suspension enough. I used the use the Conti Tour, but it has been discontinued (in the UK at least), so had to switch to the Avon. Link to comment Share on other sites More sharing options...
