jmmckenz Posted November 30, 2009 Share #1 Posted November 30, 2009 Hello everyone: This is my first post and I am sure that I am not doing this correctly so please bear with me. My basic question is this. Is there a good quality horn replacement out there, that does not require rewiring and will basically fit into the stock placements. My horn on the right side does not work and I would like to replace it but I do not want to deal with wiring and similar issues right now. Any help would be appreciated. - Thanks MM Link to comment Share on other sites More sharing options...
BuddyRich Posted November 30, 2009 Share #2 Posted November 30, 2009 For a plug and play replacement you would want to use another OEM. They stink as far as level of sound. Many of us have put the Striebel Airhorn there. But you'll have to wire up a relay. If you still want the OEM I'm sure someone here has one they would be willing to get rid of. I don't know where mine is or I would offer it to you. Good Luck Link to comment Share on other sites More sharing options...
Cougar Posted November 30, 2009 Share #3 Posted November 30, 2009 Striebel Airhorn Link to comment Share on other sites More sharing options...
Two Tone White Posted November 30, 2009 Share #4 Posted November 30, 2009 Hello everyone: This is my first post and I am sure that I am not doing this correctly so please bear with me. My basic question is this. Is there a good quality horn replacement out there, that does not require rewiring and will basically fit into the stock placements. My horn on the right side does not work and I would like to replace it but I do not want to deal with wiring and similar issues right now. Any help would be appreciated. - Thanks MM http://www.venturerider.org/forum/search.php?searchid=1805823 Link to comment Share on other sites More sharing options...
atlm Posted November 30, 2009 Share #5 Posted November 30, 2009 I highly recommend the Stebel air horn. I put them on all my bikes now, since stock horns are completely ineffective. Carbon One (on this forum) makes an adapter for the 2nd gen Venture that works perfectly. It comes with the instructions to wire it. The horn comes with everything else you need, including the relay. Since the battery is only about a foot away from where the horn mounts, it's an easy install. Link to comment Share on other sites More sharing options...
rumboogy Posted November 30, 2009 Share #6 Posted November 30, 2009 Can you show some pictures of how it looks installed. Thanks, Wally Link to comment Share on other sites More sharing options...
Dave77459 Posted November 30, 2009 Share #7 Posted November 30, 2009 Can you show some pictures of how it looks installed. Thanks, Wally Stebel long view: http://farm3.static.flickr.com/2345/3761583151_454086f1fc.jpg Stebel close up: http://farm4.static.flickr.com/3228/3390568060_0beacb3ca8.jpg Stebel plus V7Goose's horns (on the saddle bags): http://farm4.static.flickr.com/3449/3393058867_6db39a2a58.jpg Link to comment Share on other sites More sharing options...
SilvrT Posted November 30, 2009 Share #8 Posted November 30, 2009 here's another thread for an idea... [ame=http://www.venturerider.org/forum/showthread.php?t=41530]Stebel Nautilus Horn Install - VentureRider.Org[/ame] Link to comment Share on other sites More sharing options...
Skid Posted November 30, 2009 Share #9 Posted November 30, 2009 The relay for the Stebel horn is not that bad to wire up. I'd say if you need some help there is probably another member close that would be willing to help. I would but I may be a little far away. Or if you can wait till anothef VR get-together I'm sure there would be several volunteers..... Link to comment Share on other sites More sharing options...
dynodon Posted November 30, 2009 Share #10 Posted November 30, 2009 An option to the air horns is a Hella Horn. Here is the version I have heard about from an E-bay source, but you can also get them through Griots garage or other sources: http://cgi.ebay.com/ebaymotors/Hella-Supertone-Electric-Horn-Set-Porsche-85115_W0QQcmdZViewItemQQhashZitem3357c12a00QQitemZ220515609088QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories The nice thing about these is they should go in the stock locations and should not require a new relay. Will be louder than stock. Link to comment Share on other sites More sharing options...
